Need help: revving on own while stopped
Old 08-09-2011, 09:33 AM
TheAnswer11's Avatar
I instaed the upper nwp intake spacers. Also new MAF, 6th Gen upper intake manifold, arm, and throttle Body and now the car is revving on it's own from 1.25rpms to 2rpms continually about every 45 seconds to a minute .. Does anyone know what this could be .. Also have a video below..
http://i802.photobucket.com/albums/yy308/maxxkidd00/12f427ad.mp4
TheAnswer11 is offline
Old 08-09-2011, 09:48 AM
Gizm0's Avatar
Have you done the idle relearn procedure?
Idle Air Volume Learning (Throttle Position Learning)
It is better to count the time accurately with a clock. 1. Perform “Accelerator Pedal Released Position Learning”.
2. Perform “Throttle Valve Closed Position Learning”.
3. Start engine and warm it up to normal operating temperature.
4. Turn ignition switch “OFF” and wait at least 10 seconds.
5. Confirm that the accelerator pedal is fully released, then turn ignition switch “ON” and wait 3 seconds.
6. Repeat the following (steps 7a, 7b) procedures quickly five times within 5 seconds.
7a. Fully depress the accelerator pedal (HARD)
7b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the Check Engine Light (CEL) stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the CEL is ON.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure the idle speed and ignition timing are within the specifications.
Gizm0 is offline
04-16-2020 05:15 AM
D Mason
06-21-2016 04:43 AM
BobTX10
10-07-2015 08:43 AM
maxima297
09-30-2015 03:32 PM
JoshG
51
09-21-2015 10:41 PM
Quick Reply: Need help: revving on own while stopped
