Gutting your pre cats
Old 02-02-2012, 08:42 AM
  #241
Originally Posted by 02whitemaximase
This is to trick the secondaries NOT the primaries.
Woops, meant to switch that around.
Originally Posted by 036mtmax
You only need two anti-foulers you can get them at Autozone in the help isle. There is a short 18mm and a long 18mm, Get the longer of the two. The guy i sold the car to still hasn't had a CEL and it's been almost 15k.
Great. Thanks for all of this.
ChrisMan287 is offline
Old 02-02-2012, 02:17 PM
  #242
killer00's Avatar
How the freak do I take the screws off? I took off 3 from the front precat. After that, total failure on taking off the other screws.
killer00 is offline
Old 02-03-2012, 06:20 PM
  #243
Eirik's Avatar
Originally Posted by cjandura
My '97-Maxima-owning buddy has been running this "mod" for three years. After installation, he's been running on 14-year-old precats and a test pipe with no CELs stemming from precat efficiency or main catalytic converter efficiency.
Eirik is offline
Old 02-03-2012, 07:03 PM
  #244
036mtmax's Avatar
It's a heck of a lot cheaper and easier to install those than a set of sims. Id rather drill an anti-fouler than splice into an 02 harness.
036mtmax is offline
Old 02-03-2012, 07:09 PM
  #245
Xpcgamer's Avatar
What I don't get is your picture shows one non fouler and the link everybody keeps pointing to it shows 2 of them stacked together with on drilled out. Also your pic shows one Sensor with the fouler but it goes on both of the secondary sensors correct? The location you show in your pic and the other just after the front manifold cat correct?
Xpcgamer is offline
Old 02-04-2012, 03:55 PM
  #246
036mtmax's Avatar
No you don't stack them together you use two drilled 18mm anti-foulers the one i showed in the pic and the second one goes into the 02 thats directly above that one on the Y pipe. It was too hard to get a good pic of the other fouler after i installed it otherwise i would have posted a pic.
036mtmax is offline
Old 02-04-2012, 04:41 PM
  #247
Xpcgamer's Avatar
I got it now. Thanks.
Xpcgamer is offline
Old 02-08-2012, 04:20 PM
  #248
chopstic's Avatar
Car sounds wonderfull after gutting those cats! But my heat shield took some colateral damage in the process. I ended up breaking 2 of the 3 bolts on the front heat shield. Is thrre any way to remedy this situation as that one bolt isnt really holding it all that well
chopstic is offline
Old 02-08-2012, 04:45 PM
  #249
Rochester's Avatar
The best remedy is to simply remove the heat shield around the precat.
I suppose if it really concerns you, then figure out a way to put header-wrap around the precat after removing the shield.
Rochester is offline
Old 02-08-2012, 04:57 PM
  #250
036mtmax's Avatar
What Rochester said, I left all my heat shields off.
036mtmax is offline
Old 02-09-2012, 10:09 AM
  #251
chopstic's Avatar
even the heat shields around the exhaust manifolds? It kinda looks like I need it just to protect the wires going to the o2 sensors
chopstic is offline
Old 02-09-2012, 10:42 AM
  #252
Rochester's Avatar
No, it really doesn't, unless the wiring is actually laying against the exhaust for some reason.
You are needlessly obsessing over this. However, when it comes to obsession, you're in good company here, so don't feel bad.
Old 02-09-2012, 10:51 AM
  #253
02whitemaximase's Avatar
The o2 wires are stainless steel. Rochester is right, just make sure they aren't actually touching the manifold. Here is a picture of my setup. I have headers and used two antifoulers to extend just a little more and after 160 miles no cel. By the way wire loom and zip ties are your friends.
02whitemaximase is offline
Old 02-09-2012, 11:01 AM
  #254
Rochester's Avatar
By the way wire loom and zip ties are your friends..
Both of which can be purchased as hi-temp plastics... just in case.
06-06-2017 02:01 PM
maxinout93
10-31-2015 02:04 AM
lrb6805
09-18-2015 07:07 PM
Justin Kroll
09-02-2015 11:06 AM
Quick Reply: Gutting your pre cats
