help needed - Need a new engine (valve tapping sound)
Old 05-18-2012, 07:34 PM
Amit56's Avatar
So I went to start up my 03 max today and a loud tapping type of sound was coming from the upper part of the motor - more like a loud valve tap or something. After adding about 1.5 qt of oil and the tapping noise died down slightly but its still there. The motor does burn about 2 qts of oil every 3200 miles or so. These issues got me thinking of getting another motor but not sure if its worth it for a car that is almost 10 yrs old. If I do decide to replace it what engine should I get and from where? I was told by a fellow member to get an 07 Altima 3.5.
Anyone willing to help me out Im located in Southern NJ/Philly area?
Help is much appreciated.
Amit56 is offline
Old 05-18-2012, 08:06 PM
maxima672's Avatar
try using some seafoam to free up the rings, but a vlave may be burnt also
maxima672 is offline
Old 05-18-2012, 08:18 PM
cjandura's Avatar
Contact member aackshun he works for a nissan recycler
cjandura is offline
Old 05-18-2012, 09:35 PM
'02 Style's Avatar
You can use most any transverse mounted 3.5 from a ('02-'08)maxima, altima, quest, or murano. Swap over the intake manifold, oil pan, and maybe the fuel rails. Let us know what you decide to use.
'02 Style is offline
Old 05-18-2012, 09:48 PM
Rods03Max619's Avatar
Agreed, and you can also check here...
http://www.car-part.com/
Rods03Max619 is offline
Old 05-19-2012, 05:28 AM
cjandura's Avatar
Aackshun is a much better deal and gives great support the swap isnt bad took me 3 days by myself i got a 06 motor with 15k on it swapped mani,inject,coils,oilpans
cjandura is offline
Old 05-21-2012, 08:45 AM
Amit56's Avatar
Anyone recommends a reputable tech/member to have the motor installed? Contacted couple members but did not hear back from them. I am located in southern NJ/Philly area.
Amit56 is offline
Old 05-27-2012, 12:42 PM
Discipulus96's Avatar
Does it matter if the engine was from a manual or automatic? On car-part.com when searching for engines you have to specify a transmission type.
Discipulus96 is offline
Old 05-28-2012, 06:29 PM
'02 Style's Avatar
If memory serves, it is possible to use either (I don't remember the specifics of what needs to be swapped), but you really want to stay with the same type of engine (auto or manual) as your car is. All I can really remember about that part was that it increased the labor needed (and thus $$$) if you try to use a AT on a MT car or vice versa. Sorry for not being much help in that area.
Old 05-30-2012, 10:11 AM
princeholiday's Avatar
Anybody know where can get reputable person for engine install in bronyx area? or close by.
Also source for securing engine..friend got qupte 1000 for 03 Maxima Engine 87k..but told her kind of hesitant..might be same issue and engine is older than her car which is an 04'
She's tight on funds....
Thanks for help.
princeholiday is offline
Old 06-13-2012, 07:30 AM
Amit56's Avatar
update : ended up having an 07 maxima motor swapped over. Runs and drives like new. Only thing I have noticed is the exhaust is a little bit nosier but I can live with it. Was told the cams maybe a little a different than from an 03 motor which can be the cause of the noise.
Big Thanks to a fellow member "Unklejoe" for the help.
Amit56 is offline
Old 06-13-2012, 09:29 AM
dot dot dot ...
NmexMAX's Avatar
Cams are the same, valve springs are slightly softer.
Cool getting it to work.
Mind snapping pics of the intake manifold, most namely where the VIAS valve resides?
NmexMAX is offline
Old 06-13-2012, 01:59 PM
'02 Style's Avatar
Congratulations! Feels nice having that power back doesn't it? Did you do the timing chains as well?
smplyamzng
12-13-2015 01:19 PM
TonyJr
08-20-2015 12:14 AM
MaximaDrvr
08-19-2015 08:20 PM
doobadoo
08-15-2015 06:43 PM
Quick Reply: help needed - Need a new engine (valve tapping sound)
