New OBX headers are finally in stock, pics with install, questions and comments
Old 01-30-2012, 09:06 AM
02whitemaximase's Avatar
The OBX headers (02-03 Maxima, equal length y) have been out of stock for at least a year. They are finally back as of late December 2011. I am going to install them in the next week or so. For engine performance mods I have the Megan OE-RS catback installed along with berk/apexi intake and 5 piece spacers. I have compiled all of the information needed to get these headers installed correctly.
The headers are going to arrive this Wednesday. I plan on posting a few pictures of them out of the box. I have a feeling that these may have some differences from the past version 3. A few drawbacks for the previous OBX headers is the weak flex section, y-pipe past the collector being a measly 2 1/16” diameter, poor primary oxygen sensor bung placement on the rear bank, and the alignment issues which call for trimming the cross member and rear motor mount bracket. I hope that this newest batch will have addressed some of these issues. I also have a feeling that the y pipe diameter has been changed to 2.5” which is great news.
It has been confirmed! It is about 2.5" for the y pipe.
My first photo is of new OEM exhaust gaskets. Look at the part numbers and order those if you plan on doing a header install on a 3.5. Although you could get away with reusing the original gaskets, I would recommend spending 35 bucks for the peace of mind.
The front (closest to radiator) header measurements are as follows:
Runner length from where it meets the flange to where all three join
cylinder 2= ~10", 4= ~9" 6= ~12"
Prices and part numbers:
OEM exhaust header gaskets $13 each 14035-4W015
OEM cat gasket $8 20692-65J00
Spark plug antifouler $5 each pack made by HELP 42009, 42002
MAF cleaner $7
Energy Suspension (ES) subframe bushings $25 7.1116G
OBX 02-03 headers $350-380 shipped
The purpose of this thread is to display the newest batch of OBX headers. Exhibit how the install goes and post up some before and after pictures and videos.
Please feel free to ask questions or post comments. I will be happy to take requested pictures.
The rear header/y pipe is currently getting the primary bung relocated and a new wideband bung added. I will have them back tomorrow and will amend this post again thereafter.
[/IMG]
Installation Notes
My install went nearly flawlessly minus one heat shield bolt being seized and a secondary o2 sensor not coming out of the old converter. I know these headers are made over seas where quality control is not great. With that being said I think no two sets of headers are exactly the same which means that you may need to trim something during your install. I came a couple of millimeters from having to trim my front motor mount bracket and my rear bracket went on no problem although it was very close. Probably about 2-3 mm from touching and my front bracket is literally 1mm from touching the header. My flex pipe has about 1/4' space from touching the subframe.
As you can see one of the primaries comes very very close close to the front motor mount bracket but it did not require trimming. Although some may be uncomfortable with how close they are, it is no problem. The mount and header will NOT move even though mine are basically touching it does not matter.
The y pipe comes about 1/4 of an inch from touching the sub frame cross member. Again this is not a problem. I have driven it like this enough to not experience any noise and the way I see it the motor really only moves front to back so this tight space does not come into play.
In order for the front primary to have enough wire slack to reach the new header bung you will have to cut the tape holding the group of wires that travels directly over the middle coil from the larger harness that runs along the top of the valve cover. The tape was holding both harnesses together to about right in the middle of the top middle of the valve cover. Easy fix takes one second.
As you can see below the far left plug has to be unclipped from the coolant pipe in order for that primary to reach.
The rear primary wire has to be extended too. From all of my research people here have been saying to cut the primary either at the wire harness and add some wire to lengthen it or to cut the actual o2 wire and extend those by adding wire. Problem is that is can mess with the voltages. The wire is stainless steel which is nearly impossible for an amateur to solder correctly. My method requires NO WIRE CUTTING!!! You need to remove the wire harness cover pictures below and simply separate the o2 wires from the rest of the wires. First you need to separate is from the green plug wires, then you need to slit the right side of the main harness that fees into the back of the plastic box. PLEASE TAKE YOUR TIME!!! Be very careful to cut precisely and slowly. Doing this will give you enough slack to reach the rear primary o2 sensor.
This next pictures shows exactly where my o2 wire is coming out of the main harness. It is wrapped in a black plastic protector. This picture is taken along the firewall from the driver side, so the top of the picture is the passenger side, the bottom is the drivers side and as you can see the top left is the upper part of that black wire harness box. The fattest harness coming from the box is what you need to slit the side of and separate the 02 wire from. My o2 wire is running out of that harness down toward the middle of the picture.
The following picture is of one of my secondary sensors. I have the antifouler setup and as of about 75 miles no CEL. This secondary is the one with a green plug and red wire cover. The wire running above it is actually the other secondary which is the blue plug with white wire cover. I secondaries have different length wires so I recommend this configuration
02whitemaximase is offline
Old 01-30-2012, 09:11 AM
aackshun's Avatar
Take measurements of EVERYTHING!
aackshun is offline
Old 01-30-2012, 09:13 AM
Will do. Can't wait to wrap a string around the primaries and y pipe. It's been too long since I have had to use pie.
Old 01-30-2012, 09:16 AM
cjandura's Avatar
Dont know what you USING a pie to do.but just slapping a ruler across the end of the pipe will measure it just fine.
Wonders if People on the ORG have a strange PIE fetish??
cjandura is offline
Old 01-30-2012, 09:21 AM
diameter=2[c/(2pi)]
rulers are boring
Old 01-30-2012, 09:31 AM
AznRyan's Avatar
I'd use the ruler and eat the pie.
AznRyan is offline
Old 01-30-2012, 09:56 AM
aka UNCDooD
Jason R's Avatar
Very nice! Can't wait for the detailed pics of these headers since i've been thinking about a set for my car.
Jason R is offline
Old 01-30-2012, 09:58 AM
Xpcgamer's Avatar
Thank you for doing this. I spoke with the Header dude at OBX and he told me they where the same. I did ask specifically on the 2 piece vs 3 piece design and he said they where 2 piece. Keep us updated. Was planning on gutting the cats and buying a WS Y pipe but the cost is almost to the price of the OBX. Subbed.
Xpcgamer is offline
schmellyfart's Avatar
Also, why not use a caliper to measure the pipe?
schmellyfart is offline
Old 01-30-2012, 10:02 AM
No caliper in my tool collection.
Old 01-30-2012, 10:05 AM
This is an actual picture of the headers from the vendors posting. That y-pipe looks thicker than other pictures from the old versions.
Old 01-30-2012, 10:08 AM
Xpcgamer's Avatar
Looks promising!
Xpcgamer is offline
aackshun's Avatar
They look like mine.
aackshun is offline
Old 01-30-2012, 01:32 PM
My axles cry for mercy...
essential1's Avatar
Looks just like the set I helped a friend install a while back. I'm willing to bet money that its the same exact design as the previous. Obx is all about keeping manufacturing costs down. Bigger diameter/thicker piping will drive that cost up significantly which in turn will make the price the consumer pays multiply by god knows how much to offset the difference.
essential1 is offline
Old 01-30-2012, 02:41 PM
dnice02's Avatar
Nothing changed. I installed mine last week Saturday. The inside diameter is not 2.5on the y pipe. You still have to relocate or use the next bung down for the rear primary. I still had to grind down the cross member and front motor mount, and take the little cover off of the rear mount. Other than that the install went ok i guess. Oh and its still a 2 piece design.
dnice02 is offline
Old 01-30-2012, 07:27 PM
7speed's Avatar
Thats too bad. I was hoping it would have been corrected because I thought about selling my cattman y to get the obx combo. But looks like I'll just have to keep the ypipe and keep working on this project.......
7speed is offline
Old 01-31-2012, 03:16 AM
CMax03's Avatar
Sell the Cattman and Go OBX! I'll take the Cattman off your hands! You'll awaken out of this dream into a freaking nightmare the day you sell that Cattman for OBX......
S.O.S.;......why change it? It might be even harder to install if they did.......
Good Luck on the install....
Yeah Good luck too all you OBX Lovers.....
CMax03 is offline
Old 01-31-2012, 03:42 AM
a.k.a. STuNtMAN
JonBlz's Avatar
gutted out my cats as well and paired it with a full exhaust and definitely runs hard
JonBlz is offline
Old 01-31-2012, 06:08 AM
TDMIIG's Avatar
I pulled the trigger on a set of OBX headers last night. I'm looking forward to the install (once it gets warmer). I installed a set of headers on my acrua CL-S so I'd hope this isnt too much more difficult. I'll photo document the install. I may get a warpspeed hfc while I'm at it.
TDMIIG is offline
Old 01-31-2012, 06:53 AM
dnice02's Avatar
I kinda miss my gutted cats. I didn't really notice a power increase going from gutted cats to headers. But it could just be me.
dnice02 is offline
Old 01-31-2012, 07:28 AM
cjandura's Avatar
looks like the same design as the ones i got last year.ended up smashing them on the ground and slinging what was left across my driveway after 6+ hours of fitment issues.
cjandura is offline
Old 01-31-2012, 07:30 AM
ranmas2004's Avatar
Nothing against OBX but I just consider it poor engineering if you claim this part fits and people have to cut and grind pieces off their car just to get it to fit. Thats unacceptable! they have been selling these things for years and STILL have not improved them??? I'm sure many people have let them know and they REFUSE to make improvements.......thats just horrible. As I said nothing against people who have OBX headers and they may perform great once installed, but purposely not changing your product after you know there are serious fitment issues is just terrible.
ranmas2004 is offline
Old 01-31-2012, 08:58 AM
They don't have much incentive to change the headers since people are still buying them with the issues.
Old 01-31-2012, 09:12 AM
ShocknAwe's Avatar
GL on the install. WHen a friend ordered the pair we took a look at it and just sent it back. They aren't exactly Ebay cheap and you should NOt have to do all this modding and grinding to make them fit. Even if they changed the design the cost would go up as others said and who knows if they would even fit better? maybe even worse. They aren't a bad product and certainly show gains in WHP and torque but they need to be redesigned as far as fittment goes. They know of the issues, as I as well as hundreds of others have told them and they haven't corrected a damn thing which is far from good business. I lucked out and found a Cattman which is far from the norm and the install went as it should for a pricey item. We are stuck with OBX now as Cattman slips into the abyss.
ShocknAwe is offline
Old 01-31-2012, 09:52 AM
aackshun's Avatar
I understand the CHEAP part, but not the lazy part because you spend all that time grinding, welding, cutting, splicing, rearranging installing those things in about 1/3 of the time Cattman's would have been on already.
It took me 10 minutes w/ a sawzall and dremel.
aackshun is offline
Old 01-31-2012, 09:55 AM
cjandura's Avatar
Originally Posted by aackshun
You guys are cheap and/or lazy.
#Imjustsayin.
NO! just Old and inpatient! oan i would do all the modding before trying to install first get 2 new O2 bungs and have them welded 90* from their current location then plug the orignals also i would get a small 4" long good quality 2.25" lined flex section and cut the rear header off and install the flex to better aide in movement and alignment.but thats just my opinion from what i went thru.
cjandura is offline
ShocknAwe's Avatar
#Imjustsayin.
Just cheap lol. If I pay for a direct fit product it should be direct fit, not half *** fit with some mods. If Cattman can do it then OBX can do it. Not like it would take a million dollar research team to fix it. They probably have the issues with pictures in their inbox as we speak because EVERYONE will have these issues when they install them. I helped another friend install them who didn't care that it would take longer and it took us about 6hrs to do it with quite a few smoke and beer breaks mixed in. Not HARD per say other than the obvious difficulty with the rear header but just unnecessary for a product thats marketed as direct fit.
Old 01-31-2012, 09:58 AM
aackshun's Avatar
I didn't relocate them, I only have two o2s
Just extended the wires on one.
Lets see....
Extended Wires ($5)
Took a sawzall and dremel to the xmember (upon initial initial install I did not have clearance issues but then I got the solid mount and then I did). ($meh)
Brought two oil drain bolts from lowes ($5)
Had a new Flex Section Welded ($80)
OBX Headers Shipped + Mods = $470, and I got them after 3 business days.....
Happy OBX customer here.
Sure.... WHEN you pay for direct fit. In OBX's case, you did not, so your point is now moot.
aackshun is offline
Old 01-31-2012, 10:02 AM
cjandura's Avatar
I would of modded mine to fit but the damn header flange broke at the center exhaust tube but then again i was fully fustrated and think 80's heavy metal guitar smash as a picture of what i did to them.
cjandura is offline
Old 01-31-2012, 10:08 AM
Let's not turn this thread into another OBX v. Cattman pissing match. I created it to post new numbers and answer any concerns regarding this latest batch from OBX.
Old 01-31-2012, 10:25 AM
dot dot dot ...
NmexMAX's Avatar
We thank you for the info you've already provided and look forward to the install.
This thread might need a clean-up.
NmexMAX is offline
Old 02-01-2012, 11:44 AM
Great news. Just got the OBX headers in. I took a ruler to the y pipe outlet and the pipe diameter is just about 2.5". Maybe a sixteenth short. I will post pictures after work.
GREAT NEWS!
Old 02-01-2012, 12:29 PM
CMax03's Avatar
Honestly,...... Sometimes you'll need to make adjustments when modding that's what aftermarket performance parts bring to the table these days! My hats off to those willing to install OBX and conquering all the obstacles that you're faced with! I've install many different brands of headers and every single one of them have something you have to do to make them work or fit properly....So it separates the real technicians/mechanics from the not so talented weekend warriors! I think what everyone needs is, to have a plan and stick too it, make whatever adjustment you need to make your headers work flawlessly and be happy.....Words of wisdom from believe it or not CMax03!!!!!!
CMax03 is offline
Old 02-01-2012, 05:09 PM
cjandura's Avatar
Your really going to want to relocate that front O2 sensor because with the extra length of the anti foulers it might just poke the rad.
cjandura is offline
Old 02-01-2012, 05:14 PM
antifoulers are only for the secondaries which do not exist on the front header
Old 02-02-2012, 02:24 AM
CMax03's Avatar
That's not necessary!!!! the primaries stay active so plug in bank 2 (front) and bank 1 need to be lenghtened to plug into the next plug downstream from the rear manifold O2 bung! Plug that rear O2 bung facing the firewall and plug the Bank1 primary in the next O2 bung, keeping the secondaries plugged but placed either under the engine cover or battery tray.....then installing a dual circuit O2 Sim.......
CMax03 is offline
Old 02-02-2012, 07:20 AM
TDMIIG's Avatar
To add to that, it would be nice if they had a "non-fouler" with a y split that allowed you to plug two o2 sensors in to one bung. Then you could plug the primary o2 bung on the rear collector, plug the primary in to the first bung on the y pipe, and plug both secondaries in to the last bung (using the y-split non-fouler thing). Everything would be plugged in and with the o2 sensors out of the direct exhaust stream, maybe no SES light and no need for simulators. All speculative of course. Anyone with some fab skills could make one and test (I'd be a willing test subject ).
TDMIIG is offline
Old 02-02-2012, 07:33 AM
This certainly would work but I am trying to get around the sim route. Sims are very hard to come by and by using the antifoulers it would be much cheaper than a sim.
Old 02-02-2012, 02:19 PM
TDMIIG's Avatar
http://www.ebay.com/itm/OBX-Exhaust-...item1c236c8e2e
Free shipping and $349. Just thought I'd share (I just paid 379 shipped )
TDMIIG is offline
Old 02-03-2012, 07:22 AM
iBURN's Avatar
Does anyone know if the new 02-03 OBX headers fit the 2000? I'm guesging they will with slight modification, but it's not like OBX's are known to drop right in.
iBURN is offline
Quick Reply: New OBX headers are finally in stock, pics with install, questions and comments
