Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendor Directory
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 06-26-2011, 06:00 AM   #1
Points: 11,829, Level: 71
Points: 11,829, Level: 71 Points: 11,829, Level: 71 Points: 11,829, Level: 71
Activity: 7.6%
Activity: 7.6% Activity: 7.6% Activity: 7.6%
Crank/No Start - 2001 Maxima
I got my car back from the shop and it drove fine, however just outside of my house, the car just died. The engine didn't shut off right away, it was acting like I was out of gas. Pushed the clutch in and the engine died, and would not restart. No spark.
Pulled the codes and got a CPS REF and Swirl Valve Check (P1165). Replaced CPS REF, car fired up. I also replaced the spark plugs and a coilpack that failed on me shortly after.
Started the car and attempted to drive it down the block, where I ran into the same issue I had initially. Wideband reads all the way lean and I'll press the throttle pedal and nothing will happen it just coasted to a dead stop. No restart.
I tested the resistance of the CAS as well, and it came out out of spec. I replaced that with no luck, and a P0340 popped up.
I was sitting at a 1/4 tank the whole time.
This car has JWT cams, bolt ons and e-Ultimate.
I understand the necessity for fuel, air and spark, and I'm looking for some ideas on where my next step should be.
__________________
Mod lists are for the weak.
Maxima.org - the only place where the slowest guys keep their 'mods' top secret and require delta clearance to share.
Youtube
Administration Tuning - Builds & Executive Adventures
MoncefA33 is offline   Reply With Quote
Old 06-26-2011, 06:29 AM   #2
Points: 21,793, Level: 92
Points: 21,793, Level: 92 Points: 21,793, Level: 92 Points: 21,793, Level: 92
Activity: 100.0%
Activity: 100.0% Activity: 100.0% Activity: 100.0%
Crusher103
Send a message via AIM to Crusher103
erratic fuel pressure regulator, would be what i point the finger at.
__________________
96 Black I30t A.K.A Big Black/97 Black SE A.K.A. The DD(build in progress)
YES my cars have more mods than yours. And one MIGHT be reliable.
Quote:
Originally Posted by NCSU_MAX View Post
Crusher doesnt need any more crazy a** ideas... he generates plenty on his own on a daily basis...
Quote:
Originally Posted by Conrad283 View Post
Nope, that's just crusher being crusher
Crusher103 is offline   Reply With Quote
Old 06-26-2011, 06:38 AM   #3
Activity: 7.6%
Quote:
Where is the FPR? And is there a way I can test it?
__________________
Youtube
Old 06-26-2011, 07:29 AM   #4
My axles cry for mercy...
essential1's Avatar
Points: 8,144, Level: 60
Points: 8,144, Level: 60 Points: 8,144, Level: 60 Points: 8,144, Level: 60
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
The FPR is whats on the end of your fuel rail. Do you still have your stock one?
Also, did you smell fuel after you drove it?
__________________
DJ paul drives a 5th gen
essential1 is offline   Reply With Quote
Old 06-26-2011, 07:29 AM   #5
Activity: 7.6%
No fuel smell after I drove it.
__________________
Youtube
Old 06-26-2011, 08:26 AM   #6
Points: 4,404, Level: 42
Points: 4,404, Level: 42 Points: 4,404, Level: 42 Points: 4,404, Level: 42
Activity: 0%
Which grade of fuel do you use? This may sound strange but I had a similar issue not too long ago and the gauge read 1/4 tank. After putting in a little premium fuel in it it started right up.
__________________
Four Wheels, Leather Seats & a Sunroof.
MizzMaxine is offline   Reply With Quote
Old 06-26-2011, 08:31 AM   #7
Activity: 7.6%
I use premium all the time. That would be the simplest fix and won't hurt to try.
__________________
Youtube
Old 06-26-2011, 09:13 AM   #8
Rochester's Avatar
Points: 15,264, Level: 79
Points: 15,264, Level: 79 Points: 15,264, Level: 79 Points: 15,264, Level: 79
Activity: 5.6%
Activity: 5.6% Activity: 5.6% Activity: 5.6%
Quote:
One on each fuel rail. Here's a pic of mine (from that "what is this thing?" thread). Lovely surface corrosion.
Click the image to open in full size.
__________________
FI RHFC · R2C Intake · Eibach sways · GT-Spec FSTB · Swift Springs · Michelin PSS · Vossen CVT
2011 Infiniti G37 Sedan 6MT
Rochester is offline   Reply With Quote
Old 06-26-2011, 09:24 AM   #9
Activity: 7.6%
Yup stock FPR.
__________________
Youtube
Old 06-26-2011, 09:31 AM   #10
5.7 Gen Maxima
SurraTT's Avatar
Points: 17,236, Level: 83
Points: 17,236, Level: 83 Points: 17,236, Level: 83 Points: 17,236, Level: 83
Activity: 2.2%
Activity: 2.2% Activity: 2.2% Activity: 2.2%
if your getting po340 that's CAM position sensor.
Why was the car in the shop?
If the ECU is not getting a cam signal input it will not run. This is what ive been going through with my swap.
You should check and see if your even getting spark, its pretty easy to check
__________________
Like VoltageDrop.net on Facebook
336.270.9202 CALL/TXT
Need a 5.7 Gen swap? or a Patch Harness or Plug and Play Haltech/UTEC/EMU Harness? www.VoltageDrop.net !
SurraTT is offline   Reply With Quote
Old 06-26-2011, 09:36 AM   #11
Activity: 7.6%
Car was in the shop because I was getting cams installed.
I've gotten both CKPOS (REF) and CAS now even though I have a brand new CAS plugged in.
How should I check spark?
__________________
Youtube
Old 06-26-2011, 10:39 AM   #12
5.7 Gen Maxima
SurraTT's Avatar
Activity: 2.2%
oh ok hmmmm
Check spark by taking a coil pack out, and putting a sparkplug in the end, and setting it somewhere where it grounds out, then have someone crank motor over and see if its sparking.
To me seems like you crank, and cam sensors are messed up, either the wiring or the sensors. Im betting wiring, as the car did run for a little bit.
could even be a ground,
Get the multimeter out!
__________________
Old 06-26-2011, 11:04 AM   #13
Activity: 7.6%
oh ok hmmmm
Well my CPS REF sensor is new and the car is not throwing a code for either POS or REF.
Gonna see about the grounds...
Any other ideas?
__________________
Youtube
Old 06-26-2011, 11:24 AM   #14
5.7 Gen Maxima
SurraTT's Avatar
Activity: 2.2%
So what codes are you currently getting?
__________________
Old 06-26-2011, 11:36 AM   #15
Activity: 7.6%
P1165. - Swirl valve control solenoid.
P0340 - CAS - even though I replaced it
__________________
Youtube
Old 06-26-2011, 12:53 PM   #16
5.7 Gen Maxima
SurraTT's Avatar
Activity: 2.2%
DO 3.0s have only 1 cam sensor? from what i can tell they only have 1, so if that one is not working = motor wont run
If the sensor is new, it could be the wiring.
Im not even sure what a 3.0 cam sensor is even reading? timing chain?
From the FSM
Malfunction is detected when
(Malfunction A) the cylinder No. signal is not sent to ECM for the
first few seconds during engine cranking,
(Malfunction B) the cylinder No. signal is not sent to ECM during
engine running,
(Malfunction C) the cylinder No. signal is not in the normal pattern
during engine running.
IT could be the ecu not getting a signal, or something is off far as timing, not sure how it would of ran fine until it stopped.
How long was the car running after cam install till this happened?
Was it running ok or very rough?
__________________
Old 06-26-2011, 12:57 PM   #17
Activity: 7.6%
DEK has one cam sensor. As far as the wiring is concerned I haven't checked the grounds but I will check them.
Engine was running smooth with the new coilpack, no weird noises, the cam timing is correct.
__________________
Youtube
Old 06-26-2011, 04:53 PM   #18
Activity: 7.6%
Added fuel, Reset ECU.
Cranked car, pulled codes.
Got P1320, that's my only code now.
Seems like the CPS REF could be related to this according to the FSM.
__________________
Youtube
Old 06-26-2011, 07:26 PM   #19
ajcool2's Avatar
Points: 19,791, Level: 88
Points: 19,791, Level: 88 Points: 19,791, Level: 88 Points: 19,791, Level: 88
Activity: 2.1%
Activity: 2.1% Activity: 2.1% Activity: 2.1%
Send a message via AIM to ajcool2 Send a message via MSN to ajcool2 Send a message via Yahoo to ajcool2
I would definatly check the wiring on all three sensors first but it sounds to me like it could be a timing issue.
__________________
DCMAX FTW
The Green Lantern 14.98@90mph 60' 2.14 AUTO (Before the 00VI) 170 HP 3140lb w/driver
The Ladies Car 13.58@103mph 60' 2.19 AUTO 210whp, 213wtq DJ 3220 w/driver
The Dark Phoenix 12.05@112mph 60' 1.64 AUTO 348 RWHP DD 3280lb w/driver
ALLGONOSHOW
FASTEST CAR @ MAXUS 2010
Need a part? PM ME I have to much maxima crap sitting around
ajcool2 is offline   Reply With Quote
Old 06-26-2011, 07:37 PM   #20
Activity: 7.6%
Quote:
Cam timing?
__________________
Youtube
Old 06-27-2011, 07:44 AM   #21
5.7 Gen Maxima
SurraTT's Avatar
Activity: 2.2%
Seems weird that the timing would be off as it was running and running fine?
P1320 basically says no spark. so no need to check haaha
Possible Cause
Harness or connectors (The ignition primary circuit is open or
shorted.)
Power transistor unit built into ignition coil
Condenser
Crankshaft position sensor (REF)
Crankshaft position sensor (REF) circuit
Seems like Crank REF signal is not there or not right thus its not firing the coils.
__________________
Old 06-27-2011, 07:46 AM   #22
Activity: 7.6%
Yup that's consistent with what the FSM said.
Now, when the car was running after I replaced the CPS REF, it was only on 5 cylinders, one of the coilpacks grenaded. I replaced the coilpack with a spare I had laying around and my starting issues came back.
I'm gonna take a step back, unplug that coilpack I had originally replaced first, crank the car, and if that doesn't work I will see what I can find where the spark is being shut off at.
__________________
Youtube
Old 06-27-2011, 07:48 AM   #23
5.7 Gen Maxima
SurraTT's Avatar
Activity: 2.2%
hmmm ok, so it MIGHT be a coil pack/ condenser issue / power transistor haha
__________________
Old 06-27-2011, 07:51 AM   #24
Activity: 7.6%
Seems weird that the timing would be off as it was running and running fine?.
THIS. My buddy who did it said he checked the timing 3 or 4 times, rotated the engine by hand and had said if the timing was off at all it would have bent all the valves. AND, it would have made a nasty noises during cranking.
__________________
Youtube
Old 06-27-2011, 09:33 AM   #25
5.7 Gen Maxima
SurraTT's Avatar
Activity: 2.2%
Yeah just sucks something happened w/e it is your car is not running!
goodluck man! i know how frustrating it can be, i haven't driven my car in almost a year!
__________________
Old 06-27-2011, 04:54 PM   #26
Points: 8,576, Level: 62
Points: 8,576, Level: 62 Points: 8,576, Level: 62 Points: 8,576, Level: 62
Activity: 1.2%
Activity: 1.2% Activity: 1.2% Activity: 1.2%
Send a message via AIM to Rood
__________________
Precision injectors 525cc
BBMAF
J Dub bodykit
Profec e01
All for sale
Rood is offline   Reply With Quote
Old 06-27-2011, 05:24 PM   #27
Location: Toronto, Buffalo, Syracuse, Mississauga, Etobicoke
Points: 4,942, Level: 44
Points: 4,942, Level: 44 Points: 4,942, Level: 44 Points: 4,942, Level: 44
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
facebook.com/worldwiderecognized http://ca.linkedin.com/pub/brandon-kershaw/9/146/aa5 TheHarshTruth
I am having this issue. I mean, considering my mechanic told me "this engines f*cked" the car doesnt start anymore after getting a clicking messed up sound from around the timing chain particularly during lower idles. I was getting a clicking sound for a while and really low idle when at lower speeds or stopped and eventually just wouldnt start one day. Cranked but didnt fire up. He said the fuel injectors were getting cut off. because of the timing jumping, etc. So I assume that has to do with the timing chain. I KNOW he doesnt want to do the job. Considering he told me I shouldnt bother putting a new engine in my max. (I have a 95) and he's right. The body doesn't even warrant it. My issue is trying to get reasonable insurance with a new vehicle though. Due to me being afraid they'll check my driving abstract which they havent done in a while.
Is the engine still fixable with a new timing chain kit even after its gotten to the point of not starting up anymore? I found some on Ebay for around 200. So I'm curious. But I assume my best bet is just to pick up another max for like under 1000. And if my insurance doesnt give me a reasonable quote for changing cars over. Then maybe do a swap from it.
Ugh, do I ever hate insurance companies ;P
__________________
··•95/97 ' ·The·Ride·Maxima.orgT.M.E.C.Car.Domain ' SE•··
worldwiderecognized is offline   Reply With Quote
Old 06-27-2011, 07:16 PM   #28
Activity: 7.6%
Update.
Cranked car, no start, tested condenser and grounds, everything looks fine.
When I crank, I smell fuel from the front of the car, not at the exhaust. FPR?
ALSO: When I crank, it cranks consistently but it has a occasional stumble...WTF could this be?
Help appreciated.
__________________
Youtube
Old 06-27-2011, 08:14 PM   #29
Activity: 7.6%
Now I've been told that you can unplug the CPS and try cranking the car, and if it starts with the CPS unplugged, the timing is probably off. Does this include the CPS REF and POS? Or just one of the two?
__________________
Youtube
Old 06-28-2011, 05:08 AM   #30
Points: 5,959, Level: 50
Points: 5,959, Level: 50 Points: 5,959, Level: 50 Points: 5,959, Level: 50
Activity: 0%
Did you check the grounds/wiring?
Shift_Max is offline   Reply With Quote
Old 06-28-2011, 07:15 AM   #31
Activity: 7.6%
Update.
Help appreciated.
Quote:
Yes.
__________________
Youtube
Old 06-28-2011, 09:43 AM   #32
5.7 Gen Maxima
SurraTT's Avatar
Activity: 2.2%
so are you getting spark??
__________________
Old 06-28-2011, 11:07 AM   #33
Activity: 7.6%
Car starts, looks like the CPS POS sensor was loose and wasn't letting it fire.
Next question. Drove the car and it is slowwwwww BUT I'm throwing a P0325 (Knock Sensor).
How do I bypass the KS? Can I use a 470k ohm resistor and put it in line with the KS wire on the engine harness? Or do I have to go to the KS connector under the LIM?
__________________
Youtube
Old 06-28-2011, 12:19 PM   #34
Rochester's Avatar
Activity: 5.6%
So you're back to normal then?
__________________
Old 06-28-2011, 12:34 PM   #35
Rochester's Avatar
Activity: 5.6%
Sorry, 'cef. I see that you're down, so the natural thing to do was kick you. I mean... the door was wide open, man!
Hope you get it figured out.
__________________
Old 06-28-2011, 12:43 PM   #36
Points: 8,422, Level: 61
Points: 8,422, Level: 61 Points: 8,422, Level: 61 Points: 8,422, Level: 61
Activity: 0%
if you bypass the knock and its still slow my bet is the timing chain wasnt lined up with the sprockets. when i put cams in my ser we missed a tooth, car was slow and something seemed off. when we pulled the VC and checked it, sure enough we miss a tooth, fixed it and car ran great. i really hope this isnt the problem cause putting cams in a max is a b1tch..
HotshotVQ35 is offline   Reply With Quote
Old 06-28-2011, 01:32 PM   #37
essential1's Avatar
Activity: 0%
Question... when you drive the car, do you hear something that sounds like little kids throwing rocks at your car? AKA pinging?
__________________
Old 06-28-2011, 02:05 PM   #38
Activity: 7.6%
Armchair mechanics don't have to deal with physical reality of mechanical issues.
Quote:
Keep reading...
I don't hear any pinging when I'm driving or at idle. Here's an update.
I'm getting a P1320 code and it seems like two cylinders on the front bank are NOT getting spark. I swapped coilpacks around with known working ones and the same issue resides. So my car is running off of 4 cylinders (Honda mode).
Any ideas on where I can start the diagnostic procedure for tracking down the misfire? Because the P0325 is relatively easy to fix, but I'd like to get a head start on this miss because it is apparently not the coils.
__________________
Youtube
Old 06-28-2011, 06:27 PM   #39
Activity: 7.6%
Misfire GONE.
Next step is bypassing the KS. Can I get yall input?
This goes as follows...
Pull UIM/LIM.
Put 470k OHM resistor into subharness.
Does anybody have pictures of how this bypass goes?
__________________
Youtube
Old 06-28-2011, 06:42 PM   #40
5.7 Gen Maxima
SurraTT's Avatar
Activity: 2.2%
what was causing the misfire?? just bad coils?
__________________
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
