atf overfill
Old 07-30-2012, 09:25 AM
alowoner's Avatar
atf overfill
hello, i just changed my atf and in my haynes book it said ti fill up as much as is drained. i drained almost 6 qts. and filled up with same. this seems like alot. anyway, my car seems to be acting strange while shifting. could it be over filled?
alowoner is offline
Old 07-30-2012, 09:43 AM
njmaxseltd's Avatar
Dipstick? It's there for a reason.
njmaxseltd is offline
Old 07-30-2012, 10:08 AM
This.
ChrisMan287 is offline
Old 07-30-2012, 10:49 AM
alowoner's Avatar
yeah i am aware of the dip stick but i cannot get an accurate reading. ran the car for a good 30 minutes, checked it while it was running but the stick is saturated. i guess i really want to know is will an overfill cause my shifting to be abnormal?
alowoner is offline
Old 07-30-2012, 10:51 AM
Amerikaner83's Avatar
overfill is just as bad as underfill, yes.
But if you had no shifting issues before, and put the same amount in, the level is not relevant.
What type fluid SPECIFICALLY did you put in? And how did you do it?
Amerikaner83 is offline
Old 07-30-2012, 12:43 PM
alowoner's Avatar
i used super tech dex/merc III, and just did a drain/fill.
alowoner is offline
Old 07-30-2012, 01:02 PM
Did you shift through all the gears when the car was in the air?
Stupid quetion, but you have an auto, yes?
Old 07-30-2012, 01:37 PM
alowoner's Avatar
yes and yes, first through drive
alowoner is offline
Old 07-30-2012, 01:38 PM
you are also supposed to go in N, R, and P as well...ALL THE GEARS
Old 07-30-2012, 02:09 PM
alowoner's Avatar
yes, did that.
alowoner is offline
Old 07-30-2012, 02:26 PM
Hmm...Don't know what to tell you.
Try going through all teh gears when you're at idle, several times. I've read a few posts that say this could help...
4 speed auto, yes? Did the 5th gen offer a 5 spd auto or was that with the 6th only?
Old 07-30-2012, 02:38 PM
Hella internets
XeroX's Avatar
It could be possible that you flushed some damaged parts from the tranny when you drained out the old fluid. If you have the owners manual it gives you a step by step on how to get an accurate reading. I switched mine to manaul YEARS ago so i cant remember off top
XeroX is offline
Old 07-30-2012, 02:46 PM
alowoner's Avatar
switched your transmission or switched your car from a to m?
alowoner is offline
Old 07-31-2012, 04:24 AM
Finchum's Avatar
not sure if it will apply. but, i suggest lucas slip stop. it puts some friction material back into the fluid so your trans will work a little better.
Finchum is offline
Old 08-02-2012, 10:15 PM
alowoner's Avatar
sahweet!!
thanks for the help!! drained about a quart and a half and it is running smooth!!
alowoner is offline
Old 08-03-2012, 01:37 PM
Hella internets
XeroX's Avatar
Converted from auto to manual.
XeroX is offline
Old 08-03-2012, 02:59 PM
bennuss's Avatar
I have the same problem and also measured exactly what I took out. Cant get a good reading on the dip stick. Any secret to it?
bennuss is offline
Old 08-13-2012, 01:01 PM
alowoner's Avatar
i just researched how much is supposed to be in it. 4 to 5 qrts. since i know how much i put in, i emptied what i needed to. everything is good now. well, till my max totally died. onto the trouble shooting again. not tranny related. could be fuel pump, not positive yet.
alowoner is offline
mclasser
08-23-2015 09:32 PM
max808
12-19-2001 08:40 AM
Maximum Pursuit
09-27-2001 04:31 PM
bill99gxe
05-15-2001 07:31 AM
bill99gxe
03-23-2001 09:36 AM
Quick Reply: atf overfill
