How low are you?
Old 02-08-2012, 01:12 PM
cjones450's Avatar
How low are you?
Ok so I have heard through numerous people that after a certain number of inches of a drop the axels start to give issues so how low are you and do u have any axel issue. Reason why i ask i recently purchased coilovers and don't want to start to have issues with axels.
cjones450 is offline
Old 02-08-2012, 01:22 PM
clintb3astwood's Avatar
Dont slam the car and your axles should be fine. I'm planning to buy coilovers in the coming months.
clintb3astwood is offline
Old 02-08-2012, 01:26 PM
tseng1023's Avatar
not low enough. i might start saving for some BC's!
tseng1023 is offline
Old 02-08-2012, 01:56 PM
T_Behr904's Avatar
I'm still rockin' the stock off road suspension.
T_Behr904 is offline
cjones450's Avatar
Buy my tein/tokico combo sell it to u really cheap and there in great shape lol
Old 02-08-2012, 01:57 PM
Grand_hustle17's Avatar
Wtf.... How long have u owned ur max?
Grand_hustle17 is offline
Old 02-08-2012, 01:58 PM
Sig showed my drop but a 1finger gap should more than be enough for the weak axles
Old 02-08-2012, 02:01 PM
cjones450's Avatar
well i plan on being that low
T_Behr904's Avatar
LoL about a year and a half. Right before I lost my job, I was going to buy coilovers at that time when I had the money.
Old 02-08-2012, 02:03 PM
T_Behr904's Avatar
How cheap is cheap? LoL
Honestly, I can't afford to do anything to my car right now other than maintenance work. I'm only working a part time job right now.
Old 02-08-2012, 02:06 PM
Well I understand 1000% I'm jobless too... Never thought I'd be in this predicament....
Old 02-08-2012, 02:17 PM
TunerMaxima3000's Avatar
Impossible question to answer, I hope you understand that right?
In reality, any deviation from stock height will shorten the life of the axels. The lower you go, the lower the lifespan of the axels, it's really that simple. Once the axels are pointing up on the outside (wheel end) when you're sitting still, you are going to be eating axels prolly on a semi-monthly basis.
All that said, I can give you a general estimate for the Maxima, 2" is pretty safe territory, but you WILL wear components out faster. not just your axels either. 1.5" would be very safe/conservative territory. This level of drop would have minimal effects on lifespan of components. Certainly not measurable ones anyways.
TunerMaxima3000 is offline
Old 02-08-2012, 02:35 PM
T_Behr904's Avatar
Never thought that too. I was with my last job over 11 years.
Old 02-08-2012, 06:01 PM
Ghost_54's Avatar
I am on S-Techs with GR2s, drop is about 2.2" on the front & 1.8" on the rear ... measurement from the ground to the top of the wheel wells is 25.5"all around. I have running this setup for over two years with no ill effects on any components.
Ghost_54 is offline
Old 02-08-2012, 06:31 PM
luvlexus101's Avatar
2 years, I'm still not low :P
luvlexus101 is offline
Old 02-08-2012, 06:32 PM
Rods03Max619's Avatar
Maybe a 1/4 higher.....
Rods03Max619 is offline
Old 02-08-2012, 06:50 PM
Originally Posted by Ghost_54
I am on S-Techs with GR2s, drop is about 2.2" on the front & 1.8" on the rear ... measurement from the ground to the top of the wheel wells is 25.5"all around. I have running this setup for over two years with no MEASURABLE ill effects on any components.
FiXeD
Old 02-08-2012, 07:22 PM
I wonder what happened with that raising the motor to save axles when lowered thread.
Old 02-08-2012, 07:34 PM
03VQMAX's Avatar
I'm 25" in the front from floor to middle of upper fender, the same for the rear, axles start to do a slight vibration, nothing major. If you go to the NISFLO meet, you'll see.
03VQMAX is offline
Old 02-08-2012, 09:17 PM
altezzablazes's Avatar
About 25 1/2 all around
altezzablazes is offline
Old 02-08-2012, 09:25 PM
Stock over hurr.
ChrisMan287 is offline
Old 02-08-2012, 09:41 PM
ShocknAwe's Avatar
When I first started in on my suspension about a year ago I did like most people probably do and slammed it. Then I realized it handled like crap and my suspension guru basically laughed at me prompting me to do an overhaul. I have a 4th gen which might vary a little bit in the right ride height but Im a little over 26in for both front and rear and I find this to be a happy medium. I went ahead and bought some HD Raxles ahead of time because its only a matter of time for the axels to wear down and give you problems when your lowered more than about 1.5". I believe the stock ride height on 4th's is about 28.4" IIRC so by my theory anything under about 26" and your more rapidly wearing your components and it certainly doesn't improve handling to over-lower either. As long as you have the right suspension components and with modern CO's then in reality you can go as low as you want if its a "look" kinda thing your going for but your driving will have to become more conservative over speed bumps and the like.
ShocknAwe is offline
Old 02-08-2012, 09:47 PM
Not again..
Old 02-08-2012, 09:52 PM
ShocknAwe's Avatar
I will not lift off my over-lowering is terrible for handling. I think, on a 4th, that anything under about 25" is over lowering unless of course you have those big money CO's which is another case entirely. Your stock ride height? In your sig it looks lowered but I guess its the lip adding a few inches
Old 02-08-2012, 09:56 PM
This is the 5th gen section. My 5.5 sits at stock height.
Old 02-08-2012, 10:11 PM
ShocknAwe's Avatar
I dont know if its possible but the stock 5th gen ride quality actually seems worse stock than the 4th's stock ride quality. In the 5th's I have driven, at about 90mph the suspension gets dangerously floaty.
Old 02-09-2012, 12:25 AM
bryanakaslim's Avatar
im 24 3/4 all the around on bc and i love my ride
bryanakaslim is offline
Old 02-09-2012, 01:54 AM
My axles cry for mercy...
essential1's Avatar
I'm slammed as fawk...
axles sound like they're doing the river dance.
bushings and ball joints are shot.
but the car rides and handles better than any spring/strut combo ive came across. And it looks great.
essential1 is offline
Old 02-09-2012, 04:13 AM
infinimax96's Avatar
Yeah, until your tire rolls off when you hit a bump..
I don't have a 5th gen but my 4th gen sits with a 2.25" drop in the front and 2" in the back. I have smaller tires (205/45/R16) so my car sits a lot lower then some of the guys with 17"+ wheels. I don't have any problems with binding axles, or bad bushings/joints yet. The car has already been dropped for over a year, so I don't see it having any add normal ware at this point.
My buddy's 5th gen has a 1.5" drop all around and doesn't have any issues at all. It's not as stiff as my 4th gen but does give a sportier feel over stock. Honestly I'm not sure what he's dropped on though.
infinimax96 is offline
Old 02-09-2012, 04:20 AM
Any coilover set up will ride better than spring/strut on the 5th gen. Well, pretty much any CO
Shocknawe is right about lowering too much adversely effecting the suspension. On paper, the only benefits to going lower are better COF and lower COG. The adverse effects going past 2" are obvious, suspension geometry gets fcuked, which causes excessive wear and worse handling.
Old 02-09-2012, 05:09 AM
ranmas2004's Avatar
My drop is modest.....I got Eibach Pro Kit with 1.3" drop in front and 1" in back. I have 245/45 18" wheels. Looks great to me:
FRONT:
REAR:
For me I dont like to slam the car down to the ground scrapping ants off the street as I'm driving with the tire all under the fender wall. But everyone has different taste.
ranmas2004 is offline
Old 02-09-2012, 05:10 AM
mrjasonlyrics's Avatar
I'm lowered 1.5 in the front and 0.5 in the rear sitting on 22's,18's and 17's for different modes. No axle or front end issues since i've installed it about 10mths ago. The ride is pretty comfortable but I feel the cracks in the road due to the low profile tires.
mrjasonlyrics is offline
Old 02-09-2012, 05:17 AM
phatboislim's Avatar
vibration all day and didnt care...loved teh look way too much to care about the vibration
phatboislim is offline
Old 02-09-2012, 05:48 AM
321VQ35MAX's Avatar
I am stock height
And when I was on S-techs and Illuminas when I parked next to Shane I thought my car was lifted
321VQ35MAX is offline
Old 02-09-2012, 05:57 AM
Originally Posted by 321VQ35MAX
I am stock height
Old 02-09-2012, 06:03 AM
321VQ35MAX's Avatar
If you want lower, just bag it
Old 02-09-2012, 06:14 AM
You embarrass me.
zero2sixtyZ's Avatar
I don't have proper measurements of the drop, but I'm sitting at a one finger gap all the way around on 245/40-18s. I love the look and stance... and it's easy to drive, handles pretty well (except for the constant shield rubbing on hard turns), etc.
However, axles hate me. Combined with the ES mounts which drop the motor a bit lower, it's obnoxious how many times my axles have been changed. The car does not have proper suspension geometry, and doesn't handle as well as it could. I'm definitely a preacher of function over form now, and will be raising the coils to the highest height which should still give me an inch drop.
zero2sixtyZ is offline
Old 02-09-2012, 06:16 AM
Doesn't that look ridiculous? Those tires are almost 2" lower than normal.
Old 02-09-2012, 08:11 AM
ranmas2004's Avatar
DAM.....all those ants you scraped off the ground and killed when you were driving...should be ashamed.
Old 02-09-2012, 08:15 AM
essential1's Avatar
Yeah, until your tire rolls off when you hit a bump...
3 years later stretching a 235/35 on a 10" wide wheel and have never had an issue with tires. And its my daily, and I drive aggressive as hell.
[IMG]Barney.jpg[/IMG]
[IMG]barney2.jpg[/IMG]
[IMG]barney3.jpg[/IMG]
That first pic is teh sex!
I am stock height
lmao. what he was up against...
Quick Reply: How low are you?
