NWP 75 mm throttle body installed, first thoughts
Old 07-29-2013, 11:09 AM
  #41
so nasty nismo's Avatar
Wow, give a good review on the item show some respect to Nwp instead of going of topic.
so nasty nismo is offline
Old 07-29-2013, 11:30 AM
  #42
a.k.a. STuNtMAN
JonBlz's Avatar
^^I'm not saying anything bad about NWP and never will i have all his stuff on my car
JonBlz is offline
Old 07-29-2013, 02:24 PM
  #43
theblackone3.5's Avatar
Originally Posted by JonBlz
in order to get rid of the throttle delay you have to get yourself a sprint booster.......bigger TB will make it respond better but the delay will still be there....sprint booster takes care of that issue, i know because i have one in my 02 max
They dont make a sprint booster for the 6th gen maxima. I have a 96 max and a 05 max.
theblackone3.5 is offline
Old 07-29-2013, 03:08 PM
  #44
ranmas2004's Avatar
Originally Posted by TexasTex
"Ban them?" HAHAHAHA, wow man, that is a ridiculous statement.
Based on your posts, I'd imagine you guys have slowed down on the ol' site because your nap times and Matlock reruns get in the way.
I get what you're saying there Mrinternetzpolice, but seriously. Are you gonna run around every thread making sure everyone is in perfect cooperation with the sites rules and regs? Okay Hot Fuzz.
Who are you again? Oh, you're a guy that has 1300 posts and has been here longer. OOOOOOOHHHHHHHH, you better police all the newer people on here. Don't you think that the mods know how to ya know, MOD? Go take your Geritol and blood pressure medicine now, because we all know policing the "netz punks" is stressful proposition.
Coming from a NEWB with 98.6% activity....sounds like someone needs a life.
ranmas2004 is offline
Old 07-29-2013, 03:23 PM
  #45
TexasTex's Avatar
That's so insulting. How could you muster such words? You're so impressive.
TexasTex is offline
Old 07-29-2013, 03:31 PM
  #46
Fakie J Farkerton's Avatar
Dude. With all due respect, please leave this thread. No good will come of this.
Fakie J Farkerton is offline
Old 07-29-2013, 03:32 PM
  #47
blue_magicSE's Avatar
My question is where the TB adapter plate and the elbow meet.. can that be opened up more? (the elbow opening)
blue_magicSE is offline
Old 07-29-2013, 03:50 PM
  #48
Donkeypunch's Avatar
When you test for intake restriction you see what atmo is for example: 98kpa
Then you hook up a gauge to the manifold and if it's like 90kpa you have a big restriction.
Take the air box off and see if it goes higher.. If not, then the box isn't a restriction.
Get a BBTB and see how that does ect.
Allot of cars come with a non restrictive throttle body unless it's modified like cams/headers/tune.
I have a 90 bmw that I tested and the throttle body is slightly
restrictive, but it's boosted now so it doesn't matter.
Donkeypunch is offline
Old 07-29-2013, 11:21 PM
  #49
a.k.a. STuNtMAN
JonBlz's Avatar
yea idk about the 6th gen sprint booster but for the 02-03 maxima they have it, and a 4th gen would not need it because it is cable driven so there is no throttle response delay
JonBlz is offline
Old 07-30-2013, 05:29 AM
  #50
ranmas2004's Avatar
7th gens have it...they would need it with the CVT taking so much power from the car.
Old 07-30-2013, 10:43 AM
  #51
nishfish871's Avatar
It would be great to see what the intake restrictions are. Im betting the elbow is the most restrictive after you have a bigger throttle body. Seeing as you go right back to the 70mm...
nishfish871 is offline
Old 07-30-2013, 01:04 PM
  #52
95naSTA's Avatar
IIRC the stock bore on the elbow is 72mm, so you only need to open it 1.5mm all around.
I did it easily with a drill and flapper wheel.
http://forums.maxima.org/all-motor/6...ter-plate.html
95naSTA is offline
Old 07-30-2013, 02:20 PM
  #53
If the stock elbow is 72mm then the TB is a bottleneck for sure.
Old 07-30-2013, 02:31 PM
  #54
CauzinDrama's Avatar
The 72 millimeters really isn't too much of a bottleneck if you're still using the stock Maf. Which I think more people are then aren't.
CauzinDrama is offline
Old 07-30-2013, 03:08 PM
  #55
I love lamp.
maximase86's Avatar
Anyone done this mod with a large bore MAF as of yet? I'm interested in doing this, but at it stands, I'm just doing the Stillen popcharger with a stock maf and piping/with resonator. It seems to me that it would be a little counter intuitive to use the stock MAF size with this sort of mod. I would probably want to do the full monty for this mod.
S
maximase86 is offline
Old 07-30-2013, 05:13 PM
  #56
95naSTA's Avatar
I went from a 3" (76mm) ID to a 83mm ID Q45 MAF on my 3.5 hybrid before the 75mm TB. FWIW the larger MAF + stock TB had more of a butt dyno gain than larger MAF + 75mm TB.
95naSTA is offline
Old 07-30-2013, 05:21 PM
  #57
95VQ30's Avatar
Won't you need a tune and new mapping with a larger MAF?
95VQ30 is offline
Old 07-30-2013, 05:34 PM
  #58
S
The dyno results show it is not counter intuitive. If you use a larger MAF and piping then you will probably see better results.
And tuning will be required if a larger than stock Maf is used.
Old 07-30-2013, 09:19 PM
  #59
03maximaguy's Avatar
might be dumb question but I don't follow. what will a sprint signal booster do for throttle response?
03maximaguy is offline
Old 07-30-2013, 09:39 PM
  #60
MaxinO2's Avatar
^ nice, I may plan to do something like this in the near. Just depends on if its worth the little gain or not. I still don't have headers or cat-back yet so
MaxinO2 is offline
Old 07-30-2013, 10:41 PM
  #61
melvinman2003's Avatar
Did some daily driving on highway to work and noticed mpg goes down
Just wanted to let you all know on the highway the throttle body is peppy. I can see cars disappear more in rear view then ever before.
The downside I notice is I need to be a lot more conservative on the gas. If I hover around 72 at 3000-3100 rpms I get around 24.0 mpg in 4th on my auto.
If I dig into the throttle I have seen it dip to 22.6 mpg. I see the MPG moving more frequently now. I think tuning my car with the turbo xs utec should help resolve some issues. I also know light to light cruising and idle my mpg seems worse. Anyone else have this problem?
melvinman2003 is offline
Old 07-30-2013, 10:44 PM
  #62
http://www.kbb.com/nissan/maxima/2002-nissan-maxima/
Apparently 24 mpg is the norm I guess. I have gotten to 24.5 at best. I also know that I need air in my tires. This might bump it back. It has been hot here. Let me try that and see what it does. I just never noticed a huge jump in mpg pegging it until now. Maybe that means its working LOL.
Old 07-31-2013, 04:15 AM
  #63
ranmas2004's Avatar
More air = more gas. Welcome to the wonderful world of mods! I get about 20-21mpg in my turbo 3.5L Maxima. You can try to tune it out, but usually a tune will get you more power....= more fuel. You can tune light cruising to run around 15.0-15.1 ish to save gas, but when you accelerating the tune will be to get that power....so you will need more fuel.
Old 07-31-2013, 06:48 AM
  #64
At 72 mph I'm only turning about 2600 - 2700 rpms.
Old 07-31-2013, 07:33 AM
  #65
Max_Gator's Avatar
Yes please.
Max_Gator is offline
Old 07-31-2013, 08:39 AM
  #66
dot dot dot ...
NmexMAX's Avatar
Originally Posted by Max_Gator
Yes please.
Let me get my Pathfinder squared away and I plan on dynoing this with my set-up, before and after the TB and also giving that Sparks IM another chance.
Stay tuned. (no pun intended)
And again, with Maximas all logic is essentially tossed out the door as I've said before. 3" exhaust, 4" intakes, 440cc (very big) injectors for NA, all of which had anyone said anything about these mods 8-10 years ago would have been tossed to the wolves because logic does not support the theory. But we found it, they work.
NmexMAX is offline
Old 07-31-2013, 10:01 AM
  #67
Prophecy99's Avatar
is your intake 4" how big is the RR MAF
Prophecy99 is offline
Old 07-31-2013, 10:22 AM
  #68
Leroni35's Avatar
Does anyone have this tb mated to a TRUE CAI ? i.e. cattman or anything that goes into the fender?
Leroni35 is offline
Old 07-31-2013, 10:44 AM
  #69
dot dot dot ...
NmexMAX's Avatar
In my expereince, and as what I said earlier regarding logic, I believe true CAI's are overated. I've done many many IAT logs, and it really only comes into play when in stop and go traffic, a palce where you really don't need/want an intake anyhow. My IAT's on the highway (45+MPH), and moderate (30MPH) speed cruising are typically ambient ± 3ºC.
Our worst enemy is the aluminum getting heat soaked, and there's very little we can do about that.
I am willing to bet any car properly set-up with a 3" or larger MAF and associated tubing would outperform a car set-up properly with a PRCAI.
But to asnwer your question, considering how young this mod is, and how rare a truae CAI is these days, I'd bet the asnwer is no.
LR/RR MAF is 82mm, this one is around 100mm. 440's or greater are a must with it.
NmexMAX is offline
Old 07-31-2013, 12:29 PM
  #70
The stock coupler on the cold air snorkel always comes off on mine.
Is that the case with you guys too?
Is there a common fix?
Old 07-31-2013, 12:54 PM
  #71
dot dot dot ...
NmexMAX's Avatar
Where it meets where the other piece sits on top of the radiator?
Yeah, happened so often I got medieval with it and used a screw in there acting as a pin.
NmexMAX is offline
Old 07-31-2013, 01:30 PM
  #72
Gemner's Avatar
MrJasonlyrics.......
This why I hardly come on here anymore. Dont even waste your time responding anymore...let mods just ban them.
Originally Posted by mrjasonlyrics
I hear you bro. I too have slowed down because of this but I still poke my nose in once every so often to see what's good with this site. I mean how hard is it, rules are rules and the site forbids you post anything like this. Oh well. I'm out.
Ive been on this site years longer than both of you noobs and you are both correct AND at the same time you dont know WTF youre talking about. Years ago this argument would have never happened (thats where youre correct) because nobody would have wet their pants over someone posting a video of themselves going 90...or heaven forbid even well over 100
Gemner is offline
Old 07-31-2013, 05:00 PM
  #73
Toolie
knight_yyz's Avatar
I just grabbed an elbow from the salvage yard and the opening was 73mm, so i did some fancy grinding, took out some of the shelf, and got it to 74mm. Going to 75 would be a ton of grinding to make it worthwhile. It can be done though. I just hate grinding aluminum because it clogs up carbide burrs, and stones.
I will be mating my BBTB with an 80mm ID BBMAF and velocity stack. Dyno tune will follow in a few weeks. I will also be cermaic coating the elbow and upper IM, the lower is already done.
knight_yyz is offline
Old 08-01-2013, 06:15 AM
  #74
You beast mode you
I am doing the same, grinding the elbow. No point having it go small again after the TB.
Old 08-01-2013, 01:03 PM
  #75
Toolie
knight_yyz's Avatar
I just found the shelf started way too early, almost like it was acting as a blockage. I still need to smooth it out a bit.
Old 08-02-2013, 07:16 AM
  #76
I actually got my mileage back up to 24.8 mpg! What I ended up doing was filling tires to 40 psi, alignment, and a crankcase breather filter. The nipple coming off my intake pipe was a restriction. The air in tires upped it to high 23 mark but the crankcase filter helped get me in the high 24 range!!
I also know for a fact when you start making cars suck in a lot more air a catch can and or breather filter is needed on the valve cover or you burn oil in your intake tract from the valve cover. I had a similar issue on my Celica. I also noticed after the breather filter it eliminated the oil smell id get after a hard run on the Maxima. I recommend a breather filter to anyone who is modding heavily. It will save on oil consumption and your mileage will go up due to less oil being burnt during combustion.
Old 08-02-2013, 07:59 AM
  #77
Gemner's Avatar
yeah, mods dont cause bad gas mileage, if anything in general they will lead to better mileage because they facilitate a more efficient burn. Your car only needs x amount of power to go y speed and engine modifications dont change that. Its keeping your foot out of the go pedal once its modified that is the trick.
Gemner is offline
Old 08-02-2013, 08:08 AM
  #78
But when it sounds sooooo good it's hard not to... Lmao
Old 08-02-2013, 08:53 AM
  #79
ranmas2004's Avatar
DANG 40psi? I usually fill to 32psi. Yeah I put breather filters on both my valve covers it helps but still burns.
Yup...isnt that the whole point of modding? Why mod if you just going to stay regular driving?
Old 08-02-2013, 08:54 AM
  #80
Is 40 PSI safe?
Quick Reply: NWP 75 mm throttle body installed, first thoughts
