2k maxima
2k maxima
When i turn key to second position(all lights light up on dash) there is a loud buzzing noise coming from engine bay it seems to be around the tranny area. It sounds i like a high power transformer. I haven't check it out yet but gonna check relays first any suggestions?
It could very possibly be your electronic motor mounts( if you have an automatic). They tend to buzz when they are going, and when they go they can fry your ecu. Just disconnect them. They will not cause any harm disconnected.
Most likely our electronic motor mounts.
Heres a good thread on it:
http://forums.maxima.org/5th-generat...e-startup.html
If the buzzing continues after you shut off your car, its getting bad and you can unplug them if you want (not a bad idea because when they go for good, then can fry your computer on the way out).
I believe there is a relay related to the fuel pump priming in the left kick panel that gets noisy and buzzes. I've replaced in other Nissans but not a Maxima. Mines not loud. I wait everytime for the fuel pump to prime in every car I drive. It ended my random misfire code CEL.
