tach needle lag
tach needle lag
Hey everyone boguht a cluster to fix my gas gauge problem fix the gas gauge work fine now but the tach on the new cluster seems to no work correctly when i received it the tach needle was not resting on the black small needle. Took off the front plastic cover moved it back but when i rev the needle seems to lag a little. Should i give it some time to see if it will adjust or is this an easy fix. Thanks in advance.
$700? That's ridiculous.
Junkyards? www.car-part.com. I'm sure a junkyard somewhere in the US will ship you one for significantly less than $700. Good luck.
PS - you've got PM
PS - you've got PM
James92SE
142
01-02-2024 09:23 AM
Justinmc760
08-23-2015 03:10 AM
