Most Trusted Place For Used 2001 Maxima ECMs?
I know I'm all over this thread about the godamn ECM/IACV bullsh*t, but I'm a total novice with cars in general and being a part-timer working for minimum wage in Connecticut, dealerships and shops just aren't an option.
I'm scared to get a rebuilt ECM just because there is no guarantee that it'd work. For example, I took mine out of my car and noticed the STA509A was fried. Okay cool, I bring it in for repair and the repairman explains to me there is no fixing it. Why? Because the damn shortage burned THROUGH every layer of the motherboard and almost through the metal case. So yeah, a new chip could be soldered on but it doesn't mean it'll work if the damn connectors are charred to nothing.
Anyway, do you guys have any positive experiences with certain places for used ECMs? I'm looking to spend no more than $300, so new ones are out of the question. No traction control on my vehicle. Also, will an i30 ECM work with my Maxima? Thank you in advance.
-Stru
-Stru
Would that all be settled once my car is towed to the dealership and they reprogram everything? I'm not sure how much they're going to charge for it though. I live in CT, so probably a lot.
ECU pin 6 ----- STA509A pin 9
ECU pin 7 ----- STA509A pin 7
ECU pin 8 ----- STA509A pin 3
ECU pin 17 --- STA509A pin 5
If any of these are open circuit, you just need to add a jumper wire from the mosfet pin to the connector. Not sure why the repair shop you visited was so clueless, probably just didn't want to deal with it, but the fix isn't hard and isn't risky. You don't even need to solder the new chip into the board, you could just tape a new one down and run jumpers wires from the leads to the 10 i/o. Remove the old one of course.
You can quickly determine if the output connections from the mosfet to the ECU connector are ok, just get a multimeter and probe continuity of the following:
You'll pay out the @$$ for their services but http://www.autocompdirect.com/ is who you want to talk to.
It's who the car-part.com people (like me) deal with from time to time.
I'm not a fan of their prices but their work is reputable.
ah2002
03-09-2016 01:42 PM
District
08-15-2015 08:23 PM
