5th Gen: What did you do to your 5th Gen today?
Old 05-21-2013, 10:41 AM
  #81
DOODOOCHIP's Avatar
are those tails painted or you got overlays on them.
DOODOOCHIP is offline
Old 05-21-2013, 10:57 AM
  #82
SSJRICH's Avatar
More playing with ride height and dampening settings... getting close... Can't wait to align the car so the wheel is straight...
SSJRICH is offline
Old 05-21-2013, 11:26 AM
  #83
5thGenHaas's Avatar
I usually dont post on the forumns but i go on everyday, but here is what i did today, i Put on my G35 18's powdercoated black. I also put my new smoked side markers and blacked out my headlight housings. What do you guys think? lowering springs and struts this weekend...cant wait
Attached Thumbnails 5th Gen: What did you do to your 5th Gen today?-img_20130514_204854.jpg
5thGenHaas is offline
Old 05-21-2013, 11:27 AM
  #84
dot dot dot ...
NmexMAX's Avatar
Installed that plastic button on the seat belt that keeps the seat belt clip from sliding to the floor when the seat belt is not being worn.
It's the little things that sometimes make a big difference. Just ordered the small plastic cover that goes near your foot near the gas pedal.
I lost mine in my ECU wiring/modding days and now it looks a bit weird and one wire is spliced and sometimes depending if i have sht kickers on, I'll grab taht wire and bam, there goes my CC.
Only problem I got an email telling me it was on national backorder from Nissan USA.
Next up, going to try and finally connect my primary O2's into the headers without extending them. I hope it can be done. Only problem is, I drive it every day so I can't do that job during the week, because hot.
Looks really good. Nice and clean. Going to look even better with the springs and strutrs.
What brand you get?
NmexMAX is offline
Old 05-21-2013, 11:35 AM
  #85
5thGenHaas's Avatar
I got the Kyb AGX and vogtland lowering springs...all i need after that is to remove the cancer on the rear wheel wells That alone is going to be sooo much funnn
Old 05-21-2013, 11:36 AM
  #86
Finchum's Avatar
Painted. Just took my time taping the lens and trying to eyeball where the chrome ring was.
Finchum is offline
Old 05-21-2013, 06:06 PM
  #87
zach90z's Avatar
Replaced the power steering belt and painted some screws.
zach90z is offline
Old 05-21-2013, 10:33 PM
  #88
jsonde's Avatar
Dipped my rims /molding/grill!
Plastidip!!!!
Attached Thumbnails 5th Gen: What did you do to your 5th Gen today?-2013-04-28-09.01.17-1.jpg
jsonde is offline
Old 05-21-2013, 10:47 PM
  #89
zsolt117's Avatar
Did you use a special paint or just regular spray paint?
zsolt117 is offline
Old 05-22-2013, 06:22 AM
  #90
Maverick4189's Avatar
How good are those threads gonna be covered in pain?
Maverick4189 is offline
Old 05-22-2013, 06:35 AM
  #91
Fakie J Farkerton's Avatar
Quoted before he fixes it.
Threads covered in pain.
Fakie J Farkerton is offline
Old 05-22-2013, 07:28 AM
  #92
zach90z's Avatar
I used Dupli-Color Engine Enamel 500 degree.
Very painful hahaha. But on a serious note I covered the threads in tape and sand blasted the bolt heads only. Then I stuck the threads in the cardboard box so I wouldn't paint over them since they are ok.
zach90z is offline
Old 05-22-2013, 08:08 AM
  #93
a33nismo's Avatar
I took my worthless injen intake that i removed after i realised how much hot air that thing gets when the fans are on and turned it into a true cold air intake like the old place racing intake.
Took maybe 1 hour to do it and that includes doing the battery relocation mod that i found on the forum.
Since i dont have fog lights i took the dremel and cut out the inside of the fog light slots so direct cold air can get into there.
I also position the filter as you can see right above the whole so direct rain won't hit it coming in you can just see the bottom of the filter through the whole.
Since yesterday i ordered 3 new Injen couplers so everything will match and get rid of the red spectre ones i used for the time being. I'm also picking up an old berk intake midpipe from a friend to get rid of the hermoltz resonator this weekend.
Also i will be cleaning up that part of the engine bay more this weekend since most of that area has been covered up until i did the battery location so everything will be nice and clean there soon like the rest of the engine.
a33nismo is offline
Old 05-22-2013, 10:05 AM
  #94
SSJRICH's Avatar
^^^^ Nice job on the CAI
Think I might have myself a weekend project
SSJRICH is offline
Old 05-22-2013, 10:47 AM
  #95
a33nismo's Avatar
It was well worth it.
With my scan tool my IAT are around 36 degrees colder while driving in 85 degree temps then when i had my injen located in the original location by the radiator and gets better at highway speed. The main thing i like is at idle in traffic or with the a/c on the IAT stay the same and aren't effect by engine heat or hot air from the fans.
Here is the link to the battery relocation thread i followed.
http://forums.maxima.org/5th-generat...ir-intake.html
Also if you don't have a injen intake currently you can buy just the pipes which are identical to the injen stuff for $20 and then just grab a couple of intake couplers and filter and have a intake for about $50 depending on filter i went with a apexi so it was alittle more.
Also you can use the elbow that came with the injen intake kit like in the battery relocation thread or just pick up and 3" 90 degree elbow like i did from autozone for $6 for a cleaner look but either way will work great.
http://www.ebay.com/itm/00-01-NISSAN-MAXIMA-3-0L-OBX-DIY-COLD-AIR-INTAKE-PIPE/330926652416?_trksid=p2047675.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D7842326274435825404%26pid%3D100011%26prg%3D1005%26rk%3D1%26sd%3D330904661807%26
a33nismo is offline
Old 05-22-2013, 11:06 AM
  #96
Garrettz459's Avatar
had some time to play with gold plasti dip
[IMG] /IMG]
[IMG] /IMG]
[IMG] /IMG]
[IMG] /IMG]
I have not seen a gold plasti dip before until just now
No offense but that doesn't look good at all in my opinion but again it your car I'd stick with black plasti dip... good thing you can remove the paint!
Garrettz459 is offline
Old 05-22-2013, 01:27 PM
  #97
SSJRICH's Avatar
Gold aint my thing as well... I think I might go Gun metal for my wheels
SSJRICH is offline
Old 05-22-2013, 01:56 PM
  #98
a33nismo's Avatar
Yeah gold rims are really a hard color to get right on some cars it really depends on the color of the car. Blue does really well with gold rim like the olf rally subaru's.
Oddly i'm looking into gold rims also because the Konig Daylite only come in 3 colors lol.
Gold , black with a yellow lip or Green.
These are the ones i was looking at. I'm really into light weight rims and these 17's are right at 14lbs.
http://www.discounttiredirect.com/di...r=9&wd=17&rw=7
also there other 2 colors they come in.
If the light gold wheels dont work out for me i could pick up the Kong backbone is 17x7.5 that weight 16.3 lbs so just alittle more.
a33nismo is offline
Old 05-22-2013, 02:01 PM
  #99
5thGenHaas's Avatar
What color is your max? i like the black ones the best but it depends of what color max u have
Old 05-22-2013, 02:05 PM
  #100
SSJRICH's Avatar
I am all for Subaru Blue STI with Gold rims but thats about it...
SSJRICH is offline
Old 05-22-2013, 05:16 PM
  #101
Old 05-24-2013, 12:56 PM
  #102
SSJRICH's Avatar
Going to wash her, and maybe change the fuel pump/filter and install new cabin air filter and motor.
If there is time, I'll get the shop to do up my new exhaust
SSJRICH is offline
Old 05-24-2013, 04:21 PM
  #103
DOODOOCHIP's Avatar
what you getting for ur new exhaust?
Old 05-24-2013, 07:07 PM
  #104
Rolled to a car meet then went to Fast and Furious 6 with them
Old 05-25-2013, 08:32 AM
  #105
SSJRICH's Avatar
Resignator delete, straight 2 1/4 with mangaflow and SS tip. (stock cat forward) Gotta keep it on the quite side with the kid on the way. Just want some note. I have had to many loud *** cars and its ok when your young and have a fast car... but daddy needs to be responsible (at least a bit)
SSJRICH is offline
Old 05-25-2013, 09:13 AM
  #106
Renaldo C's Avatar
Scaredy pants?
Drove my 6mt 2002 Maxima SE to the food store to pick up some groceries and this guy on a cell phone walked pass slowly in the crossing in front of me, I revved it and he jumped hahaha. vq35's sound monstrous between 3500 and 5000 .
Renaldo C is offline
Old 05-25-2013, 11:07 AM
  #107
SSJRICH's Avatar
How was the movie? Probably cheching it out tonight.
SSJRICH is offline
Old 05-25-2013, 02:00 PM
  #108
rebelhell's Avatar
Finally replaced my cabin air filter that I bought three months ago. And fixed a bad connection in my navigation that started annoying me last week. Need to wash and wax her pretty bad....maybe tomorrow.
rebelhell is offline
Old 05-25-2013, 02:04 PM
  #109
01maxium's Avatar
Got an alignment at the stealership and cost a wamping $109.00 but I have a membership card and get points, so it covered $85 of it and only had to pay $roughly 25 out of pocket.
01maxium is offline
Old 05-25-2013, 02:11 PM
  #110
cjandura's Avatar
Was that a 4 wheel alignment?
cjandura is offline
Old 05-25-2013, 03:23 PM
  #111
01maxium's Avatar
It was a 4 wheel alignment. quoted for $85.95 but the charged $9 for shop fees which is a rip off.
01maxium is offline
Old 05-25-2013, 03:39 PM
  #112
cjandura's Avatar
You do know there is No Fcukin way our cars can have a 4 wheel alignment right?
cjandura is offline
Old 05-25-2013, 05:01 PM
  #113
I usually use a sledge to adjust my rear
Old 05-25-2013, 05:58 PM
  #114
5thGenHaas's Avatar
Well today i put on my new struts and vogtland springs...so far love everything...just wish the front sat a little lower. let me know what u guys think?
Attached Thumbnails 5th Gen: What did you do to your 5th Gen today?-img_20130524_210147.jpg
Old 05-26-2013, 07:30 AM
  #115
It was legit. One of the best ones I'd say. Couple stunts were kinda far fetched but it was a great show. Prolly gonna go watch it again, after the credits is a extra bit and we know #7 is the final one so...
Old 05-26-2013, 02:34 PM
  #116
DOODOOCHIP's Avatar
damn #7, i remember that 5th was going to be last.
Old 05-26-2013, 07:50 PM
  #117
Brl24's Avatar
In the last week I did...
New front rotors and pads
Fresh oil and filter
P. front wheel bearing
Changed 2 tires and balanced all wheels
Installed 01 AE tails
Put pipe clamps on all the exhaust hangers, so solid now
and fixed my leaking muffler by welding on an 01 AE muffler, both thanks to a parts car I scored.
Also, I picked quite a few things from it, door sills, side markers, knuckles, LCA's... And lots more.
I was feeling pretty good about my car last night when I parked it in the garage and went out to see coolant on the ground... and all over the engine compartment.
So, today, I happily came across the recently replaced almost new rad, with perfectly functioning rad fans in that beaut of a parts car. Cleaned it up nice, swapped it into mine, and filled her up with fresh coolant.
Feelin pretty good about her right now.
Brl24 is offline
Old 05-26-2013, 07:58 PM
  #118
Brl24's Avatar
**** it, I'm goin out to retro the fogs into my car
Since they never existed when I bought it.
Brl24 is offline
Old 05-27-2013, 01:08 AM
  #119
00Lightsout's Avatar
pulled out the intake, removed battery, removed front valve cover, removed upper and lower intake manifold, disconnected all electrical, removed rear valve cover!!! she's gonna get her right bank head rebuilt & some paint this week!!
00Lightsout is offline
Old 05-27-2013, 10:09 AM
  #120
SSJRICH's Avatar
Explain how, I need to "adjust mine" The Rigth rear tires scraps with I hit big bumps but the left is just fine...
I am going for an alignment tomorrow morning but I doubt they will touch the rear...
SSJRICH is offline
Quick Reply: 5th Gen: What did you do to your 5th Gen today?
