Worst dipstick ever 02-03 (VQ)
Old 06-11-2012, 09:15 PM
  #41
T_Behr904's Avatar
ya... that system is stupid!
my friends got a '73 911 with an '85 3.2 F-6 and you have to run the car till its pretty warm and them you can get a reading. i thought in '85 they would make a safer system to see if you're low on oil. what if you're low and you in the middle of warming up and something happens as the oil does the cooling and lubing
crazy fun car though... ~250hp in a 2500 lb car
They have a dry sump system which stores the majority of the oil in a tank Once the engine heats up to a certain temperature, a thermostat opens up to start circulating the oil through the system, similar to a liquid cooled car. Once it's warmed up, you check the level with it running at idle on level pavement and can either use the dipstick or the oil level gauge in the cluster. Let your friend know that having the oil level halfway on the gauge is ideal. You don't want to over fill that.
T_Behr904 is offline
Old 12-12-2012, 10:03 AM
  #42
paradiddle's Avatar
dipstick s*cks
I always have extreme difficulty reading the dipstick on level ground after 15 mins or more on my wifes oil chugging VQ35. over night is better but oil must run down from somewhere and coat the stick above the line. My best guess is if I see a dry spot above the bottom and more oil above. My wife can't read it well and has missed some crucial oil refills.
We ran Mobil 1 syn since we bought car with 35K miles every 3-5K and it still ended up as a oil burner. I did the valve covers, PCV etc. no change. I'm running dino oil now but it's really no better and I don't believe any oil or treatment will fix this. It needs rings and you can't always check this if the oil ring is bad but compression rings are good with a leakdown or compression test.
This monster motor is very flawed and should have had a recall but for some reason gives up oil at over 100k. we have 170k now and just buy 5 extra quarts on every oil change as it sucks up about once every 1k. cheapest solution. Now we get p0021 codes and I hear that low or dirty oil can make the chain adjuster stuff funky with cam timing and throw codes. We are just going to run it in the ground for another year and dump it. too bad , our previous 99 Max was great and this has been the opposite.
I have a Ford van with a V-10 and it started using oil at 30K. Dealer told me that 1K was "acceptable" and couldn't fix. I had used the factory motorcraft oil and filter and it still didn't stop the inevitable.
paradiddle is offline
Old 12-12-2012, 10:35 AM
  #43
TallTom's Avatar
Just do it 1st thing in the morning while parked on lever ground. Makes life easier.
TallTom is offline
Old 12-12-2012, 11:11 AM
  #44
dot dot dot ...
NmexMAX's Avatar
Are we done here?
NmexMAX is offline
Old 12-12-2012, 02:50 PM
  #45
MaxinO2's Avatar
I have noticed that waiting a few hours will give you the most accurate reading or over night. It takes a long time for all the oil to drip to the bottom in our vehicles.
MaxinO2 is offline
Old 12-12-2012, 03:00 PM
  #46
select127's Avatar
Pour some cold water on the dipstick and then insert it. One side should give the correct reading.
Learned this back in 05 when I worked my first job at jiffy lube.
select127 is offline
Old 12-12-2012, 03:07 PM
  #47
MaxFiyah's Avatar
mine sucks also but mine comes out dry wtf right lol
MaxFiyah is offline
Old 12-12-2012, 05:59 PM
  #48
Aviation005's Avatar
seems like you did the basic repairs already. it could be your oil pressure sender unit. many leak only while the car is running
i have also saw a blown seal inside the timing chain cover that caused a huge oil burning issue.. this is what i think is causing your issue. do you get chain rattle at cold starts by any chance?
the piece the broke in the timing cover didnt even have a part number.. i will try to find that thread later
Aviation005 is offline
Old 12-25-2012, 11:07 AM
  #49
paradiddle's Avatar
I'll look at the OPS but I'm sure I would have seen that leak. It is getting noisy at cold starts. Haven't had the code in awhile but I will consider this if it becomes a problem. We will stick with the 5 qts between oil change method for now and I will try that cold water trick on the dipstick. Limp another year out of this. I had fun smoking some unsuspecting dudes at a stoplight the other night. at 178k I really don't care now........ ha ha
Old 12-25-2012, 11:13 AM
  #50
Blue Mesa's Avatar
Id be curious to know if there's a correlation between presumed oil consumption and faulty dipstick readings...
Blue Mesa is offline
Old 12-26-2012, 12:19 AM
  #51
joebangaa's Avatar
Originally Posted by NmexMAX
Are we done here?
Can we sticky a post that says "leave car overnight before checking" and lock up all these dipstick threads?
joebangaa is offline
Old 12-26-2012, 09:53 AM
  #52
paradiddle's Avatar
I'm glad that many of you can read a simple thing like a dipstick with ease. I don't know why but I think the engine casting retains some oil and it drips on the dipstick, therefore creating an erroneous reading. some times you can even see a clear gap between the bottom and the drippings. It may be we are dolts but in my case I don't have any problem with ANY other vehicle.
The correlation may have been why my wife thought she had a full oil pan when she checked the stick at fuel up. Later I discovered it was over 3 qts low. I don't know if this caused engine damage and made it into an oil burner or the VQ 35 is at best a 50/50 motor where half of you have no problems at all and the other half put a case of oil in the trunk.
If the dipstick is hard to read you will either miss oil fills or or over fill.....overnight is obviously best. On the road hmmmmmm..... just run it 1-3 qts low until you get home and can wait overnight. ha ha
Old 11-22-2013, 05:03 AM
  #53
Prophecy99's Avatar
sorry to bump, but does anyone know how much a slightly off level grade would effect the reading? could it really effect the reading as much as putting the reading to the extremes ends of the spectrum?
and is it true that when reading the dipstick from High to Low that it gauges 1 quart?
Prophecy99 is offline
Old 11-22-2013, 05:07 AM
  #54
95VQ30's Avatar
Title says it all
95VQ30 is offline
Old 11-22-2013, 06:31 AM
  #55
Get Off My Lawn
Chris Gregg's Avatar
Worst dipstick?
YEP.
[/URL]
Chris Gregg is offline
Old 11-22-2013, 07:33 AM
  #56
D.Stillwell's Avatar
Inserting your stick all the way in, then taking it out quickly gives a more accurate reading (this method may or may not work elsewhere).
D.Stillwell is offline
Old 11-22-2013, 12:54 PM
  #57
02nismaxlegnd94's Avatar
I've had my Maxima for seven years now, and i still cant read my dipstick to this day. sometimes it reads, most times its dry, or the oil is only on the back side of the stick.
02nismaxlegnd94 is offline
Old 11-22-2013, 04:02 PM
  #58
ACee's Avatar
I check mine when the motor is completely cold after oil has had time to drain down out of the dipstick tube.
ACee is offline
derekinthez
11-13-2022 04:00 PM
hcarter1112
42
07-18-2022 03:35 PM
mclasser
22
11-12-2020 01:58 PM
bennuss
09-11-2015 05:55 AM
Quick Reply: Worst dipstick ever 02-03 (VQ)
