Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendor Directory
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 04-12-2012, 06:54 PM   #1
Points: 7,438, Level: 57
Points: 7,438, Level: 57 Points: 7,438, Level: 57 Points: 7,438, Level: 57
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Trouble Code P1800 - the infamous VIAS solenoid trouble code
2002 Nissan Maxima. Have pulled and erased CODE P1800 several times to verify that it is a legitimate and permanent trouble code. Some folks mention that they are able to repair their VIAS rod which breaks and causes this trouble code, however, this is not relevant to this engine as it has a different VIAS setup. My question for you all is this... how often is this issue resolved by simply replacing the actual solenoid itself?
Thank you.
soundquest is offline   Reply With Quote
Old 04-13-2012, 08:08 AM   #2
Willing to learn
oldngivout's Avatar
Points: 9,397, Level: 65
Points: 9,397, Level: 65 Points: 9,397, Level: 65 Points: 9,397, Level: 65
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Actually that is what it needs, a new solenoid. They don't last forever, and replacement is easy.
If you want to confirm this, just take some jumper wire and power the solenoid up on the bench. It should click on & off when 12v is applied & removed. Polarity is not important BTW.
__________________
Unless you do it exactly like I did, your results may vary.
oldngivout is offline   Reply With Quote
Old 04-13-2012, 08:20 AM   #3
Points: 6,323, Level: 51
Points: 6,323, Level: 51 Points: 6,323, Level: 51 Points: 6,323, Level: 51
Activity: 2.5%
Activity: 2.5% Activity: 2.5% Activity: 2.5%
Get a block off plate and done deal!
__________________
maxima.713 is offline   Reply With Quote
Old 04-13-2012, 02:19 PM   #4
Activity: 0%
you guys are awesome -- looks like I will be ordering a new solenoid. I have read that disabling the system by a block destroys some of the low end power. Any truth to this? IF that is the loss, what/where is the gain? Anyone know who sells this solenoid most inexpensively?
Old 04-15-2012, 08:49 AM   #5
Points: 3,120, Level: 34
Points: 3,120, Level: 34 Points: 3,120, Level: 34 Points: 3,120, Level: 34
Activity: 0%
Courtesyparts.com Nissan
Hi guys, my 2002 was throwing the same code (P1800) 2 days ago, yesterday when I got in the car to go to work, I started her up and the SES light didnt come on?
Does this code just go away? It confused me to say the least...I was just about to order Valve Assy-Solenoid,Valve Timing Control from Courtesy Nissan, do I still need to?
__________________
I love seeing Civics and Scions in my rear view mirror! All hail the mighty Maxima!
deuce22 is offline   Reply With Quote
Old 04-16-2012, 12:23 AM   #6
Activity: 0%
I would not buy it from the dealership, it is waaaay too expensive, like $139 we're talking at my local stealership. I found one online for $39 a few weeks back. Now... if I could only find it again. Anyone?
Old 04-16-2012, 05:39 PM   #7
Activity: 0%
Quote:
Did you order it from Pep Boys , Auto zone...etc? Or was it Rock Auto or another online retailer?
Thanks in Advance
__________________
Old 05-31-2012, 07:45 PM   #8
Points: 1,641, Level: 23
Points: 1,641, Level: 23 Points: 1,641, Level: 23 Points: 1,641, Level: 23
Activity: 0%
Quote:
I have the same P1800 code; a lot of people told to put a block of plate but Whould my SES light come off?
qroundqod is offline   Reply With Quote
Old 06-01-2012, 12:18 AM   #9
Activity: 0%
Quote:
Actually, you guys wont' believe this but the solenoid was not bad at all. THE MAF HAD FAILED AND IT WAS CAUSING A SECONDARY FALSE POSITIVE P1800 CEL FOR THE SOLENOID. So... I replaced the MAF with a genuine NISSAN, year 2000 MAXIMA MAF (a 2003 MAF from a 5.5 gen is 450 bucks vs. only 90 for the 5th gen. Y2K MAF which is 100x better to begin with and does not require idle relearn after installing -- read the DIY post on the MAF swap and it will tell you how to do this and why). Not only did the erroneous error code go away, BUT MY IMPOSSIBLY HIGH IDLE FROM THE THROTTLE BODY CLEAN PROCEDURE AND 60 FAILED IDLE RELEARN PROCEDURES COMPLETELY NORMALIZED TO 650 RPM!!! And... AND...THE CAR FREAKING DRIVES LIKE A BAT OUT OF HELL NOW! I mean it has more pep and torque than day one off the lot. No joke!
This is so important we need everyone to know about it that has a 5.5 gen Maxima. GET THAT STOCK MAF OUT OF THERE AND SWAP IT WITH A GENUINE Y2K! EVEN IF IT IS WORKING JUST FINE!
Old 08-15-2012, 02:40 PM   #10
Points: 2,447, Level: 29
Points: 2,447, Level: 29 Points: 2,447, Level: 29 Points: 2,447, Level: 29
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Where did you find it for $39. I have searched everywhere and can only find it for $150 from the stealership.
chopstic is offline   Reply With Quote
Old 08-15-2012, 02:59 PM   #11
dot dot dot ...
NmexMAX's Avatar
Points: 47,506, Level: 100
Points: 47,506, Level: 100 Points: 47,506, Level: 100 Points: 47,506, Level: 100
Activity: 76.7%
Activity: 76.7% Activity: 76.7% Activity: 76.7%
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
Quote:
If you mean the MAF, here's one for 87.xx$
http://www.courtesyparts.com/22680-m...957_1973_1976&
__________________
03 SE 4AT 257whp/245wtq
95 SE 4AT 245k Miles
08 Pathy LE 5.6
Stuff for sale: 4" intake tubing/FastCat, HID bulbs, HID Fog Kit,front bearingshttp://forums.maxima.org/5th-generat...t-springs.html
NmexMAX is offline   Reply With Quote
Old 08-15-2012, 03:11 PM   #12
Activity: 1.5%
I was looking for the VIAS solenoid
Old 09-20-2012, 05:42 PM   #13
Points: 2,067, Level: 27
Points: 2,067, Level: 27 Points: 2,067, Level: 27 Points: 2,067, Level: 27
Activity: 0%
I was just searching and came across this.....thank you as I am throwing the same codes. Time for a MAF.
vfrpilot28 is offline   Reply With Quote
Old 09-20-2012, 05:49 PM   #14
Points: 10,018, Level: 66
Points: 10,018, Level: 66 Points: 10,018, Level: 66 Points: 10,018, Level: 66
Activity: 5.1%
Activity: 5.1% Activity: 5.1% Activity: 5.1%
Quote:
Good Luck and report back if it helped.....
__________________
http://youtu.be/ZcAj1ffamM8 3'' Cattman Exhaust
http://youtu.be/Icm7djbfUdMR Rev Up Full Cattman
231whp/226wtq
Rods03Max619 is offline   Reply With Quote
Old 10-29-2012, 02:36 PM   #15
Points: 7,140, Level: 55
Points: 7,140, Level: 55 Points: 7,140, Level: 55 Points: 7,140, Level: 55
Activity: 0.3%
Activity: 0.3% Activity: 0.3% Activity: 0.3%
Send a message via AIM to DougAtoms
I've got P1800 too. Bench tested the solenoid with 12vdc and click, click just as expected. Also verified that air flow was properly deverted. Vacuum lines and actuator react as expected. ECM seems too difficult to access to perform voltage measurement at pin 27. Others mention the MAF could be triggering the P1800 code. Where do I get the Solenoid for a great price? Car drives with no noticeable issues. Could this still be a MAF sensor? My previous car (1996 Infiniti I30) had a bad MAF that presented itself with infrequent, brief, erratic performance issue, never with a code or MIL.
DougAtoms is offline   Reply With Quote
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
