Whistling noise.
Whistling noise.
At high idle I have a whistling noise that I can't locate. Its also present under heavy load at higher rpms. I've checked vac lines and they all look good. Ive tried started fluid to see if its a leaking intake gasket but no change on engine speed. Suppose it could be an exhaust whistle but I think it might be the PVC valve. Has anyone come across this noise? It is very hard to locate as its pitch makes it sound like its always coming from somewhere else, regardless of where you are.
foodmanry
09-24-2015 12:02 PM
