Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 06-21-2012, 09:01 PM   #1
Points: 2,641, Level: 31
Points: 2,641, Level: 31 Points: 2,641, Level: 31 Points: 2,641, Level: 31
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
2001 Maxima fast idle fix??
Hello all,
I have read through several other threads about this issue with the 5th Gen Maximas. As far as I can tell a lot of us have the same issue with no "real fix." From what I can tell it may be an issue with the ECM? What I was wandering is if anyone here has tried out some of the places you can ship them your ECM and have the fast idle issue fixed and they ship it back. (Ex. www.circuitboardmedics.com) Is this a scam or is it legit? Please help, im tired of having to hold the car on the brakes in stop and go traffic!!
07busawannabe is offline   Reply With Quote
Old 06-21-2012, 11:50 PM   #2
Points: 1,347, Level: 20
Points: 1,347, Level: 20 Points: 1,347, Level: 20 Points: 1,347, Level: 20
Activity: 0%
Is your engine a VQ35 or VQ30? I recently fixed my high idle issue on my '03 (VQ35) and I may be able to help if yours has the same engine.
__________________
'03 Hand-Me-Down with 270,XXX. Pings like a ***** fugga but keeps on going...
Gugs is offline   Reply With Quote
Old 06-22-2012, 06:11 AM   #3
Points: 4,218, Level: 41
Points: 4,218, Level: 41 Points: 4,218, Level: 41 Points: 4,218, Level: 41
Activity: 0%
If you've got a burned chip like I did in the ECU, and that was caused by external component failures or vice-versa, it is the luck of the draw.
In my case, the flaming chip did not destroy the circuit board traces around it.
I was also lucky that I've been in the repair industry for defense, avionics, down to automotive and consumer devices and had the skills and equipment to replace the idle air control valve chip.
The really scary thing on these cars is one component can destroy another one, so you really have to diagnose it.
In my car in addition to the idloe air control valve stepper motor shorting and burning out the (non current protected) controller chip in the CPU, it looks like the chip in the ECU can fail and burn out the valve. Load of crap design...
Also some have had the smart engine mount controller chip fail due to the engine mount shorting, and that chip is near the idle control chip, burning it out with collateral friendly fire.
I haven't been on here in awhile, but this forum saved me close to 2500.00 for this incident. Not counting if brought it to a dealer that might not even have known of this congenital problem at the time.
If you are going to dig into it, here are some steps you can take off the top of my head. Others will jump in for details I presume, as I may not be around.
Check for motor mount problems also, but:
Measure the resistance of the "idle air control valve" motor, two or four windings, , probably 2 center-tapped, I forget. they should read some low value of ohms, I think 4 or so. One of mine was a dead short. Use good meter, and/or a friend who knows some electronics.
Retrieve the computer, was hard for me before really knowing where it was: Think of it resting on the hump, as far forward to the firewall as possible, in your radio stack trim. Then I think I needed right angle screwdriver or nutdriver to get at the mounting bolts. I think they were normal hex/phillips screws, nothing special.
Open the top of the computer in a static safe way, at least not on your lap with a fuzzy sweater on....
Look at the (single in-line package) IC chips, if burned or popped, you should not miss it.
If the valve checks out good, and the chips look good, then maybe you are lucky, and it is something simple.
Any are encouraged to hijack this thread, I don't know when I'll be around..
good luck.
PS, if you replace the computer, I think you have to jump hoops for getting the anti-theft reset, etc. I didn't as I replaced the chip in my existing unit.
jh15 is offline   Reply With Quote
Old 06-22-2012, 01:34 PM   #4
Activity: 0%
thanks for the info. Im going to start digging around tomorrow and see what I can find out. Thanks again.
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
