Maxima HID Retrofit Build
Old 09-26-2011, 12:09 AM
  #81
Genes1s's Avatar
00-01 E46 Bi-X Retro w/Di-Noc CF Vinyl wrapped bezel: 9/25/11 Complete
OK, just completed the retro and mounted.
It is AMAZING on the road. I've had half a dozen setup before, this is the best I've seen so far. It blew my old FX35 setup out of the water. It made the Mini H1 setup like Halogen. I'm shocked that E46 Bi-X can be this good.
I'm pretty happy with the result. I need to tweak the height adjustment a little since it is now at 1.5" drop or less and I'm already running out of height travel. Don't want to open it up again yet, so, I might have to shim/tilt the headlight a little bit down. I haven't tried the hi beam yet since I need few parts to complete the wiring. Cut off is awesome, I like this better than my old FX also. Not soo much blue, but purple and yellow instead. One thing that I'm impressed was the distance.
Genes1s is offline
Old 09-26-2011, 08:05 AM
  #82
Great job! They do look nice. Get some daytime pics of the headlights on the car. I'd live to see how the CF looks in there. It's an idea I've played with for a while but I was only going to use it in small sections of the R34's.
They should hold up well to heat. I've seen others use that stuff in their retros and it's fine.
ChrisMan287 is offline
Old 09-26-2011, 08:53 AM
  #83
L_U_D_I_AMaxima's Avatar
I still don't understand why people neglect the e46 projectors... with little modification they are as good if not better that the tsx or tl or fx projectors... those are just simply overrated and horribly overpriced. Good Job MSU2000.. I have a set of the E46 bi-xenons I am putting in my gf car and for my maxi I am working on a dual set of a single MDX/camry projector with 9005 high beam... I have heavily modified the mdx projector with custom shields and e30 clear lens and the output is as good as it is on the tsx and tl... Great job again man...
L_U_D_I_AMaxima is offline
Old 09-26-2011, 10:29 AM
  #84
Genes1s's Avatar
Genes1s is offline
Old 09-26-2011, 11:47 AM
  #85
Waxima's Avatar
That might be one of the sickest headlight setups I have ever seen. The CF wrap looks great. I'm looking forward to getting the Mini H1 retrofit off you whenever it's ready.
Waxima is offline
Old 09-26-2011, 01:13 PM
  #86
Originally Posted by MSU2000
would you mind taking a picture from the front of the car?
Old 09-26-2011, 05:49 PM
  #87
Genes1s's Avatar
More picts as requested.
W/Valeo D2S fog light.
Genes1s is offline
Old 09-26-2011, 07:12 PM
  #88
They look awesome. Was that output shot on the road with the fogs on as well or just headlights?
Old 09-26-2011, 07:26 PM
  #89
Genes1s's Avatar
Just the headlights. I hardly used the fogs really..
Genes1s is offline
Old 09-26-2011, 07:32 PM
  #90
I'm impressed with the E46's. If it wasn't for that shield work they'd be absolute crap. I admire your craftsmanship.
Old 09-26-2011, 07:44 PM
  #91
Genes1s's Avatar
Thanks. I was shocked honestly. I didn't expect to be this good, you really can't tell from wall shot. From the wall, my old FX35 wins handsdown, but on the road, no way. Now I'm wondering how my modded RX330 & TL stack up against the E46. The RX has far sharper cutoff than the E46, it has more or less the same intensity at the cut off and slightly wider on the sides.
I need to find a flat wall to do wall shot and find out how wide the beam is....stay tune...
Genes1s is offline
Old 09-26-2011, 08:56 PM
  #92
much much much better fit that the Morimoto... are you using the cutling shrouds on those?
I have seen a couple of people use the e-55r shrouds... looks good as well....
great figment one again ...
Old 09-26-2011, 10:30 PM
  #93
Genes1s's Avatar
Wiring issues: parking lights fuse keeps blowing.
Thanks everyone for the encouragement and support. I ran into several wiring problems tonight. Here is the scenario.
As you know the parking lights on the 5th gen Maxima is on bottom side (A) and next to the headlight (B).
The one next to the headlight (B) has dual filament bulbs and serves as both parking light and turn signal. It has 3 wires, 2+12V (one for corner light, one for turn signal light) and common ground (black). I wired my CCFL to +12V of the parking light (the one on the bottom side) and to - ground. Those black and red wires pointing to the top in the picture are the CCFL wires female connector leads. It was fine for awhile untill I blew both turn signal fuse (10amp) and corner light fuse (10 amp). Changed it twice and it blew again after 10-15 minutes.
Has anyone has any problem with this. CCFl should only take few hundred milli Amp. Should I wire the CCFL ground straight to main ground for better ground connection.
So I unpluged both CCFL connectors off and I still got blown tail light fuse which covers all dash lights, parking lights, and fog lights. Headlights, turn signals, and brake lights work just fine.
It made me to think that I might have short circuit somewhere. I used quick splice except on one ground connection (solder and taped). I even taped the open connector to the CCFl that I didn't use. Has anyone ran into problem like this?
Genes1s is offline
Old 09-26-2011, 10:37 PM
  #94
luvlexus101's Avatar
Hm maybe ground to body.
luvlexus101 is offline
Old 09-27-2011, 12:24 AM
  #95
I would give that a try.
Old 09-27-2011, 11:45 AM
  #96
Genes1s's Avatar
I'll try that.
Genes1s is offline
Old 09-27-2011, 12:42 PM
  #97
You embarrass me.
zero2sixtyZ's Avatar
Wow Impressive thread. Really like the CF look on those headlights.
zero2sixtyZ is offline
Old 09-27-2011, 10:17 PM
  #98
Genes1s's Avatar
Thanks! Very pleased with the performance on the road. standing in front of the car, it doesn't look intense like TSX, RDX, or CTS, etc. Behind the wheel is where you see the intense cutoff bouncing off the wall at 200 feet.
Genes1s is offline
Old 10-03-2011, 09:23 PM
  #99
Genes1s's Avatar
Rewired the ground and worked good now. CCFL is very bright. For some reason car looks like Subie....
I'm dragging my feet on the 02-03 retro now.......
Genes1s is offline
Old 10-07-2011, 07:41 PM
  #100
Mini h1. Is sorta out there but I didn't want to hack the reflector that much.
Old 10-08-2011, 04:00 PM
  #101
Genes1s's Avatar
Looks good! The shroud can be tucked in a little deeper without having the projector lens sticking out IMO. I know what you mean, this 5.5 gen headight isn't to get the look right. It's hard to make it look better than its stock form IMO.
What are you going to do with your MatchBox?
Genes1s is offline
Old 10-08-2011, 04:38 PM
  #102
No idea just sitting around right now.
Def could have cut the shroud and fit it deeper but..I'm lazy and I hate trimming the shrouds so I let it be.
Old 10-08-2011, 04:48 PM
  #103
maximalxl's Avatar
that looks sick
maximalxl is offline
Old 10-08-2011, 07:42 PM
  #104
Right now I'm debating which projector to go with for the low beam half.
Might possibly put a hold on that though. Will post output shots after morimoto 50 watt ballasts go in.
Old 10-08-2011, 09:34 PM
  #105
Genes1s's Avatar
You know, the Mini H1 should def fit in the low beam area even if you tuck it in deeper. The Mini is pretty skinny (width wise). The left/right adjustment screw is the culprit. You get wide flange or big dia projector in there and it will not sit flush due to adjustment screw in the way (unless you are OK with projector sticking out). Put H1 in the low beam and Matchbox back in high beam it's going to be money.
Genes1s is offline
Old 10-11-2011, 04:05 PM
  #106
Old 10-16-2011, 09:06 AM
  #107
Genes1s's Avatar
FX-R Built: Sneak Peak
This is 00-01 FXR Retrofit for someone else. I have his permission to post the build process.
Cut Off at 15'
Cut Off at 140' or so
Cut Off at 50'
Both headlights. Driver side didn't have shroud yet.
Stay tune.........
Genes1s is offline
Old 10-17-2011, 09:31 PM
  #108
Genes1s's Avatar
FX-R Built: Beginning stage
Headlights apart
Trimmed projector
Test Fitting
Projector mounted
Beam shot
Test Fit Shroud
I was going to use GG shroud, but didn't look too good since it didn't cover the projector well. Used Apollo instead.
Alignment check
Wall shot
Genes1s is offline
Old 10-18-2011, 09:53 PM
  #109
Genes1s's Avatar
FX-R Vs E46 modded
Ok, it's hard to find flat wall around my area, so this is best I can do so far. Same setting, HID components, same location.
50' wall shot
E46
FX-R
Overall, FX-R is more intense/brigthness below the cut off line, have sharper cut off, and more foreground than E46. I used to have FX35 OEM and it wasn't as intense as this FX-R.
Although E46 appeared to be dimmer, it has uniform beam pattern instead of spotty beam/pencil beam than FX-R has. It also has better high beam which throws the light down in the center more than FX-R. E46 blue band is also less agressive and pretty uniform along the cut off line. FX-R has far thicker blue band which produces crazy color flicker on the road.
We'll see how these two perform with 50W ballast.
Genes1s is offline
Old 10-19-2011, 07:33 AM
  #110
EuroDriver's Avatar
Awesome work! Although the FX-R is more intense, I think the E46's are going to be much easier on the eyes while driving.
On a different - slightly off topic note, how did you seal the back of the 5.5 gen housings? My covers no longer fit on my fleabays and I can't come up with t good solution to seal them while leaving them accessible for bulb changes.
EuroDriver is offline
Old 10-19-2011, 10:01 PM
  #111
Genes1s's Avatar
The 5.5 gen lights are not done yet. Most of the time, I re-use the covers but when it sticks out too much I usually make an extention then put a piece of rubber gasket with clamp ring.
My very first retro. Ran it for about 8 months in the WA/OR rainy season. No leak, condensation, no problem. Won't do this setup like this though if I can avoid it.
Genes1s is offline
Old 10-20-2011, 07:14 AM
  #112
EuroDriver's Avatar
Thanks - you 'da man!
Old 10-20-2011, 02:41 PM
  #113
RR5
RR5's Avatar
Great work! A projector retrofit has been on my short wish list for years!
RR5 is offline
Old 10-20-2011, 06:20 PM
  #114
sek11172's Avatar
good job
sek11172 is offline
Old 10-22-2011, 09:27 PM
  #115
Genes1s's Avatar
FX-R Built: 90%done
For some reason I have a lot of problem with these perticular brand headlights. From adjustment screws, to bezel won't budge open.
Anyway, I was planning to wrap it up and call it good tonight but instead have to wait few more days since I couldn't figure out to seperate the bezel from the headlight lens. I needed to trim the bezel a little to make clearance for verical adjustment since the Appolo is pretty big. I could've mounted the projector little futher back, but I was trying to maintain the clearance between D2S Connector and engine bay. So I had to make sacrifices.
Driver and passenger side are alligned to each other. Underexposed camera setting to show the beam pattern.
W/normal camera setting
Both at the same height w/underexposed setting
Car is about 30' off the wall
Now its time to trim and mount the shrouds.
Not necessary but I'd like to know if the part silicone part JB weld is doing its job to hold the shroud in place. Shake test.
More problem wit adjustment screw, this time is the horizontal adjustment screw. It's taped with silicone now.
It's time to figure how to seal the back of the housing. I had to cut the top portion of the holw to clear the projector, but I went a little too far thinking that I might not have enough to begin with.
Cut off aluminum flashing to take up the space, JB weld them and lay butyl tape on top to add more sealing surface.
W/OEM boot modified
Can't wait to get this done....
Genes1s is offline
Old 10-22-2011, 10:42 PM
  #116
Is it me or is that cutoff bowing.
Old 10-22-2011, 11:22 PM
  #117
Genes1s's Avatar
Driver side is perfectly straigth but passenger top section of the cut off bowed/bled a little. I didn't want to mess with FX shield really since it's tricky (almost annoying) to get it right.
Genes1s is offline
Old 10-23-2011, 02:55 PM
  #118
Genes1s's Avatar
FX-R Built: 10/23/11 update
OK got the bezel out after heat gun and 1.5 hours of wrestling match with it. Bezel is trimmed ( took out about .125" material off the bottom edge) and looked pretty good EXCEPT my dremel wandered off and hit chrome area some of the chrome peeled off. I was about to throw the dremel away across the garage if my boy wasn't playing nearby. Sigh.....
Drive Side chrome damage
Passageer side
Passenger side
Genes1s is offline
Old 10-24-2011, 01:49 PM
  #119
Brudface's Avatar
Omg, I am sooo jealous of the 5th gens right now I could beat my head against a wall, try fitting that thing into the 5.5 reflector bowl... good effin luck! love the FX-R's too by the way the highbeam is almost like an angel coming down from the heavens.
Brudface is offline
Old 10-24-2011, 04:09 PM
  #120
Genes1s's Avatar
I can't wait to get back to the 5.5 gen retro. I need to ship this one out then start looking for used 5.5 gen driver side headlight
Genes1s is offline
Quick Reply: Maxima HID Retrofit Build
