Power window trouble
So my rear driver-side window will go down but not up. The main switch at the driver's seat will not move the window either way but that rear driver switch will make it go down and not up.
I removed the rear driver switch and used it on the rear passenger window and it goes up and down.
I used the rear passenger switch on the rear driver window and same problem, down but not up.
What is causing this problem?
I can hear a click coming from the motor area when I press the switch down but no sound when switched up.
Hmm... when you swapped the switches, did you put the one from the right-rear into the front-right door? How does it function now? You need to isolate the switch circuit from the regulator motor. Once you do that you can locate the "up and down" terminals on the Right-rear window, and supply 12V to them (ground on one and positive on the other). It should move which ever direction. Then reverse the polarity (reverse positive and ground) and it should move the other way.
Having the same problem with front passenger window goes down and after a while it will go back up, its like has power then nothing all the other windows are fine though......but haven't tried to fix the problem yet..so good luck...
Any updates? How are you getting the window to go back up so that you can continue testing? From what I've read, the driver side main switch can cause problems with all windows, not just the drivers window. You may want to pull it out and inspect it, see if you can see anything wrong with it, some find traces in the board that are fried. If you have access to another maxima, you could try swapping the switches, it only takes two minutes to get them out - its just one screw.
I happen to find few threads from sometime back and some mentioned simply cleaning glass windows and window side rails with armor all type of cleaning solution, and I happen to had both products at hand and I just did that, and it has improved my windows very well. Although I'll prob. do grounding kit at some point, this has def. made me happy.
mhmmm maybe someone could help me? My windows go down ok but comen back up seems like a struggle it goes up very slowly and it makes a sound like its scratching the glass but its not.. any idea what it is? could it be the motor? or possibly just rust and gunk build up? my max has 216k on it lol
They can be fixed, someone of your abilities could likely do it, but it's more effective to just pick up a new one. I have one here actually PM me if you find the Master to be the issue Prof.
