Anyone try Ebay Engine mounts/Shocks ?
My Engine mounts are gone. Car is driving hard due to that problem. I have looked around, and ebay has them at a decent price at $50 per mount.
Front struts are at $100 for a pair for the front. I need mounts apparently and not the struts themselves.
Question is, Has anyone tried them on their 02/03 ? I dont think these mounts are electronic...especially the center and right passenger side one.
Any help would be appreciated.
get the full set from amazon or ebay and you dont have to worry about the electric mount at all just swap it with a regular mount and try to get yourself mounts made for the MT so you can upgrade to ES mounts in the future if you deside to MOD
eBay mounts: yes, have a couple. Still evaluating long term. But seem good and easy/cheap enough to replace if they do fail in a couple years.
eBay struts: NO. Get a known brand. Buy a known brand off eBay is okay, but nothing else......NOT something you want
To try and replace if it blows in a couple years.
I have eBay mounts as well. I poly filled all of them.
From my experience, I have found they are softer compound than the OEM mounts.
Mine were labeled with Nissan Cefiro 2.0, and I would venture to say all the other ones on eBay for the Maxima 5/5.5 gen are as well. What that means is, these are replacement mounts for the 2.0 4 cylinder Cefiro, not a 3.0/3.5 V6. Potentially they are not as robust due to different weight in engines. Just my theory...
Used these when I returned my car to stock and had one minor fitment issue. My front motor mount bracket didn't fit nicely onto the cross member, the fitment was too tight and wouldn't line up with the bolt holes. I basically just bent the bracket "open" a little more so that it would fit. Drove the car around for a couple months with these eBay mounts + inserts, inspected them before selling, and they were in good shape still. Can't complain for the price.
IMO, rtv is too soft to do anything but split and crumble apart the first time you give the car throttle.
You could buy some 80 (or close) shore poly and fill the mounts. That would do something. Filled all four (tranny and motor) mounts on my '89 turbo. But, with the option of installing ES mounts, that would be my suggested course of action if you are looking for stiffer mounts.
Yes. They're pretty much all the same for 95-03.
http://www.ebay.com/itm/95-03-MAXIMA...195d0b&vxp=mtr
re
I think i would cuss regardless. Changing the oil cooler gasket made me cuss.
When you put the jack on the engine, with the 2x4..Do we cross mount with the oil pan...or lift on the transmission
re
I was quoted $140 to have them changed. What do you guys think ? That is labor only. I think the non electronic is better, as it would be less prone to failure.
I am going to try the first right mount myself, but if i am unable to...then idk
No! it not. It's way stiffer than the electronic one, which causing lots of engine vibration at idle, you can even feel it if you rest you hands on the steering wheel. I bought the set which came the front (non-electronic), got installed for about two weeks, but and-up removed and replaced with the electronic one bought from ebay for $75 bucks. Dealer wants $273 for it.
re
If $140 for all 4 of them then go ahead, good deal.
re
Guys,
The mounts came in today. All look good, and all of them were actually listed for Maxima and not cefiro.
I am thinking about changing the transverse mount first. Question is, How does this mount pull out ? I know that the nut is under the body, but how exactly do you pull it out ?
Im trying to look for a how to on it somewhere here....guess there isnt one
londonflu
40
09-25-2015 09:11 AM
ballerchris510
09-11-2015 05:29 PM
