My newest protoype
Old 01-08-2012, 07:47 AM
  #401
Toolie
knight_yyz's Avatar
Originally Posted by BobPezz
From the pictures; It looks like the problem is the AT body mount bracket is narrower than the MT body mount bracket. Due to the tabs that interfere with the angled part of the Wrayth urethane bushing. As soon as I get the time I'll take off the airbox, get out my calipers, and give you measurements. Bracket width, pin length, bushing lengths etc.
I understand that the auto chassis bracket has tabs to be removed. But it does not make sense to me that a pin which is 86 mm long can fit in the chassis bracket, but the bushings and mount which are also 86mm don't even come close to fitting. Something isn't right, and i can't wrap my brain around that. If the pin is 86 mm and it fits into the chassis bracket, then the chassis bracket must be at least 86mm wide. If the transmission mount and the bushings are 86mm wide then it should fit like a glove. That's all assuming the tabs have been removed.
knight_yyz is offline
Old 01-08-2012, 07:48 AM
  #402
TallTom's Avatar
Originally Posted by 02whitemaximase
I do not have the es inserts.
Your description of the mount is the same as when I installed the ES Torque Mounts. After driving it hard for a few days, they softened up a hair and now they are hardly noticeable. Hopefully your new mount will do the same.
TallTom is offline
Old 01-08-2012, 08:15 AM
  #403
02whitemaximase's Avatar
Originally Posted by JonBlz
02whitemaximase I sent you a pm
I will keep you in mind. Right now I'm actually contemplating installing the remaining mount especially since the six speeds seem to not encounter the same fitment issue chris had. I'm waiting to feel if the current mount will "settle in" and change with a little time.
02whitemaximase is offline
Old 01-08-2012, 09:19 AM
  #404
luvlexus101's Avatar
Unless its not actually 86 mm wide and the mount spreads it apart a little bit? Idk but even installing a stock mount I always use a pry bar to line it up as I raise the transmission from the bottom.
luvlexus101 is offline
Old 01-08-2012, 11:09 AM
  #405
Toolie
knight_yyz's Avatar
On a side note it looks like the damn tow truck did almost as much damage to my car as the frikkin idiot who rammed me! My front passenger wheel bearing was toast, 120cdn to replace, my front control arm is damaged, (the part the king pin holds is oval right now) and my side skirt is crushed in at the front wheel well. Looks like he didn't line everything up before he rammed the axle cradle under the front wheels, and it looks like my front bumper is sagging. My front engine splash shield is ruined, and the side engine shield that protects the pulleys and oil filter is gone...
Old 01-08-2012, 11:34 AM
  #406
Get Off My Lawn
Chris Gregg's Avatar
Sorry been away, kids and all!
No, I do not have the ES bushings, but I have replaced my front electric mount (again, I am auto) for a manual transmission front mount. Also, I know cars and engines are different, but I have all four mounts on my '89 turbo poured solid polyurethene and it has significantly less vibration and cabin noise than my 2003 with both Wrayth mounts. I would suggest though, there is a reason Nissan went with electronic mounts on the auto version of these cars! Clearly at idle they are prone to crazy vibration which ecos into the cabin.
I want to be clear, my comments are not intended to degrade the quality of the Wrayth mounts.....I hope I've already mentioned my positive thoughts and impressions of the product. I also want to say that these mounts were originally designed just for the engine mount...that aside from matching the measurements, Ray had no access to further R/D on actual cars, specifically not an auto. So, I knew it was a chance from the get go.
Now, I've looked at this again. Although I couldn't put a ruler to it at the time, I am certain that the body bracket on the car is angled. To clarify, it looks like the bracket is wider where it receives the mount and pin than where it is welded to the body/frame. As solid as the Wrayth mounts are, any reduction in width is going to make it difficult to push the inserts into place. I will try to confirm this visual observation, but if anothe auto is out doing the install, I'd hope they go ahead and get measurements at the tip and at the frame to verify if a difference actually exists and to what extent.
I want to also again mention, I strongly believe a great deal of the vibration and noise is becuase of the amount of contact/how firm the inserts push against the body bracket. I of course just couldn't say to what degree the volume and vibration would change if the inserts were not so tight.
I think if the inserts, once installed in the mount, were cut to the side facing the driver's wheel, just cut a little away from where the pin goes through and just cut that remaining 1/2 off, the mount would fit perfect. I'm just not willing to do that.
Chris Gregg is offline
Old 01-08-2012, 12:19 PM
  #407
Toolie
knight_yyz's Avatar
Is the chassis bracket removable on the auto? The 6 speed seems to be held in by 4 bolts. Maybe the chassis bracket can be swapped? I don't have access to an Auto right now, I am so busy with getting ready for Mexico, making arrangements for the multitude of pets we have, and repairing the car today to make it drivable again I don't think I will be able to look at an Auto until I get back at the end of the month
Old 01-08-2012, 08:10 PM
  #408
Get Off My Lawn
Nope, perma-welded. Good thought though.
Old 01-08-2012, 08:44 PM
  #409
2000_MAXIMA_KING's Avatar
Maybe the bracket for the AT trans mount is wider where the inserts sit thus since the inserts have a lip they sit further out, meaning the center is not actually touching but there is a slight space. The design of the inserts rests on the reasoning that the width of the mount is the same as twice the part of the insert after the lip on the insert. If the AT bracket is slightly larger in width this would cause both sides of the mount to sit out further then they are supposed to.
Someone needs to measure the width of the AT and MT mount brackets.
2000_MAXIMA_KING is offline
Old 01-09-2012, 01:37 AM
  #410
Toolie
knight_yyz's Avatar
I have both brackets. They are 51mm wide, and both are 86mm wide with the inserts. We need to find out the width of the chassis bracket.
If that chassis bracket is welded on, how do you do a 6 speed swap?
Old 01-09-2012, 05:07 AM
  #411
Shift_Max's Avatar
On the auto, the chassis bracket is welded on to the frame. On the 6spd, it is bolted onto the frame. You have to remove the spot welds to remove the chassis bracket, grind the frame smooth, drill new holes, and then bolt on the manual mount.
Anyway I am interested in a set of mounts for a 2k2 6spd. Let me know when you get enough people to produce another set.
Shift_Max is offline
Old 01-09-2012, 08:42 AM
  #412
A few pictures and notes to supplement Chris's How to for just the passenger mount.
Here is a picture of the stock mount removed. The first step is to remove the metal plate that attached to the top of the mount.
1. It is one 14mm bolt in the middle of the mount and two 14mm bolts that attach to top plate to the engine.
2. Now that the top plate is removed, use a deep 14mm socket to remove the nut from the permanent threads you see between the left body mount and engine.
3. As Chris said the only difficult nut to get to for this mount is the one facing down. The nut you removed from the left side is the same as the nut you have to remove from the right side except it is upside down. Go under the car, use a 14mm deep six point socket with about 12-18 inches worth of extensions. Be careful with this nut. Do not rush and strip it. It may help to add a swivel joint and remove the side engine cover so you can get clean contact but I did not do either. You are going to squeeze the socket between the pulleys and the side engine cover (or body if the cover is removed).
4. Now remove the Long bolt that runs through the mount and the two holes you see on the body tabs. I used a 14mm socket on the right side and a 14mm small ratcheting wrench on the other side under the power steering pump reservoir. You may need to pull that long bolt out with pliers or vice grips.
5. The last bolt is the 14mm in the middle that was under that top metal piece you removed in the beginning. By now you should have a mount you can pull out to the right of the mounting tabs.
Here is are pictures of the stock mount. As you can see there is a gap to allow movement of the rubber insert. Unfortunately there is a trade off. This gap causes a reduction in vibration and therefore noise in the cabin but this also allows for loss of power to the wheels because the inertia is being absorbed by the mount movement.
These steps are to remove the stock mount. Now you can either pay someone to press the mount out or do what I did, but it is up to you.
1. I used an air chisel to remove the main rubber insert but I think a regular chisel (possibly large flat head screwdriver) and mallet will be enough to knock the rubber out.
2. I used a dremmel tool with a cutting wheel to simple cut a line in the metal part of the mount. BE CAREFUL not to cut too much, meaning only cut the insert mount metal NOT the mount bracket too.
3. Even if you did not cut completely through the mount insert metal it should be thin enough to pry up from the bracket like pictured below. This will allow for the metal to easily be pushed out. I just had to tap it with the same screwdriver and mallet.
The next part is simple. Since Knight made a perfect fitting mount I was able to press in the new mount inserts with my hands and a couple of love taps with the mallet. Now, lube up the metal insert for the bolt hole and tap it in with a mallet (a little more love is needed for this one). This is what you have:
To install the mount is a little tricky.
1. The first bolt I installed was the through bolt that attaches the mount to the body.
2. I then attached the nuts to the long stationary threads but on threaded them on slightly. You may need to coerce the engine with a large pry bay in order to get some of these nuts/bolts started but do take care in what you are prying against. If you do not have Sasquatch hands then you should be able to start threading the downward facing nut.
3. Start threading the middle bolt and then once they have all been started, tighten them.
4. Install the top metal plate and enjoy your new mount.
As I have stated before. My first impressions are great. There is a noticeable but very slight vibration at idle and acceleration. The engine noise is transmitted more throughout the chassis. I actually had a small buzzing in my rear deck at idle but have since resolved it. When cruising none of the attributes mentioned above are heard of felt. I can say for certain that more power is delivered to the ground and that some of the first gear bucking has subsided. (The bucking you get when you take first gear up to about 15mph and then let off). Also in between shifts are much smoother. I have heard from other members that what I am experiencing closely resembles that of installed ES front and rear mount inserts (which I currently do not have). I also think it is very similar to what I have read the torque link feels like. For changing just one mount I am very impressed and I am sure that the mount still needs a little time to settle so I expect some of the noted vibration and noise to subside. Good luck and enjoy.
Old 01-09-2012, 08:54 AM
  #413
Toolie
knight_yyz's Avatar
FTR, If you have the ES torque mounts you don't have to man handle the engine. They are strong enough to hold thine in place. for the DIY guys with no lower urethane bushings you could try to support the engine with a jack
Old 01-09-2012, 09:05 AM
  #414
Do you feel like getting the ES inserts will take stress off of your side mount? Based on your post I get the feeling that your mount has taken some of the sagging out out the motor therefore making the front and rear mount sit higher than stock. Does this mean that the front and rear mounts are not holding their fair share of the motor weight, causing the engine to essentially sit ever so slightly lop sided (higher on the passenger side)?
Old 01-09-2012, 10:33 AM
  #415
Get Off My Lawn
I don't have the ES bushings and did not have to support the engine for either side. Although I had a jack under there if needed, I actually initially tried to do the mounts with some jack supporting the engine, but it actually threw things out of wack. Once I removed the jack, I was able to budge the engine enough by hand to line up the bolt through the insert. I just had the car sitting on level ground. Same thing for tranny side, no support when doing that mount, just lined up the bolt through the pin first, then dropped the bolts through the mount plate and tightened her right down to the transmission.
I won't answer for Ray, but I'm certain good motor mounts (or ES) take stress off the torque mounts....I also believe this works conversly as well. One thing I learned with my 1989 turbo was that the torque and stress from the engine was effectively absorbed by the motor mounts. This is why (in part) on the 3rd gen, the crossmember is prone to snapping at the front. If the 3rd gen had a torque mount on the front of the engine, I'm confident those cross members would not have been so prone to failure. My point here is that naturally such force takes a significant toll on the mounts. I think this is a good point to connect why Aaron indicates the torque link is not a substitute for replacing old/worn/damaged mounts.
Old 01-09-2012, 10:48 AM
  #416
ampire's Avatar
That side mount looks a ton easier to install then the front ES bushings. I think it took a friend and I about 6 hours to do front and rear ES motor mount bushings at an auto hobby shop that included the press.
Poly mounts are worthwhile and I highly recommend swapping.
ampire is offline
Old 01-09-2012, 10:51 AM
  #417
Toolie
knight_yyz's Avatar
I think my side mounts would have died ages ago if I did not have the ES torque mounts installed.
Old 01-09-2012, 11:03 AM
  #418
Do you think my engine is sitting at an angle now?
Old 01-09-2012, 11:09 AM
  #419
Toolie
knight_yyz's Avatar
Possibly, but not very much. You have 3 other mounts in there. The oem mounts are made to sag to the middle of the bracket. Urethane is still extremely pliable even at high durometer ratings. It will still squash under load
Old 01-09-2012, 11:10 AM
  #420
Shift_Max's Avatar
Pictures of the mount installed on a 6spd trans mount?
Old 01-09-2012, 11:11 AM
  #421
I am worried that getting front and rear es mounts will intensify the vibration and noise in the chassis. Do you think this is true?
Old 01-09-2012, 11:43 AM
  #422
Toolie
knight_yyz's Avatar
More than what u are used to I did the torques first so when I did the passenger side I felt no difference.
Old 01-09-2012, 01:52 PM
  #423
a.k.a. STuNtMAN
JonBlz's Avatar
Anyone who's worried about vibration then this is not for you everyone should already know when you go with more solid mounts other than oem you will experience this so vibration should not be an issue
Vibration with my es mounts doesn't bother me at all
JonBlz is offline
Old 01-10-2012, 10:00 PM
  #424
IslandMax's Avatar
Another install of the (timing cover) side mount. I used an air chisel to take the stock mount out.
The mount feels great (my old one was shot), I dont feel any increase in vibration at idle or driving, the car is manual and has ES torque mounts. Driving I can feel the engine being held better, letting off and getting back on the gas in gear feels much smoother. Hopefully I have some time soon to do the tranny mount.
IslandMax is offline
Old 01-11-2012, 03:30 PM
  #425
BobPezz's Avatar
I wonder if Chris's vibration problem has to do with an AT always being driven by the engine via the torque converter's fluid coupling, vs. an MT which isn't driven with the clutch disengaged. Prehaps the firmer Wrayth tranny mount will constantly transmit vibration through the AT. But only through the MT when moving and that's minimal compared to an AT being stopped by holding the converter stationary with the brakes. Not to mention the hydraulics that run regardless of forward motion.
BobPezz is offline
Old 01-11-2012, 06:14 PM
  #426
Get Off My Lawn
I think that is part of it. You were much more technical in your response, but i eluded to your comment (although genericly) in talking about Nissan's use of electronic motor mounts, which soften at idle.
Keep in mind that the vibration and noise is still significant in park and neutral for my car. Soon I'll be able to comment on the difference with removing the transmission mount
BTW, perhaps I've missed it, but am I the only one who has even installed the transmission mount (auto or manual) at this point?
Old 01-11-2012, 07:03 PM
  #427
Toolie
knight_yyz's Avatar
No one has attempted the drivers side yet. I would do it if I could find a 6mt mount for a spare
Old 01-12-2012, 05:11 AM
  #428
Shift_Max's Avatar
I am waiting to see pictures of that as well.
Old 01-12-2012, 07:12 AM
  #429
StevieB's Avatar
No time lately
Too busy with work for the moment...slim chance I might get to it this weekend. Refresh my memory, is the transmission mount easier to get in and out than the passenger side mount? Previously I found with the passenger side mount I had to access one bolt from underneath, but I seem to recall reading the Trans mount can be done from the top. If someone can please confirm that's the case I'll do my best to change it Saturday.
Cheers
StevieB is offline
Old 01-12-2012, 07:16 AM
  #430
Shift_Max's Avatar
The 6spd trans mount bolts are all from the top. 4 bolts hold the bracket to the trans and one single long bolt goes through the center of the mount. And the mount is held to the frame with 2 more bolts.
Old 01-12-2012, 07:18 AM
  #431
All of your assumptions are correct. There are a couple of step by step instructions on passenger mount install. Are you a six speed?
Old 01-12-2012, 08:19 AM
  #432
StevieB's Avatar
Thanks shift_Max . 02white...6 speed. I'm very familiar with the passenger side replacement, having done stock replacements previously. I've never done the transmission mount, thus my question.
StevieB is offline
Old 01-12-2012, 10:58 AM
  #433
I would do mine if I can source someone or a way to punch out the old inserts. My car is currently undriveable though so I'll only be able to do a review on the install.
Btw I was working on my car yesterday and noticed my trans mount doesn't look like the ones in the pics posted in this thread. It was a quick glance but it quickly caught my attention that it was different.
Old 01-12-2012, 11:28 AM
  #434
Toolie
knight_yyz's Avatar
The bracket is different on the older models, but the bushing is the same size
Old 01-12-2012, 02:45 PM
  #435
Toolie
knight_yyz's Avatar
I'm getting lots of inquiries about the next batch. If you are interested, please start up a new list. I am leaving for mexico on Saturday for two weeks. I don't think I will have internet access, so we'll see how things are looking when I get back. Need ten guys per batch.
Old 01-12-2012, 04:52 PM
  #436
"I'm just sayin'..."
nelledge's Avatar
Quick review of passenger mount: awesome.
On a sadder note, the six speed mount is going to have problems similar to those stated by Chris. I removed mine completely from the car, got some info for Knight, ran a tap through a few bolt holes that had some ugly threads, and reinstalled the old mount.
Knight: I've got some measurements and photos for you. I PM'd you my email address.
nelledge is offline
Old 01-12-2012, 05:55 PM
  #437
BobPezz's Avatar
Ray, I took some measurements on my 01 tranny mount. The bad news is Chris is right and no offense intended to him, I admire his tenacity and strength. But to get the mount in the AT body bracket he must have bent the living crap out of it! The problem appears to be that it's asymmetrical and from what I could see without removing the mount quite a bit narrower than the assembled sleeve and pucks. I apologize in advance I'm using the American inch system since that's what my measuring tools are. And that some measurements are by eye using a 6" scale because I couldn't get my calipers into position to get good measurements. But they're close enough to get the message across and after 30 yrs of being a machinist I CAN give a good approximation by eye. I don't have time to post my findings now I've run out of time tonight. Plus I have to get the pictures I took and measurements organized intelligently.
BobPezz is offline
Old 01-12-2012, 07:18 PM
  #438
Toolie
knight_yyz's Avatar
My Apologies guys, but after seeing pictures, it looks like i ****ed this up. The only thing i can think of to do right now is I have been getting inquiries to sell more of these. So if it is ok with those that have bought them, I suggest that you sell the pair of pucks that wont fit on the drivers side, and i will go back to the drawing board and redesign that side. If you guys sell the pair for 65 shipped, you will break even and then we'll work something out for the drivers side when i get some time.
I'm not sure what went wrong, but if you guys can wait for a while I will correct this. From the looks of the pictures i have seen, it looks like both the 6mt and the auto need some tabs ground off the chassis bracket, and I have to make the pucks a little thinner. The 6mt tabs are hidden and pretty well impossible to see until the rubber mount is removed.
So for now, guys, if you want to purchase a set of my mounts, please contact the guys who have bought them, (see the list) and arrange for payment. When I get some time I will redesign the drivers side and make sure they fit on my car before putting them "on the market"
1. BobPezz.
2. Chris Gregg
3. 2000_MAXIMA_KING
4. Cant_Get_Ryte
5. mbdemonte
6. StevieB
7. nelledge
8. 2kayznmaxima
9. 02whitemaximase
10. zero2sixtyZ
On a side note for Bob, I don't use metric most of the time when I machine. If i get a metric drawing i convert it to imperial. But for stating sizes and such in here it was easier to say 86 mm rather than 3.385" as it isn't a fraction Even when i made the prototype, i new the size in metric, then converted to imperial, then added the percentage to compensate for shrinkage, then rounded up to a nice even number. LOL then I machined it to the imperial size.
The new prototype might just be as simple as making the flange a lot more narrow, or I will change the angle of the taper, and the thickness. But I need to remove a chassis bracket and measure it up with a vernier off the car.
Old 01-12-2012, 07:41 PM
  #439
Ok thanks for the update knight, its unfortunate this had to happen. I would really hate to sell mine, can you figure out a way to make it fit? or can I ship it back to you (on my expense) you "modify it" to make it work and ship it back (on your expense that way we are even)?
If this idea isn't really practical, I'll just sell it.
Old 01-12-2012, 07:45 PM
  #440
Toolie
knight_yyz's Avatar
For now, I'm not sure what needs to be done to modify it. I really hate machining urethane, it always looks like crap when it is done. But give me some time to take a look at it when i get back from my holidays.
Quick Reply: My newest protoype
