Upgrade Reverse Lights??
Old 04-10-2001, 05:54 PM
killrwheels's Avatar
I am looking for the actual size of the bulb needed to replace rear back-up lights........It appears to be a bulb larger than a wedge but exact size is not known....
Someone out their had a Sterling Mist with Blue backups at the Broward Mall (Fl) last weekend....nice !!!
killrwheels is offline
Old 04-10-2001, 07:00 PM
DKNYchinito
there's a new sticky thread above with all bulb info.
Old 04-10-2001, 07:01 PM
DKNYchinito
just checked... its a "super wedge bulb".
Old 04-10-2001, 07:06 PM
I looked at the sticky also......but no number listed for this piece. It appears it may be a w2 but do not want to order until certain as PIAA's are expensive to just throw away.....anyone got the bulb number???
Old 04-10-2001, 08:22 PM
Fastest Fantasy Maxima Evar
IceY2K1's Avatar
Stock is a KOITO 912 which is 12V and 13watt bulb.
I replaced mine with a Sylvania 921LL 15watts from Autozone. It's white and brighter than stock to compensate for my tint at night.
IceY2K1 is offline
Old 04-10-2001, 09:08 PM
yongjun's Avatar
You can use a regular wedge bulb too
but if you are looking for it.
Just look for a wedge bulb with a fatter bulb part
i have a pic here
yongjun is offline
Old 04-11-2001, 01:02 AM
areX's Avatar
careful...
careful about getting the right bulb, tho. i had a friend of mine get me one at Autodynamic's store and he came back with a bulb the same size as the brake lights... TOO FAT. it's the one right in between the 194 small wedgies and the big break fatties. they should be numbered as "921" according to Autooptiks.
search around. if you search, you will find.
areX is offline
Old 08-30-2020, 02:10 PM
Thrillho's Avatar
Originally Posted by Melikos
Yes, the backups are important, but even this measure does not always help.
yo my dude, I don't know how it's on here but on most forums it's frowned upon to bump a 10+ year old thread.
Thrillho is offline
Old 08-30-2020, 04:12 PM
Donkeypunch's Avatar
frowns be damned then.
threads are forever if it helps someone searching for it later on then why not.
Amazon Amazon
i'm using this bulb on the passenger side hit helps a TON when parking and you have tinted windows.
those led ones aren't even close to being as bright.
Donkeypunch is offline
Shannon and Ian
05-18-2016 05:03 PM
Maxima-Ness
31
04-12-2005 07:25 PM
xsp00kyx
04-29-2002 11:44 AM
PejMax97SE
04-15-2002 10:03 AM
block
11-05-2000 09:45 PM
Quick Reply: Upgrade Reverse Lights??
