Is a tap necessary for aluminum
Old 05-20-2022, 11:35 AM
2002SEMT's Avatar
I am installing the (in)famous Mitzone aluminum valve covers. I removed the improper sheet metal screws and intend to buy the correct M4 x 07 machine screws. Is retapping the threads necessary or because it's aluminum, will the new screws themselves correct the thread damage from the improper sheet metal screws?
2002SEMT is offline
Old 05-20-2022, 11:51 AM
I'm nutty for Nissans
JSutter's Avatar
Use a thread chaser if you can find one.
JSutter is offline
Old 07-24-2022, 02:34 AM
mabsarer22's Avatar
Do you have to tap? If you threadmilled you would go through less tools since you can just comp it out further as the tool wears Also curious, what kind of part you working on that has that many holes?
mabsarer22 is offline
Old 07-28-2022, 08:49 AM
2002SEMT's Avatar
I WAS going to get aluminum valve covers. Since the screws that hold the ignition coil seal plate are questionable, I was going to modify it. After careful consideration, I decided to replace the warped plastic valve covers with OEM.
2002SEMT is offline
RaptonX
02-02-2014 05:24 PM
pimpin02max
120
08-19-2007 08:55 PM
Maximeyez
02-04-2004 05:26 AM
kpark
02-07-2002 09:40 PM
Quick Reply: Is a tap necessary for aluminum
