Altering brake pedal for heel-and-toe
A month or so back there was a thread about heel-and-toe. After reading that thread and watching some videos I've started double-clutching. I enjoy it, it makes everything nice and smooth and makes driving more active. I can't get heel-and-toe though. Maybe my foot is too small or the pedal is just poorly positioned as some have said but unless I press the brake almost all the way down I can't get on the throttle at the same time. I was wondering if it would be possible to alter the brake pedal in some way to bring it down or closer to the throttle? Anyone done anything like this?
/troll.
inallseriousnessyouneedtobeonthebrakeshardtoattain therightheeltoeangleonthesecars...whichisdoneforar easonbecausewhyareyouhealandtoeingunderlightbrakin g?
Reason cars are not built with this in mind is braking then turning while then shifting is the easiest way for the general public. That doesn't mean it's the best way overall. With that said the closer the throttle got to the brake the greater the risk is of an accident so it makes sense why it is set up the way it is out of the factory. I think it is reasonable to say that heel-and-toe is a more efficient way of downshifting around an easy turn but that it is not feasible on the Max because of the setup of the brake/throttle.
Makes me wonder why do it in the first place if you're not braking hard
My check engine light is on and I had it read at Auto Zone. It showed Open or short circuit condition, failed power transistor unit, failed ignition ballast resistor, cam position sensor failure. HELP, WHAT DOES THIS MEAN? I tried searches but could not understand what they meant.
06-06-2017 02:01 PM
HerpDerp1919
09-29-2015 02:02 PM
