2002 Maxima shakes hard
Old 01-25-2013, 01:15 PM
BT098's Avatar
I have a 2002 Nissan Maxima with Automatic transmission that is shaking very hard at idle and in gear. I think it could be either motor or transmission mounts. My question is I have never replaced the timing belt and the car has 125K miles if the belt were failing would it shake as well or what would be it's symptons?
BT098 is offline
Old 01-25-2013, 02:08 PM
vkcooke90's Avatar
That engine is actually chain driven, there is no timing belt. Do you notice alot of engine movement when the car gets put into gear, like you can see it shifting violently back and forth when the gear is selected?
vkcooke90 is offline
Old 01-25-2013, 02:48 PM
Aflion's Avatar
Do you have any engine codes? And you can look at the mounts to see if they are eaten/worn away.
Aflion is offline
Old 01-25-2013, 04:03 PM
Rcrootbeer's Avatar
Ignition coils my friend.
Rcrootbeer is offline
Old 01-25-2013, 04:20 PM
Get Off My Lawn
Chris Gregg's Avatar
^^^____ my first thought just reading the thread title. However, it is always a good idea to check your mounts if you've not. Especially the auto mounts, they are crap.
Chris Gregg is offline
Old 01-25-2013, 10:25 PM
da night ryder's Avatar
Check spark plugs as well. They will definitely cause shaking because of a misfire.
da night ryder is offline
Old 01-26-2013, 01:03 AM
K-Ryder's Avatar
Motor mounts, ignition coils, harmonic balancer. Check those thoroughly.
K-Ryder is offline
Old 01-26-2013, 05:59 PM
Puerto Rico-Maxima Lover
Lontar1's Avatar
if it is a coil, the shaking wil be all the time and when you are driving you will notice a real bad acceleration and bad noises coming from the engine. You need to look at the engine mounts and tranny mount. I have replaced the mounts and now going for the tranny mount and trust me the shaking is there.....
Lontar1 is offline
Nintensity
08-13-2015 05:41 PM
fastcarny
08-12-2015 03:50 PM
papo99
08-09-2015 07:24 AM
yat70458
08-03-2015 01:16 PM
Quick Reply: 2002 Maxima shakes hard
