Spray Can Paint Job
Old 11-30-2011, 11:23 PM
  #41
bocian's Avatar
Damn! That is impressive. Got to admit like some other people here that when i saw the post, i thought, this should be good, i was expecting a total screw up but it looks like a professional job, congrats man! Now have a beer dude!
Update us with pics of it on the car, very curious.
Btw, did you have some decent exerience with painting prior to this job? Something tells me you knew what you were doing much more than most of us...
bocian is offline
Old 12-01-2011, 02:38 AM
  #42
zzmmrx0xmzz's Avatar
WOW that is amazing! What did you use for clear coat?
zzmmrx0xmzz is offline
Old 12-01-2011, 04:56 AM
  #43
ColtMax's Avatar
Thanks for the props! As far as experience with paint goes, I did spray a few things over the years, but this is my first attempt with such a big piece and also my first trial in achieving a great finish.
No secret, read the can and execute as written: 8 inch away from part, constant speed, 25% overlapping, thin coats, 5-10 minutes flash time cure between layers.
Ill go and heat the garage this morning to start reassembly. Will keep you posted!
ColtMax is offline
Old 12-01-2011, 05:01 AM
  #44
ColtMax's Avatar
As mentioned earlier, this is the clear i used.
http://www.proformproducts.com/en/pr...=94&category=8
ColtMax is offline
Old 12-01-2011, 05:43 AM
  #45
mrjasonlyrics's Avatar
Just when you thought you seen it all. I gotta rate you for doing such a creative thing and getting an amazing outcome. Keep up the good work man.
mrjasonlyrics is offline
Old 12-01-2011, 06:56 AM
  #46
ColtMax's Avatar
As mentionned to mrjasonlyrics in privates, The secret is really in the wet sanding of your primer coating. Primer is usually thick and will buld up into imperfections, this characteristic has a tendency of orange peel. so this is why you need to we sand it. Look at videos on youtube.
For the coating, thin layers, and dont worry if it looks dull at first. dont shoot from too far. 8 to 10 inches is ideal. By putting many thin layers you wil ensure an even coating and acrylic clear will melt a bit te previous coat, so it will tend to flatten out any imperfection on its own. In the end, since you have put many even layers wet sanding the clear will not be a problem and you will get a deep and profesionnal finish.
ColtMax is offline
Old 12-01-2011, 07:35 AM
  #47
TunerMaxima3000's Avatar
Just make sure to buy sandable primer, fills scratches much better too.
It helps to paint match your primer as much as possible too, that way if you do get a scratch in the main paint, it's not as noticable later. Helps with overall richness of the colour and blending as well.
TunerMaxima3000 is offline
Old 12-01-2011, 07:30 PM
  #48
ColtMax's Avatar
No progress pic yet, but Santa came by today....
ColtMax is offline
Old 12-01-2011, 10:00 PM
  #49
WhoDatBuuL's Avatar
WOW !!! thas damn good
WhoDatBuuL is offline
Old 12-02-2011, 03:23 PM
  #50
crazy97's Avatar
Well the Max had this rust spot on the right fender forever. Because I have not repaired it in time, it got to a point that no repair was possible. I called Napa and a new fender was only 75$.... Since I was going to do a bit of body work, I thought it was a good time fix the broken and scratched bumper as well.
As I cant do nothing half way, I ordered new fender liners, new engine splash guards, (some were missing). All bolts, clips, and brackets to do the job were also ordered from Nissan.
I dont have access to a reliable compressor for shooting paint properly so I decided to follow the advices from the paint rep of the auto parts where I usualluy go to. He suggested to use spray can, Well the result is impressive! The primer coat was wet sanded and 3 coats of clear were applied.
I also built a semi-paint booth with a ventilation panel made of two bathroom fans blowing into 3inches flexible tubes in order to withdraw gases outside of the garage.
Here are some pics:
How good does that heater in your garage work?? Nice work btw
crazy97 is offline
Old 12-02-2011, 04:17 PM
  #51
GreekMaxima's Avatar
what a great work!!!!!! you need to open a paint shop lol
GreekMaxima is offline
Old 12-03-2011, 01:23 PM
  #52
TigerMax's Avatar
Can you do mine??
TigerMax is offline
Old 01-22-2012, 04:38 PM
  #53
ColtMax's Avatar
That heater works fairly good. In a -10 celcius weather it heats up the garage to about 65 farenheight in 1.5hour. My garage is not so well insulated.
As far as the body work goes, I managed to complete the job! Finally! Looks great! Color matches perfectly and finish is not so bad. after a wet sanding and a compoud it will be very good. I have been riding in cold weather and salt for the past 2 weeks. No sign of crack, dent, chip or peeling.
ColtMax is offline
Old 01-22-2012, 05:48 PM
  #54
tseng1023's Avatar
Very impressive, it actually does match perfectly! I am going to have to try a spray job on my lip soon! How long did this take you with the prep work?
tseng1023 is offline
Old 01-22-2012, 05:51 PM
  #55
s1mply_v's Avatar
Merlot FTMFW
I tried spray can painting once.. It looked great too, but it didn't last for a year.
s1mply_v is offline
Old 01-22-2012, 05:52 PM
  #56
ShocknAwe's Avatar
Thats really creative lol. Good for you and it turned out relly well.
ShocknAwe is offline
Old 01-22-2012, 06:27 PM
  #57
I'll be a hater for a minute. That looks aweful in that pic. I do hope it's just the glare or a great deal of dirt, but it looks faded, sunbleached and uneven on the bumper.
Originally this looked incredible so I'll assume it's a bad picture, well, hopefully.
oh, and just to put the bug in your brain, if you plan on selling this car anytime (I'd do it regardless), you might want to consider sandblasting and painting the rest of the trim and cowlings. It seriously looks like the front of the car was crunched and someone threw new parts at it. No one would believe you if you said you replaced them cause they were worn looking or something. Sorry if I seem critical it's just the first thing I though when I saw it.
OAN: Have you ever thought about painting your headlight housings Merlot?
Old 01-22-2012, 09:18 PM
  #58
luvlexus101's Avatar
I kinda agree not to that full extent though. The sheen/gloss is somewhat off. Looks a little orange peelish or something. Did you try cutting with 2000 grit and polishing OP?
luvlexus101 is offline
litch
123
01-04-2024 07:01 PM
04-16-2020 05:15 AM
06-06-2017 02:01 PM
doctorpullit
03-29-2016 11:08 AM
REDinLV
10-18-2015 05:31 AM
Quick Reply: Spray Can Paint Job
