OE Muffler Internal Pictures
Old 12-08-2011, 07:35 PM
cjandura's Avatar
what i'm looking for is any pictures of a oe muffler cut open.what i'm upto is I found a supplier of SS muffler parts to build your own custom units.so to do that i would need to see how the oe unit is designed inside and hopefully build one so i can get rid of this darn Megan drone and once again enjoy driving the car.my plans are to build it oe style with a 2.5" in and dual 3" out and the way i see it the parts list they use for a basic example only comes to about $55 and plus I get the satisfaction of saying hey I built that(if it sounds good).
cjandura is offline
Old 12-08-2011, 07:47 PM
T_Behr904's Avatar
I remember seeing a thread on this once. I did some Google searching and that's how I came across it. The mufflers are a variable capacity design. At low rpm, the exhaust flows through one set of pipes, then at higher pressure, a flapper valve opens and it flows through both tailpipes. I'll see if I can find it...
T_Behr904 is offline
Old 12-08-2011, 07:50 PM
T_Behr904's Avatar
Found it!
http://forums.maxima.org/5th-generat...r-exposed.html
Old 12-08-2011, 09:52 PM
That's Mr. Detail to you
Scottwax's Avatar
Looks similar to how a turbo muffler looks inside, but turbo mufflers have larger internal tubes, usually only 3 and some sort of deflector to guide the exhaust flow into the next interior tube. Still, for an OEM design, it appears to have decent flow potential.
Scottwax is offline
Old 12-08-2011, 10:03 PM
cjandura's Avatar
Thanks for the find.i must of not been using key words when i searched.wonder where i could find that flapper at?
cjandura is offline
Old 12-08-2011, 10:55 PM
Rods03Max619's Avatar
That looks wicked....Nice Find...
Rods03Max619 is offline
Old 12-09-2011, 06:55 AM
^ Jeff™
MrEous's Avatar
One key to getting rid of drone is to get any kind of muffler that isn't a 'straight through' design.
MrEous is offline
Old 12-09-2011, 07:06 AM
CMax03's Avatar
That Oem muffler is good up to 247 whp IIRC......My 1/4 mile 60 ft times have always been awesome with the OEM muffler, it appeared to outflow the capabilities of an INJEN Intake I once ran.....I laid down repeated 2.1 sec/60ft with an 4AT and 18" wheels....
CMax03 is offline
Old 12-09-2011, 07:16 AM
luvlexus101's Avatar
I've heard these varex mufflers are good but idk personally.
http://www.youtube.com/watch?v=K7jGYnhbQQU
luvlexus101 is offline
Old 12-09-2011, 08:48 AM
^ Jeff™
MrEous's Avatar
Sorry not sure what that had to do with what I said...but the OEM is an example of what I was saying to get.
MrEous is offline
Old 12-09-2011, 09:24 AM
T_Behr904's Avatar
That actually looks interesting. Porsche's for a while now have used something very similar with their optional sport exhaust systems, mostly found on the 911's.
Old 12-10-2011, 07:06 PM
gatsugansu's Avatar
that's why only one of my tip spews steam when warming up in the morning. I've always wondered if one was clogged.
gatsugansu is offline
Old 12-10-2011, 07:10 PM
T_Behr904's Avatar
Mystery solved
Old 12-11-2011, 02:51 AM
ranmas2004's Avatar
Wonder what the inside of the cattman muffler looks like.....
ranmas2004 is offline
Old 12-11-2011, 05:10 AM
TunerMaxima3000's Avatar
OP: The G35 Sedan muffler will mount with very little modification, it's stainless, has the Variable Valve, and is 2.5"
It also has some nice looking dual polished tips.
I have one in my basement but shipping would negate it for you I think.
TunerMaxima3000 is offline
Old 12-11-2011, 07:19 AM
cjandura's Avatar
Thanks Tuner is it a OE infinity muffler or a aftermarket?i might just get one for the interm until i can piece together the parts and time to build my own.
cjandura is offline
Old 12-11-2011, 07:29 AM
OEM.
Only downside is they're heavy as *****.
I also have a Cattman 2.5" Axel back sitting in my basement doing nothing.
Old 12-11-2011, 07:54 AM
T_Behr904's Avatar
OEM.
How much heavier is the G sedan muffler compared to the factory Maxima muffler?
Old 12-11-2011, 03:32 PM
I don't know how heavy the Maxima muffler is, but that G sedan muffler amazed me, I wouldn't be surprised if it's 50 lbs.
Old 12-11-2011, 03:46 PM
T_Behr904's Avatar
Jeez... that's a big hunk of metal
Old 12-11-2011, 05:04 PM
Yessir. I can't imagine that it's heavier than the Maxima muffler though.... if it is I'm sure it's not by much. Probably very close to the same muffler, the dimensions are quite close I think if not the same for the body.
Old 12-11-2011, 09:10 PM
I'll get the weight of one sometime this week when I swap out stock for my Cattman...I don't think it is 50lbs though, I know stock Headers, precats and y pipe and main cat weighed a total of about 55lbs give or take a pound vs Cattman Headers which on box says when shipped 30 lbs.....and Fastcat don't know the weight say 5lbs ....
Old 12-12-2011, 05:47 PM
Sick weigh one, I have one loose so I can weigh it too once I get a comparative number!
Old 12-12-2011, 05:52 PM
Come on Matt hack open that g muffler and give us all some pics
Old 12-12-2011, 06:23 PM
Yeah should have it by Saturday, rained today in Cali so I should have it on by sometime this week....Need More Power....
Old 12-13-2011, 09:08 AM
Actually, that's the whole reason I have the muffler, I was supposed to do that for the G35driver guys.... I've been so swamped with work, switching jobs, christmas, etc, and now the new car that I haven't had time to do it! And now I don't work where there's a welder anymore so I can't weld it back together after hacking it apart.
Old 12-13-2011, 02:24 PM
I'm assuming this guy has to post a thread on something he likely didn't research. I await his thread.......
Old 12-13-2011, 02:35 PM
cjandura's Avatar
Tuner if you have a harborfreight around you they have them on sale less then $200.not the best quality like a esb but it will get you thru the small projects.
cjandura is offline
Old 12-13-2011, 02:42 PM
Thanks for the HU, but none around here. If/when I get one I'll get a good one. All awaiting a new house with a garage, no where to use it really now anyways. It's too cold to weld outside and I obviously can't do it inside my house LOL
Old 12-17-2011, 10:07 AM
A TunerMax I got 25.5lbs for a stock muffler, my Cattman said about 24...just threw them in a basket and put on a normal scale but I always put the 25lb dumbells to make sure its on the money...What did you get....
Old 12-17-2011, 10:51 AM
cjandura's Avatar
Ok so i have been researching a few options on this custom muffler build and need some input.so from a review i have 2 options on the case design.first is a single outer shell with internal baffling materal or a inner and outter shell with sound damping between the shells with inner baffle materal.so many damn choices after talking with the supplier but he did explain that the number of internal chambers and pass thu pipes determins output sound.
cjandura is offline
Old 12-17-2011, 12:54 PM
Hmmm sounds like the G muffler weighs more, suprising. I'll have to get back to you my man I'll weigh them tonight!
Old 12-19-2011, 09:33 AM
Wow I was really shocked, but the G muffler only weighs 22.5 lbs
Seemed much heavier..... guess that just shows how much I suck at judging weight!
Old 12-19-2011, 10:07 AM
Damn that's pretty nice, when I grab them they don't really feel heavy at all....
Old 12-19-2011, 11:34 AM
^ Which way to the gym Rod?
bigfrank
10-01-2015 12:51 PM
MichMaxFan
09-30-2015 09:18 AM
Quick Reply: OE Muffler Internal Pictures
