How long will a VQ35 oil burner last?
Old 03-12-2012, 05:28 AM
  #41
TunerMaxima3000's Avatar
All good points. I admittedly would do the same, just not on a 3.5 but that's only cause I know better, if you didnt' know they burn oil, then it'd be simple to do as you did.
TunerMaxima3000 is offline
Old 03-12-2012, 06:35 AM
  #42
6spdmax's Avatar
Originally Posted by jviv35
And to OP check every inch of the block for leaking oil (including spark plug wells) and fix it...if you haven't already. Aside from this I fully believe that the switch to rotella t6 5w40 helped with the blow-by. There should have been puddles under my car considering how much oil I lost initially, but instead it just oozed out of my leaky gaskets and bad oil filter o-ring (resulted in random drops throughout my commute). The rest had to go somewhere...and I suspect it went right on by those scoured piston rings and seals. I also threw in a bottle of auto-rx, which is some kind of additive that cleans the engine without harsh detergents to maintain seal integrity. Not sure if it worked on it's own or in conjunction, but collectively they slowed my consumption.
No leaks. Would've found that by now haha. The spark plug wells were the reason I changed the rear valve cover. Replaced it with a gen6 one when I did my spark plugs. I bought the part ahead of time basically expecting it, and sure enough one of the spark plug wells had oil in it.
Gonna change the oil probably this weekend or next, and like I said I'm gonna start tracking the oil consumption more closely now to see how much difference the vc made.
I will use up the rest of a jug of Mobil1 super synthetic 10w30, and top it off with T6. I guess the theory about less blow-by makes sense. The T6 has alot of zinc in it, which probably increases the density at least somewhat.
And of course I always treat the oil and gas with seafoam right before I change the oil.
6spdmax is offline
Old 03-20-2012, 09:01 AM
  #43
Black00MaxSE's Avatar
I don't think I've ever posted in here before but I'd like to chime in. I own a 2004 G35 6MT Sedan. Ran synthetic motor oil in it for 98k miles and it started consuming massive amounts of oil after installing test pipes. 500 miles later I took the pipes off and switched to conventional motor oil.
Here's my update thread on another forum:
http://g35driver.com/forums/g35-seda...oad-*****.html
To answer the OP's question, I've seen oil consuiming engines go more than 250k miles with proper vigilance of the oil level.
Black00MaxSE is offline
Old 05-15-2012, 06:32 AM
  #44
135man
bachina's Avatar
Similar issue on I35 VQ
I had similar oil burn issues, mine did reduce it significantly maybe a quart per 4k miles. YMMV
See link below in another thread
http://forums.maxima.org/8463762-post61.html
bachina is offline
Old 05-15-2012, 12:29 PM
  #45
'02 Style's Avatar
My original '02 engine burned about a quart every 1500 miles. I was fairly diligent about keeping oil in her, and the first engine lasted to just over 290K. Then she blew a head gasket.
'02 Style is offline
Old 05-15-2012, 03:03 PM
  #46
Bad *** Newb
Child_uv_KoRn's Avatar
But that's no fault of the oil burning. so oil burner ftw
Child_uv_KoRn is offline
matts95max
09-09-2023 01:52 AM
Turbonut
46
10-21-2015 08:28 PM
KabirUTA13
19
10-17-2015 02:15 AM
RWCreative
09-21-2015 11:01 AM
Maxima Pride '07
09-12-2015 07:29 AM
Quick Reply: How long will a VQ35 oil burner last?
