Thermostat Replacement Write- Up
Hey Guys since I have not seen a thread like this and thought maybe some nOObs will like to have something like this. This fix is not hard be prepared to get dirty.
Tools Needed:
1. Small Ratchet set with a swivel head. (Preferably) 10mm
2. Pan or something to catch the coolant.
3. Pliers
4. Flat Head Screwdriver
5. Flashlight
Step 1: Let your car cool down. DO NOT open the cap while the engine is hot.
Step 2: Take off the radiator cap. Once the car is cool unplug the coolant reservoir.
Step 3: Start to take of the 2 hoses attached to the T-Stat. You will need the pliers to take off the clamps and a flat head to slide off the hoses.
***** There are 2 ways to do this you can either flush your coolant
or do like I did and just open up the hoses and catch all the
coolant in a pan underneath the car.*****
Step 4: Remove all the bolts holding the T-Stat in.I believe there are 3. This is were the ratchet comes in. It really would be good if you have a smaller set with a swivel head.
**** The Third Bolt is under this elbow****
Step 5: Take out the T-Stat and replace with new one and the new gasket dont forget to put a lil sealent on the gasket. A new OEM T-Stat on ebay runs for about $25 Bucks shipped.http://www.ebay.com/itm/NISSAN-MAXIM...item35b40ab64d Installation is the reversal of removal.
Step 6: Refill your radiator. If your coolant has bits and lil pieces of trash pour new coolant in. You dont want that crap in your engine.
Step 7: Turn the car on and blast the heat. Check for leaks.
Tools Needed:
3. Pliers
5. Flashlight
dont forget you have to bleed the system, even if you just replace the thermostat and lose ~1L of coolant
other thing is clean around the thermostat housing where the gasket mates to the surface with a razor blade
True. Sorry I forgot...just thought those were a given. Lol
Originally Posted by JonBlz
lol you will be surprised
Stickied.
http://forums.maxima.org/5th-generat...n-how-diy.html
This is a great post and it saved my **** back in May... I would go a step further and say that a swivel head for the ratchet isn't just recommended but that it is absolutely necessary. The bolt underneath the elbow is nearly impossible to get to otherwise.
le sigh, nubs gonna nub
I had to use a combination of shallow/deep sockets and a tiny extension I had laying around to get all of the bolts.
TravisCadello
61
02-22-2021 07:35 AM
OhOhMax
06-03-2010 10:00 PM
maximus_pr
08-29-2004 10:58 AM
