Battery and brake lights on
Old 12-26-2019, 08:32 PM
mithao101's Avatar
Battery is always fully charged .No leaking brake fluid! Car runs fine! Brakes are good! 2000 Maxima SE.
mithao101 is offline
Old 12-26-2019, 08:40 PM
Father of the 00 VI
krismax's Avatar
Is your battery charging? Could be your alternator ,check it with multi meter.
krismax is offline
Old 12-26-2019, 08:46 PM
mithao101's Avatar
Yes! Battery is always 15.65 v. I assume my alternator is working! No problem to start my car sometime after 2 weeks!
Old 12-26-2019, 08:48 PM
mithao101's Avatar
Sorry battery voltage is 12.65 v
Old 12-26-2019, 09:07 PM
Father of the 00 VI
krismax's Avatar
With the car on or off? With it on it should be higher than 12.65 .
And the alternator doesn't just go bad it slowly stops working. People just think that because they wait till it 100% quits.
krismax is offline
Old 12-27-2019, 06:23 AM
Bad *** Newb
Child_uv_KoRn's Avatar
Unless the VRM just pops. But, yeah, usually it's a slow degrade. One of mine **** the bed instantly in 100 degree heat. When you see it dipping into 13s, it's probably not gonna last too much longer.
Child_uv_KoRn is offline
Old 12-27-2019, 06:28 AM
Turbobink's Avatar
Battery trouble indicator + brake trouble indicator = failing alternator (typically).
Turbobink is offline
Old 12-28-2019, 03:45 PM
Shawn33's Avatar
So true, Its is the alternator 100%. The same thing happened to my car, The brake and battery light came on, I Ignored it at first because it went back off, It came on a 2nd time (about 3 weeks later) and it wouldn't accelerate past 10 mph, I turned it off to restart, and it wouldn't start back up. I got a boost, and it started fine along with the brake and battery light going away again. This time it stayed off, and drove fine for an entire year, but then started the same issue .. This time I drove somewhere safe instead of turning the car off, and finally had the alternator and belt changed(600$). It may be my android phone that caused this, since the brake and battery light came on the first time right after using the cig lighter to charge my phone which had a malfunctioning battery.
Shawn33 is offline
Old 12-28-2019, 05:09 PM
User1's Avatar
You should sue Google.
User1 is offline
Old 12-28-2019, 06:51 PM
slvr2KSE5's Avatar
100% this. It was obviously the android phone that's caused all of your problems.
slvr2KSE5 is offline
Old 12-28-2019, 11:35 PM
Shawn33's Avatar
lol
Shawn33 is offline
Pizzyflavin
05-06-2015 10:46 PM
dee.signs
08-03-2014 03:13 PM
PoePoe2797
09-22-2006 02:18 PM
Adam Cramer
07-07-2004 08:58 AM
Autofanatic
01-10-2002 09:43 PM
Quick Reply: Battery and brake lights on
