can't raise window up on 2002 maxima
Mine was stuck all the way down, I was able to get a box wrench on the left one, the right one I was able to get to by taking out the speaker and using a box wrench again. It was very small turns at a time and took awhile but got it.
Hard reach on that right side one though, have a magnet handy for when you drop the wrench.
If you just can't get it cut the wires on the regulator then it should freewheel. I assume you motor died, you can get the motor and reg together for not much more than the cost of the motor alone.
Also if you unbolt the regulator and motor that should give you a couple more inches of movement.
Nintensity
08-13-2015 05:41 PM
yat70458
08-03-2015 01:16 PM
