Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Sign in using an external account
Register Forgot Password?
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 02-05-2012, 07:03 AM   #1
Points: 734, Level: 14
Points: 734, Level: 14 Points: 734, Level: 14 Points: 734, Level: 14
Activity: 5.6%
Activity: 5.6% Activity: 5.6% Activity: 5.6%
Oilpan & rear main seal question...
I recently bought a 2000 Infiniti I30 and its leaking oil. From what I can see I know the oilpan and rear main seal needs replacing. However, I am confused about exactly what I need. Since when I search I'm finding rear main seal set, rear main seal (seal only), and rear main seal w/ housing. I live in Belize and can't get any parts for the car here so I need to import them myself so I just want to make sure I get everything I need. Are these the only three parts needed to replace the oilpan gasket and rear main seal? Thanks in advance.
Lower oil pan gasket
http://www.ebay.com/itm/Fel-Pro-Engine-Oil-Pan-Gasket-Set-/390383719884?pt=Motors_Car_Truck_Parts_Accessories &fits=Year%3A2000|Model%3AMaxima&vxp=mtr&hash=item 5ae4aed5cc
Upper oil pan gasket
http://www.ebay.com/itm/Beck-Arnley-052-3784-Rear-Main-Bearing-Seal-Set-/150627386252?pt=Motors_Car_Truck_Parts_Accessories &fits=Year%3A2000|Model%3AMaxima&vxp=mtr&hash=item 231217838c
Rear main seal gasket set
http://www.ebay.com/itm/Fel-Pro-Engine-Oil-Pan-Gasket-Set-/290660207904?pt=Motors_Car_Truck_Parts_Accessories &fits=Year%3A2000|Model%3AMaxima&vxp=mtr&hash=item 43acb2cd20
dna59 is offline   Reply With Quote
Old 02-05-2012, 07:11 AM   #2
nsnrider's Avatar
Points: 8,058, Level: 60
Points: 8,058, Level: 60 Points: 8,058, Level: 60 Points: 8,058, Level: 60
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Send a message via Yahoo to nsnrider
__________________
My 2k3 Max.
nsnrider is offline   Reply With Quote
Old 02-05-2012, 08:04 AM   #3
Truck Shifting de Turbo
Chris Gregg's Avatar
Points: 14,590, Level: 78
Points: 14,590, Level: 78 Points: 14,590, Level: 78 Points: 14,590, Level: 78
Activity: 17.1%
Activity: 17.1% Activity: 17.1% Activity: 17.1%
Use www.nissanpartsasap.com for best prices. Also, call and talk either to Ray or Wayne. They'll help with shipping.
Chris Gregg is offline   Reply With Quote
Old 02-05-2012, 08:45 AM   #4
Activity: 5.6%
^^^Their website is under construction.
Old 02-05-2012, 09:16 AM   #5
Points: 2,060, Level: 27
Points: 2,060, Level: 27 Points: 2,060, Level: 27 Points: 2,060, Level: 27
Activity: 89.8%
Activity: 89.8% Activity: 89.8% Activity: 89.8%
rear main seals make me angry...Mines been leaking for about a month now. How many oil leaks Ive had? Im not tellin!
__________________
Quote:
Originally Posted by aackshun View Post
Maxima owners, Hard work? Attention to detail? 3 things you rarely find together on this forum.
ShocknAwe is online now   Reply With Quote
Old 02-05-2012, 09:40 AM   #6
Points: 1,810, Level: 25
Points: 1,810, Level: 25 Points: 1,810, Level: 25 Points: 1,810, Level: 25
Activity: 2.6%
Activity: 2.6% Activity: 2.6% Activity: 2.6%
OP you only need liquid gasket for the upper and lower oil pans(Permatex Ultra Grey) is what I suggest. Also the FSM uses liquid gasket.
You need the rear main seal set as well. I do recommend the site chris gave you but if its down then Im sure you can message chris and get their number to call directly(They have the cheapest OEM parts online I've seen.). However you can go to Courtesy's site(http://www.courtesyparts.com/) but prices are a little higher and so is shipping, but both beat going directly to the dealer. I would recommend going OEM when replacing seals especially that RMS. good luck
BigLou55 is offline   Reply With Quote
Old 02-05-2012, 10:50 AM   #7
Activity: 17.1%
1 (877) 758-9852
Not sure if that is toll free. Only number I've got though. Check the site Monday. Either way, Ray will be in that morning.
Old 02-05-2012, 11:12 AM   #8
Activity: 5.6%
It will be too expensive for me to call him from here. So I guess I will just order from courtesy...correct me if I am wrong, but these are the parts needed? The Permatex I can get in Belize.
This comes with the seal in it right and not just the retainer part itself?
http://www.courtesyparts.com/12296m-...e-p-52527.html
http://www.courtesyparts.com/11121-g...3-p-52513.html
http://www.courtesyparts.com/11121a-...3-p-52514.html
Old 02-05-2012, 11:28 AM   #9
Activity: 2.6%
yea that RMS assembly you have the link for should come with the seal.
Old 02-05-2012, 11:31 AM   #10
"I'm just sayin'..."
nelledge's Avatar
Points: 7,191, Level: 56
Points: 7,191, Level: 56 Points: 7,191, Level: 56 Points: 7,191, Level: 56
Activity: 18.0%
Activity: 18.0% Activity: 18.0% Activity: 18.0%
Quote:
Originally Posted by BigLou55 View Post
OP you only need liquid gasket for the upper and lower oil pans...
You need the rear main seal set as well. ...
^^^This is a bit misleading.
OP. You'll need "Oil Pan Gaskets"(lip seals) #11121-31U10 and 11121-31U00, Permatex Ultra Grey per the FSM as previously stated, and "Retainer oil seal, rear"(RMS) #12296-31U20. Verify here.
Personally, I would reseal the upper and lower oil pans before I jump into the RMS. The latter is much more labor intensive. The majority of "my rear main seal is leaking" diagnoses are incorrect. The lip seal is typically what is leaking.
nelledge is offline   Reply With Quote
Old 02-05-2012, 12:28 PM   #11
Activity: 2.6%
nelledge you are correct about the lips seals, just seen those in the FSM(different section that where I thought it would've been)
Old 02-05-2012, 02:08 PM   #12
Activity: 5.6%
Thanks guys. I really am in love with this car and I'm new to the Nissan/Infiniti world so it's nice to have knowledgeable help around. I think I will try just sealing up the upper and lower oil pans since I'm strapped for cash. I still am gonna order the rear main seal though.
Old 02-05-2012, 04:31 PM   #13
Activity: 5.6%
Also does the exhaust have to come out of the way? Should I buy gaskets for that too?
Old 02-05-2012, 07:35 PM   #14
Activity: 17.1%
Would help a lot to get the exhaust out of the way. And crossmember. But that needs no gaskets.
Old 02-06-2012, 09:32 AM   #15
Activity: 5.6%
I ordered the stuff this morning from Courtesy Parts. Only thing they did not have were the 2 exhaust gaskets for the Y pipe only the one in the rear where it meets the rest of the exhaust. So I got the 2 lip seals for the upper oil pan, the rear main seal, the 2 O-ring seals, and the exhaust gasket for the rear for the y pipe. I had also previously ordered valve cover gaskets and plenum gasket, I should have checked here first and got them from Courtesy.
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Advertising - Terms of Use - Privacy Policy - Jobs - Contact Us - Maxima Forums - Archive - Top
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.2
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
