Lower front radiator support replacement?
Old 03-29-2011, 09:42 AM
woosh's Avatar
Greets,
My lower front radiator support is quite rusted and needs replacement. I've seen the threads with various patches vs the right way to replace it. (remove a major portion of the front section, drill out the old front support and weld in the new).
Does anyone know a reputable place in NYC that does this job and approximate cost (assuming I provide the new replacement front support)?
woosh is offline
Old 03-29-2011, 10:39 AM
Suspension Yoda
djfrestyl's Avatar
Put a post in the northeast section, you'll find some local installers there.
It's actually not that hard, just time consuming. Perhaps something you can tackle yourself on a weekend.
djfrestyl is offline
Old 03-29-2011, 12:13 PM
nissandrvr98's Avatar
mines trashed...the connecting bracket that bolts in to the lower rad support and up to the hood latch is no longer even attached its gotten so bad. I plan on pulling the front bumper, cleaning it up and treating the rust then patching with aluminum and fiberglass at some point this spring/early summer.
i had a local body shop (central pa) quote me about 300ish after they peeked at it if that helps at all.
nissandrvr98 is offline
Old 03-29-2011, 12:15 PM
Suspension Yoda
djfrestyl's Avatar
^^ If you're doing all that work, just replace it. The amount of work to chisel off the old one and install a new one is equal to that of working with aluminum and fiberglass.
CRizz
41
06-07-2021 05:42 AM
HOKUSMAX
11-13-2017 04:34 AM
vingodine
45
05-21-2016 12:46 PM
maxinout93
10-27-2015 01:29 PM
homeyclaus
09-03-2015 06:15 PM
Quick Reply: Lower front radiator support replacement?
