Anyone have a part # for heat seat relay or fuse?
Firstly where is the relay or fuse located? Neither seat heater work. Car is an 03. I checked courtesy but only found the switch or heating element. Any help? Thanks in advance
The drivers side button bulb went out but the passenger side lights up but doesnt turn on.
I might just stop by Nissan tomorrow and check before work.
The relay is is next to the top left corner of the in dash fuse panel. In this fuse panel, check fuse # 12. It is used to energize the relay. I hope Nissan molded the numbers in the plastic like in the Maxima because I am not sure of the orientation of the fuse panel. My best guess is that fuse 12 is the one in the lower right corner.
Fuse 29 is a 15 amp and is in the under hood fuse box. Starting at the rear fender side corner, it is the 3rd position. Position 2 is empty.
It turns out that the Altima is vastly different from the Maxima. The Altima uses a relay for the heated seats and fuse # 29.
An No Nissan didn't mold the label into the plastic.. There is a black guideline but it doesn't mention anything about the seats or heaters. I'm going to copy n paste your response and email it to myself. Thanks again bro. Will report back tomorrow.
they don't have LEDs in them...at least the 5.5gen maxima doesn't. It's a tiny incandescent bulb. If you want to do LED, you can, just remember to orient it properly and use a resistor or you'll blow the LED. Better to just disassemble the switch, pop the current incandescent bulb, go to the parts store, grab another bulb and wire the leads the same way on the rubber thing. Reinstall and enjoy.
Bump! I replaced the lights in each switch only to find out that there are two bulbs in each one. I need the bulb that makes them illuminate when you turn the headlights on. Any help? It has like a little condom on it. lol
Radio shack 12v mini lamps or do a 3mm led and 1/8w resistor
Well someone deleted their comment. Gave me the wrong P/N for the light bulb that illuminates when the headlights are turned on.. Either way I fried my driver side switch so gotta get a new one now. The little copper sliding thing bent to hell. No connection moving it with my finger.
