If you've changed your cats or gutted them, step in
I'm trying to prepare to gut my cats and I'm trying to get all the gaskets I need.
After a few quick searches and calls to dealers, I keep ending up with two part numbers.
My question is to those of you that have replaced Precats or have gutted them or possibly those with headers:
How many gaskets were there and where were they?
Any part numbers?
Where did you get yours and for how much?
For reference the part numbers I've gotten were:
20691P
20692M
Any part numbers?
20691P
20692M
Thanks for the quick reply.
Would there be none between the y-pipe and each precat?
Also, I am trying to get OEM and trying to order them online but I'm having trouble finding them.
those are the 2 i am talking about (assuming you gut the precats on the car), at end of each precat you will need a new gasket..think of it this way, look at what a y pipe looks like, it bolts to 3 locations, on at the cat and the other 2 at the END of each precat, if you remove the precats completely, you probably need 2 more at the top of each precat. 2 people have gutted them on here, maybe they can chime in..
@HotshotVQ35 - Yea that's what I meant. I know I'm probably gonna take off the y pipe so i could figure i'll need 3 gaskets there, and for some reason, I assumed that it's necessary to take off the precats from the exhaust manifold as well, which is why I think in total there are 5 gaskets.
@nelledge - Can you tell me how many miles were on those cats when you did this? Would it matter that I live in the rust belt if I consider reusing gaskets?
I don't mind spending 20 bucks for gaskets for security, but I'm just having a bit of trouble finding them. Someone else I asked also reused gaskets and had about 60k on their car at the time.
I'm gonna PM scottwax. I know he's changed his precats before.
OP, this is a whole lot of fuss about gaskets. I recommend you find a local in-stock source for the gaskets in case you determine you can't re-use the originals, so that you can pick them up if needed.
That's the thing Rochester, I did contact my local dealership and they were of no help. I don't mind buying the gaskets but if they can't help, I'm gonna need to find another way.
Other than dealerships, most places don't just stock random OEM maxima gaskets. I don't want to end up having my cats pulled and then have to redo the whole thing
I had 120k on the original gaskets. You're adamant about replacing them? Do what Rochester said. Contact a Nissan dealer and order them. Your Nissan dealer can't get it right? Move on to another Nissan dealer.
I'm pretty sure these are the replacement gaskets: 20691-30P00, 20691-51E01, 206918J100. Two ring gaskets to the y-pipe and one for the top of the rear pre-cat. The front pre-cat seals itself. No gasket needed. What part numbers did your dealer give you that are in question?
BTW: The ypipe gaskets can be changed in about 5-10 minutes once you've recently loosened the bolts. No big deal.
I've contacted about 4 dealerships, local and not local. I got different part numbers from those that weren't local and the local one was useless.
Now that everyone's saying that reusing is fine, I'm most likely going to stick that route if I can't get the gaskets.
not reading thread after people said reuse gaskets...
if youre cheap enough to not spend a couple bucks on gaskets then im sorry...
when you break the seal on a gasket or crush ring its not going to get compressed the same way so the metal fatigue on it is going to be at a different point....sounds gay and what not, but its best to spend a couple bucks to replace them before you drive down the road smelling your exhaust all day....
Like storm says replace them man! go to courtesyparts.com and order some, the only reason I reused the crush gaskets cuz i had the wrong ones and found out in the middle of install and there was no going back
OP, if you're in the middle of this job, and for whatever reason you can't re-use your originals, you're going to be stuck for a while. Go ahead and pick your favorite metaphor for the situation... there are plenty to choose from.
There's a lot more torque on bolts connecting exhaust parts than there are, say, on the VIAS plate. Plus, these are hardened steel contacts, not soft aluminum.
Buy some new gaskets and buy yourself some peace of mind in a job done right.
Protest, eh?
Couple bucks, huh? Evidently, you haven't purchased these gaskets before. How about you send me those three new gaskets, and I'll paypal you 2 bucks when I receive them. I'll even throw in the 50 cents for postage.
You were making a valid point until you had to keep talking and this gibberish came out. Stick to explanations you're certain of and your point will be well taken.
OP - It's always advantageous to use new parts. However, there are times when the parts supplied are not accurate or the work was not premeditated. Your original post suggests that you were anxious that the former may happen and you could not put your car back together. This is not one of those times. I dropped my precats on a whim while doing some other work. I had no new gaskets on standby. The relative ease and convenience of changing the gaskets allowed me to tackle the job without the new gaskets. It just so happens that I haven't had any leaks(like several others), and I haven't got around to fixing what isn't broken.
Well, this is fun! nelledge has convincing writing skills, I'll give him that.
Reminder: the OP lives in PA, with 4 months of solid, salty winter. I'm guessing phrases like "relative ease" don't apply.
Ahh, but you see. It will be hard to remove the connections whether he has the gaskets or not. However, once removed, disconnecting the pipe again a week later should be accomplished with relative ease should he need to replace the gaskets. I'm guessing they're not putting salt down in August?
Apparently no one mentioned that these so called "gaskets" are not the typical flange gaskets that deteriorate over time.
There is absolutely no reason to spend the extra money (at least on the front pre-cat).
As I stated, I have over 164k miles on my '02 and the precat to manifold and to y-pipe sealed perfectly after I gutted it. No gas fumes, no spitter/spatter, no moisture drops, nothing.
I have not been able to get to the rear yet, so I can not comment on the type of "gasket" used there.
But your choice. You can buy them, then return them if you don't need them.
thanks for that one nismopc.
After looking at the pics and seeing that the gaskets looked like metal rings, and not your typical crush gaskets, I'm starting to think I might just reuse it.
And Gemner, that's pretty much my plan was to take the cats straight off. I figure that way It's much easier to access the catalyst material and I can ensure I get it all out. Since I'm doing it at home without a lift, it'd just make things much easier than leaving it on.
I've got to say the rear precat is a bish to do while on the car. I tried to take it off but it broke my #14 socket. Time for some pb blaster and a hammer. The front precat is very easy to do, it all falls out with a few punches. I used the old gaskets and I have 130k miles.
Did you guys remove all the crap that sticks to the inside wall of the precat? I'm sure I would have to use a degreaser or some strong chemical to get it all out.
I gutted both my precats last year around this time. Like Nelledge and NIsmo stated best to take off the cats. The rear is a PITA but doable. ALoow a couple hours with beer, swearing killing anyone that starts to talk to you during the rear precat gut. I used a butane torch to heat the bolts after i soaked them with wd40 and they came off like a wh@res dress. The gaskets i reused and didnt buy anything to do the job. YOu wont get any leaks, exhaust smell or weird complications. The only exhasut smell will be from the tip of the exhaust as it now will smell like a normal car.
It is an absolute physical impossibility to gut the rear bank pre cat while on the car so heat the bolts if you can till there cherry red, let them cool a bit and crack them loose.Take your time it sucks to do.
No,the rear bank pre-cat has to be taken down to gut it.Neither of the manifolds have to come off.Both pre-cats can be dropped without touching the manifolds.The front bank pre-cat is the easy one to gut.Rear bank is against the firewall.Either you got your banks mixed up or for some weird reason our cars are setup different which i doubt.No matter how many of these you have done it's impossible to gut the rear bank while on the car period.
I'm starting to think you and I have a different interpretation of which cat is front, and which one is rear.
Would it clarify things if I said front-most, and rear-most?
Front cat is the one right behind the radiator and the rear is the one against the firewall.You are confusing the heck out of me over here...Not like that's hard to do most of the time but im pretty sure im right.
Yep,it's a mesh that looks kind of similar to the back of your typical household a/c unit or like radiator fins.There so compacted in there it's crazy/I guess that's where the majority of the sound and power increase comes from when you get it out.
