What would be the steps for repairing a jerky transmission?
Old 03-05-2013, 03:25 PM
Stru's Avatar
My 01 Maxima SE has 160k on it and it's starting to show its age. I do need it to last me a little longer though and I need to repair the ECM and IACV first, I can't afford to dump money into a new transmission. The car is great on the highway but I do some driving downtown and the first to second gear shift is pretty damn rough, sometimes second to third too.
Are there any other parts I should check that may cause the jerking in this generation of Maximas?
Stru is offline
Old 03-05-2013, 03:44 PM
95VQ30's Avatar
Auto or 5spd?
95VQ30 is offline
Old 03-05-2013, 06:16 PM
Stru's Avatar
Automatic lol sorry
Stru is offline
Old 03-05-2013, 06:26 PM
rblower2012's Avatar
A transmission flush would help but it also can ruin a transmission if the fluid has never been flushed before. I would start by draining the oil and just adding new oil into it. Do that a few times and soon enough youll have all new fluid! Lol
rblower2012 is offline
Old 03-05-2013, 06:54 PM
q.man06's Avatar
^^This. If it's black/really dirty, probably just forget about the flush. It might start slipping when you change the fluid.
Only solution is to replace/rebuild it typically.
q.man06 is offline
Old 03-05-2013, 07:51 PM
dwapenyi's Avatar
DONT FLUSH. Just drop the old fluid and replace with fresh stuff.
Make sure to measure. If your drop 3.5 quarts, add 3.5 quarts of new stuff. Dexron III or equivalent.
dwapenyi is offline
Old 03-05-2013, 10:06 PM
Stru's Avatar
I bought the car from some crook off CraigsList. Didn't ride like crap when I bought it, but the next day I found out the ECM was fried (car doesn't like to start with a cold engine), and now a month later the transmission is acting up. Not sure if it's been flushed before, but how would I go about dropping the fluid without screwing up the tranny? Any recommended amount to drop?
Stru is offline
Old 03-06-2013, 09:23 AM
dwapenyi's Avatar
Ideally you would drop everything but that will never happen. Drop the old fluid out by opening the the plug for the tranny's oil pan. Then replace same amount thru the tiny dipstick up top.
You could repeat this procedure several times;
1. drop old fluid (make sure to measure)
2. Replace with new Dexron III fluid thru dipstick.
3. Drive the car for a day.
Repeat steps 1 and 2 and 3.
By driving the car around, you get the new fluid mixing with the old fluid, alot of which is still inside the TQ converter. By repeating steps 1 and 2 after driving you slowly replace all the fluid. You should notice a difference from the 1st time you do it.
I've done it on several cars and replaced like 3 quarts just doing steps 1 and 2 once. A difference was definitely noticed. The tranny seemed more alive, shift happy.
dwapenyi is offline
Old 03-06-2013, 05:09 PM
Pilm's Avatar
Have you looked at the ATF fluid on the dipstick yet? If not check to see if the level is right and if it's still red. Sometimes transmission can act up just from either too much or too little fluid. If it's really dark and ugly, proceed cautiously, the best way would be a simple drain and refill. Then drive around and see how it feels, if it feels better or no change, then a week later you can do another drain and fill. But if it seems worse, then leave it.
Pilm is offline
mkaresh
03-12-2018 06:48 PM
gigabyte
01-06-2017 06:05 PM
salty318
09-29-2015 01:21 PM
salty318
09-28-2015 07:22 PM
Quick Reply: What would be the steps for repairing a jerky transmission?
