2003 Maxima clutch issue
Old 08-27-2012, 02:23 PM
MaxFiyah's Avatar
hey everyone so i have a issue i believe it is the slave cylinder going bad or the slave has air in it.
1. in the morning the clutch pedal is at the floor and i have to pick it back up to bring it to the normal position.
2. the car will not go into gear when the car is on (meaning i cant drive the car at all
3. when i put it into 1st or reverse b4 i turn the car on it will move
4. when i press the clutch a million times and the pressure i guess builds up it drives like a dream
5. the slave cylinder isnt leaking or anything
6. the clutch fluid is full
7. there are no clutch leaks anywhere
8. the car has a new clutch and master cylinder put in by previous owner.
i just got the car around a month ago and the next day it was like this. i just never drove it since because i was busy and i still have my other car so its sitting.
Also this sounds like a newbie question but i cannot locate the bleeder valve on the slave
a little more info is that it only has 80k on it also it has I/H/E spec2 clutch i doubt any of performance mods can screw my slave but oh well thanks in advance guys!
MaxFiyah is offline
Old 08-27-2012, 02:42 PM
Dubwiser's Avatar
sounds like u have air still left in your clutch line try bleeding it out some more
Dubwiser is offline
Old 08-27-2012, 06:48 PM
Toolie
knight_yyz's Avatar
The breeder is on the tiny slave unit which is on the transmission case. Follow the hose
knight_yyz is offline
Toolie
knight_yyz's Avatar
Damn... *bleeder
wingsfan24
08-15-2015 07:35 PM
MikesChevelle
08-10-2015 10:53 AM
09maxshawn11
08-09-2015 01:13 PM
sc10692
08-09-2015 09:37 AM
Quick Reply: 2003 Maxima clutch issue
