2002 - SE Stock head unit (non bose) audio fading in/out - TAPE ERR as well
Title says it all,
I got the stock none bose setup, and 1. my audio will fade in/out sometimes, and also my casette player is turning into ****. It will play the cassette adapter, switch to the other side, and display TAPE ERR and get stuck, and it comes out a bit later.
My audio is also sounding like crap with the tape. I just ordered a tape head cleaner, so i am hoping that fixes it.
Any clues ? someone said it could be the stock amp in the car going out
Title says it all,
ETA:
This I did not know. Would you mind pointing the audience in the right direction?
Please read the "Bose radio replacement" thread in the audio section.
A LOT of good info in there.
WRONG.
Trip controls will work, you have to ground the brown/yellow wire in the secondary harness (applies to 02+ maximas only)
Steering wheel controls can work, you just need the Axxess ASWC interface module.
Im not wrong I have installed my radio without grounding the brown/yellow wire or a axess aswc interface module I have no trip or volume control but mpg and dte still work.
Sir, you do realize that the REASON your trip controls don't work is because you have not yet grounded that brown wire?
Justin Kroll
09-02-2015 11:06 AM
