Can anyone tell me what wrong?
Old 05-11-2012, 05:59 PM
ezkill89's Avatar
I have a 2000 nissan maxima. Well this is what happens, I might drive it a bit agressive or in high heat and my car starts sticking in 2nd gear and does not want to go past that BUT if I shut off the car while I'm driving and restart the car the problems gone. This to me it feels like its a mechanical problem I just wanted to see if anyone else has had this problem with there 5th gen max. Because everyone tells me that the tranny is good so is the motor but noone can really figure out what the problem is unless its happening, can this maybe be a sensor going bad?
ezkill89 is offline
Old 05-11-2012, 09:36 PM
Coupedncal's Avatar
I think i know what's causing this problem. You are driving with three wheels and your fourth wheel is dragging in front of the car. Don't believe me? Look at the picture you have posted. One of the rims is sitting in front of the car. How do you expect the car to run smoothly this way?
Coupedncal is offline
Old 05-11-2012, 10:18 PM
TunerMaxima3000's Avatar
Mechanical? No, not likely.
Get a transmission flush and/or tranny inspection done by a reputable shop. This will test line pressures, etc.
TunerMaxima3000 is offline
Old 05-11-2012, 10:27 PM
nsnrider's Avatar
sticking solenoid?
possible bad transmission computer?
electrical problem?
bad ground?
just to name a few possibilities.
nsnrider is offline
Old 05-13-2012, 11:01 AM
ajahearn's Avatar
The 02 service manual says for No up shift from D2 to D3 to check the following:
1) park/neutral position switch
2) control cable adjustment
3) shift solenoid valve b
4) control valve assembly
5) vehicle speed sensor
Given that shutting off the car seems to resolve the problem I would start with #3. Since this is the 02 manual I don't know how much applies.
ajahearn is offline
Old 05-13-2012, 07:51 PM
^It's the same transmission but a different speed sensor and throttle set up. So there are differences in those electrical regards.
The physical transmission is the same (auto)
Old 05-14-2012, 02:41 PM
Bad *** Newb
Child_uv_KoRn's Avatar
It was always the solenoids in the 4th gen, I imagine there's a good chance some of that has carried over
Child_uv_KoRn is offline
Forge277
06-13-2016 09:26 PM
BobTX10
10-07-2015 08:43 AM
bigfrank
10-01-2015 12:51 PM
pears
09-18-2015 05:25 AM
Quick Reply: Can anyone tell me what wrong?
