Intermittent engine stutter
Intermittent engine stutter at idle - not quite a sputter or misfire. No CEL. Runs ok otherwise. recent MAF problems but fixed that. replaced plugs.
10/01 ( 2002 ) 3.5l with 175K miles and its an oil burner. 1 qt every 1000.
You can have a bad ignition coil or coils and NOT have a code thrown. Your symptoms line up with an intermittent misfire of one ignition coil.
I had the same problem and it finally threw the general misfire code after the coil got pretty bad with the intermittent misfire. I bought one new front and one new rear coil. Changed them one at a time until I found the bad coil.
Go with OEM ignition coils as aftermarket coils are hit and miss in terms of quality; no pun intended.
AaronL
11-15-2020 11:52 AM
mikeg75
11-30-2015 05:12 PM
RWCreative
09-21-2015 11:01 AM
lrb6805
09-17-2015 04:49 PM
