gas door actuator
gas door actuator
I just replaced my gas door actuator and my gas door still doesn't pop open. Before, the black nub was snapped off the actuator so I'm guessing the previous owner had problems with the gas door.. Is there some sort of spring or something that I'm missing? Because I'm sure it would work if I kept the button pushed and had someone pry it open.
Had the same issue with mine. Yes there is a spring built into the gas door. I'm still not certain mine is right but I'll try to get a picture later. I ended up buying a new door on ebay (the old one was dented anyway).
Mine would not open unless I hit the putten and pried it open. On cold days I needed a second person. One day I lubed the hinges up pretty good and it has worked fine ever since. Remember, always try the simple solutions before anything else!
Sounds like the door spring is broken. It looks more like a clip than a spring. Mounts on the inside back of the door and pushed the door open when actuator releases.
Part # 78836-AG00A. I purchased mine at local dealer for under $8.
78815P in this diagram (Same part as 6th gen Max as well)
The actuator is just a pin that holds it closed. The door is held in constant tension by that spring. When you pull the release, the pin slides back out of the way. The door springs open on its own. I'll try to get a pic of mine posted up later tonight.
If all you are getting is the spring, buy it at your local dealer. The list price is $5.28. If you order it on line, the price is $3.99 but you'll have to pay shipping charges that could be $8 to $12 on top of that.
http://www.nissanpartszone.com/parts...836-ag00a.html
Originally Posted by tseng1023
Are you sure nismo? That doesn't seems to be connected to the actuator in any way. What are 78810D and 17255N?
I just picked up a fuel door spring at my local dealership for just under $6. They had it in stock and when I saw it I realized I didn't even have one in place.
I don't really know for sure how to properly install it. Can anyone do me a favor and take a picture of their fuel door that is open pointing to the fuel door spring? That would be swell...
well i found me a spring finally... someone is shipping me a whole gas door assembly just got the shipping costs! so if you want the gas door in the color of pic displayed just pay the shipping costs and its all yours.
That's some funny ****. Glad it worked out for you!!!
Changing my fuel door actuator on my maxima 2005
Hello - anyone out there who can give me some instructions on changing my fuel door actuator? These things seem to fail at the most inopportune time. Would really appreciate the info. Thanks
06-06-2017 02:01 PM
REDinLV
10-18-2015 05:31 AM
