How to replace Transmission Control Solenoids 5th Gen
Old 01-17-2015, 03:34 PM
philsmax00's Avatar
2000 Maxima SE, 4 Spd Auto, RE4 Trans.
I recently got a P0740 code (TCC error, Torque Converter Clutch Solenoid suggesting no Torque Converter lock-up).
I did the resistance check and found 2 ohms (specs say 5 - 20 ohms) so I ordered a new solenoid pack.
I have the trans. pan off but not sure how to install the solenoids. Do I need to remove the valve body to do that?
I appreciate any tips, procedures, links etc.
also: How to shift to Neutral with battery disconnected?
philsmax00 is offline
Old 01-17-2015, 04:18 PM
george__'s Avatar
Oh do the transgo kit while in there
check the FSM
http://www.nicoclub.com/FSM/Maxima/2000/
at.pdf
There should be override button on the shift **** somewhere to allow you to shift gears
george__ is offline
Old 01-17-2015, 05:47 PM
philsmax00's Avatar
manual and button
Hey, thanks George.
I gotta good idea what I need to do now from the FSM. And also the shift release button info - tricky.
Have a good one!
Old 01-17-2015, 07:02 PM
george__'s Avatar
Originally Posted by philsmax00
Hey, thanks George.
Have a good one!
Get a TRANSGO kit!
http://www.transgo.com/products.php?...dcountview=Yes
Don't go HD, it 's a bit much for daily driving imo.
george__ is offline
Old 01-17-2015, 08:17 PM
philsmax00's Avatar
Transgo
Transgo Kit looks like a good idea. Thanks for the tip.
Old 01-22-2015, 03:43 PM
philsmax00's Avatar
Where to buy TCC Solenoid
Looking for just the TCC Solenoid, not the whole pack. I saw this item for sale somewhere, can't find it now.
Anyone know where these can be purchased?
thx
Old 01-22-2015, 04:08 PM
Da Roller Coaster!
foodmanry's Avatar
Dear god...the OP doesn't need a transformation kit.
Yes you need to remove the valve body to replace the solenoids.
Procedure linked below. PM me if you have problems opening link.
https://www.dropbox.com/s/8igh8ozand...-039a.pdf?dl=0
foodmanry is offline
Old 07-27-2015, 05:52 PM
philsmax00's Avatar
Thanks FoodMan! Just saw your reply today. I went ahead and replaced the whole solenoid pack. About $150 if I remember right. Shifts perfect now.
CRizz
41
06-07-2021 05:42 AM
Finkle
09-27-2015 09:53 PM
SmokinMax02
18
09-11-2015 12:25 AM
doobadoo
08-15-2015 06:43 PM
Tanvirkamal
08-05-2015 01:32 AM
Quick Reply: How to replace Transmission Control Solenoids 5th Gen
