Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 07-01-2011, 10:20 PM   #1
tjrocks's Avatar
Points: 6,219, Level: 51
Points: 6,219, Level: 51 Points: 6,219, Level: 51 Points: 6,219, Level: 51
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Send a message via AIM to tjrocks Send a message via Yahoo to tjrocks
manual tranny won't shift into first gear
Help!!! my car won't shift into first for some reason??? It shifts fine in all other gears. Same problem even when the car is parked and turned off. It literally wont go into the slot. It just happened suddenly. No grinding or anything. Anybody got ant ideas???
tjrocks is offline   Reply With Quote
Old 07-01-2011, 10:26 PM   #2
Points: 3,300, Level: 35
Points: 3,300, Level: 35 Points: 3,300, Level: 35 Points: 3,300, Level: 35
Activity: 0%
synchros???
michael454rs is offline   Reply With Quote
Old 07-01-2011, 11:24 PM   #3
Points: 8,422, Level: 61
Points: 8,422, Level: 61 Points: 8,422, Level: 61 Points: 8,422, Level: 61
Activity: 0%
check the clutch fluid
HotshotVQ35 is offline   Reply With Quote
Old 07-02-2011, 07:35 AM   #4
Points: 3,957, Level: 40
Points: 3,957, Level: 40 Points: 3,957, Level: 40 Points: 3,957, Level: 40
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
eiriksmal
If it won't go into the slot, wouldn't that indicate a problem with the linkage..?
__________________
HLSDs should be standard on all 2000+ Maximas.
  • I own a Frost/Liquid Silver 2005 Maxima with the Elite Package and a 6MT.
  • I'm no longer a Maxima.org sponsor and, thus, no longer have a cool avatar of Erik the Red as depicted on a stamp from the Faroe Islands.
Eirik is offline   Reply With Quote
Old 07-02-2011, 10:09 AM   #5
Activity: 0%
Quote:
not in my case, the clutch fluid resovior(sp) was bone dry and the car had a VERY hard time getting into gear...filled it up, bled it, prob solved..this is for 02-03 though..OP doesnt state what yr his car is though..
Old 07-02-2011, 11:42 AM   #6
Points: 5,120, Level: 45
Points: 5,120, Level: 45 Points: 5,120, Level: 45 Points: 5,120, Level: 45
Activity: 0.6%
Activity: 0.6% Activity: 0.6% Activity: 0.6%
Guessing it is either the clutch fluid or something is jamming your linkage. Pull the airbox and have someone look at the linkage while you work the clutch.
__________________
2002 Maxima SE 6MT Sterling Mist, SOLD at 114k mi
Free STS mod, Progress RSB, fleabay FTSB, tint.
1996 Maxima with 185,000 miles (son #2)
1997 Maxima with 104,000 miles (son #1)
2004 Mustang V6 coupe, 78,000 miles, Auto
2010 Mustang GT Cnv,14k miles, 509hp, crazy mods
http://dreammustang.com/
trooplewis is offline   Reply With Quote
Old 07-02-2011, 12:58 PM   #7
Points: 5,631, Level: 48
Points: 5,631, Level: 48 Points: 5,631, Level: 48 Points: 5,631, Level: 48
Activity: 5.5%
Activity: 5.5% Activity: 5.5% Activity: 5.5%
My car wouldnt go into third one time because the red plastic battery bolt cover flew into the linkagr when i was driving. What are the odds of that. I was panicking for a while until i looked under the hood.
Bottom line. The first step is checking the linkage
2damax is offline   Reply With Quote
Old 07-05-2011, 12:29 PM   #8
tjrocks's Avatar
Activity: 0%
i already checked the linkage and looked fine. btw i have an 01 max. also checked the fluid level seems fine too.... I'll probably try to bleed it and refill and hope this works I'm reall hoping that this nothing internal
Old 07-26-2011, 07:09 PM   #9
tjrocks's Avatar
Activity: 0%
now i can't shift to third or fifth gear. So no first first, third, and fifth!! Anybody know what could cause for me not able to shift into these gear. It's really annoying to drive the car now that i only have 2nd, 4th and reverse.
Old 07-26-2011, 07:52 PM   #10
"I'm just sayin'..."
nelledge's Avatar
Points: 8,132, Level: 60
Points: 8,132, Level: 60 Points: 8,132, Level: 60 Points: 8,132, Level: 60
Activity: 0%
I would check as many superficial items as I can before I start worrying about whether the tranny is junk or not. You stated you haven't heard any noises which is a good thing. Have you checked the slave cylinder to confirm it's actually engaging and remaining engaged while the clutch is depressed? You'll need a friend to help you. Also, I haven't read that you checked the transmission fluid level. Make sure you can't add anymore. It would be fast to check these two items off your troubleshooting list. Plus, they're both fundamental to the operation of your powertrain. Report back with your results.
nelledge is offline   Reply With Quote
Old 07-26-2011, 09:19 PM   #11
Points: 4,118, Level: 40
Points: 4,118, Level: 40 Points: 4,118, Level: 40 Points: 4,118, Level: 40
Activity: 1.1%
Activity: 1.1% Activity: 1.1% Activity: 1.1%
wow no 1st 3rd or 5th gear??
Possibly clutch not disengaging? Maybe your torque mount had came apart?
__________________
2000 Maxima SE
www.jiujitsusweep.com For all things jiu jitsu
www.BJJGiMarket.com Slightly used BJJ gear
Amave is offline   Reply With Quote
Old 07-27-2011, 09:11 AM   #12
Activity: 2.3%
eiriksmal
Sheesh, I'm assuming the 5th gen 5MT is laid out:
Code:
1   3   5
2   4   R
so how can that not be a linkage problem? I whatever nelledge says.
__________________
Old 07-27-2011, 09:14 AM   #13
Sexier Than Simpson
Bufflomike's Avatar
Points: 5,953, Level: 50
Points: 5,953, Level: 50 Points: 5,953, Level: 50 Points: 5,953, Level: 50
Activity: 0%
Definitely sounds like a shift fork issue.
Bufflomike is offline   Reply With Quote
Old 07-27-2011, 09:24 AM   #14
Points: 5,364, Level: 47
Points: 5,364, Level: 47 Points: 5,364, Level: 47 Points: 5,364, Level: 47
Activity: 2.9%
Activity: 2.9% Activity: 2.9% Activity: 2.9%
Quote:
Definately sounds like an odd issue...
(Sorry, couldn't resist that)
MadMax07SL is offline   Reply With Quote
Old 07-27-2011, 11:46 AM   #15
nelledge's Avatar
Activity: 0%
I wish my wife thought like that.
Old 07-28-2011, 01:09 PM   #16
Points: 4,133, Level: 40
Points: 4,133, Level: 40 Points: 4,133, Level: 40 Points: 4,133, Level: 40
Activity: 0%
Quote:
I had the same exact issue and this was the culprit. Lost a clutch fork. Had to replace the the clutch.
__________________
2001 Maxima SE AE MT
[SIGPIC][/SIGPIC]
****WTB: 1985-1988 NISSAN 200SX****
4DSCDriver is offline   Reply With Quote
Old 07-28-2011, 05:50 PM   #17
Activity: 2.3%
eiriksmal
http://www.courtesyparts.com/maxima-...2024_2041.html
Am I looking at the wrong diagram..? This is showing multiple forks, and gears share them in pairs (1&2,3&4,5&R).
It's been a very long time since I've seen a clutch install and got the full explanation on how the fork works to move gears.
__________________
Old 07-28-2011, 06:02 PM   #18
Points: 21,093, Level: 91
Points: 21,093, Level: 91 Points: 21,093, Level: 91 Points: 21,093, Level: 91
Activity: 2.3%
Maxima3
1st gear gone..... samething happened to my 2nd... outta no where it just wont go into the gear, i can get it in gear put as soon as i eased of the clutch it would pop itself out... urs seem to be worste than mines
__________________
the crime fighting A33
Grand_hustle17 is offline   Reply With Quote
Old 07-28-2011, 06:04 PM   #19
Activity: 2.3%
eiriksmal
Quote:
Did you ever resolve those shifting issues you had a few months ago where you got pulled over by the cop for stalling in an intersection or whatever?
*Note: This could have been phatboislim, but I cannot untangle the two of you in my mind. Apologies if it was him and not you.
__________________
Old 08-03-2011, 12:09 AM   #20
tjrocks's Avatar
Activity: 0%
some good news!!! so i finally was able to get third and fifthe gears back. did it by adjusting the shifter bushing towards the rear of the car a little bit.. Still cant get first gear. oh yeah it seems like the shifter is too far forward somehow, because the actual shifter is hitting the plastic bezel when im in third gear. Anybody know what could cause this??? I'm checking my tranny mounts tomorrow and see if it somehow caused the shifter to move.
Old 01-02-2013, 09:57 PM   #21
Points: 3,193, Level: 34
Points: 3,193, Level: 34 Points: 3,193, Level: 34 Points: 3,193, Level: 34
Activity: 3.5%
Activity: 3.5% Activity: 3.5% Activity: 3.5%
Apologies for awakening a dead thread. Similar issue, although i can force the trans to shift.... eh.... i think its the slave cylinder because its as if the clutch isnt disengaging completely. My synchros arent happy with my mobil 1 75-w90 in 20 degress either. Feels like my tranny is dying, not whining so hopefully resolvable.
__________________
Injen CAI, 245 Firehawks on 6th Gen Wheels, HID Projectors, ES Shifter Bushings, Spec Alum Fly, Sachs Clutch, EBC Reds, Powerstop Slotted Rotors, Stillen RSB.
seastone14 is offline   Reply With Quote
Old 06-02-2013, 04:35 PM   #22
Points: 1,084, Level: 17
Points: 1,084, Level: 17 Points: 1,084, Level: 17 Points: 1,084, Level: 17
Activity: 2.9%
Wont smoothly go into 1st and Reverse
Reviving the thread because i'm going through the same issues...with my 03 6mt
I had the transmission rebuilt.
I'm having difficulty engaging into 1st and reverse. I'd have to force it in or shift simultaneously depressing the clutch.
Any advice would be appreciated.
Thanks!
spec04 is offline   Reply With Quote
Old 06-02-2013, 08:55 PM   #23
Points: 9,018, Level: 63
Points: 9,018, Level: 63 Points: 9,018, Level: 63 Points: 9,018, Level: 63
Activity: 7.8%
Activity: 7.8% Activity: 7.8% Activity: 7.8%
Would Have Been Nice if original OP let us know if he solved this issue and if he did how....cause thread is pointless without it being solved.
TravisCadello is offline   Reply With Quote
Old 06-03-2013, 04:20 AM   #24
Activity: 2.9%
Quote:
Would be nice! i'll give an update once I or the shop figures it out
Old 06-03-2013, 11:39 AM   #25
Activity: 7.8%
Kool. jus incase i have same prob one day id like to know what to chk
Old 06-20-2013, 03:49 PM   #26
Activity: 2.9%
The shop first thought it was the cable so they replaced the cable, it only got a little better but at the end they had to open the tranny back and replace another synchro.
gears they replaced on mine are 1st and reverse. the rest were bushings and seals.
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
