5th Generation Maxima (2000-2003)Learn more about the 5th Generation Maxima, including the VQ30DE-K and VQ35DE engines.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Every time my left wheel makes contact with uneven ground for example my drive way something I'n my passenger-side wheel pops. At high speeds there is vibration I'n the front. Is it the hub or LCA? 6 months ago I hit a huge pot-hole that cracked my rim I'n half and it was the front driver rim that cracked, I have a feeling this has to do with my problem I'm having now.
Every time my left wheel makes contact with uneven ground for example my drive way something I'n my driver-side wheel poops. At high speeds there is vibration I'n the front. Is it the hub or LCA? 6 months ago I hit a huge pot-hole that cracked my rim I'n half and it was the front driver rim that cracked, I have a feeling this has to do with my problem I'm having now.
Hmmm... never knew that it was possible for them to create a pooping noise. However, i've heard popping noises before.
A little joking aside, if you whacked a pot hole that hard to crack your wheel in half, then I suggest taking your car to a reputable shop and have them get in there and give it a good looking over. There could possibly be steering and/or suspension damage.
Probably wheel bearing. So you should get a new hub.
I had a groaning sound from right side. I dealer told me it was LCA. I went to another shop because they could do it for cheaper and they said it was actually my wheel bearing on front passenger side. Basically they had my car on lift and showed me how right tire had a little bit of vertical play when they push on it.
Glad I got a 2nd opinion because if its was for nissan I would have spent money on control arm and still have issue.
__________________
96 Altima (Sold)
91 SE-R (Sold)
95 Max SE (Sold)
03 Spec V (MIA)
02 Max SE (RIP)
04 Max 6spd...what mods?
