Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Sign in using an external account
Register Forgot Password?
Register Photos Classifieds FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Sponsored by: Simple Tire
Click Here
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 02-21-2011, 02:33 PM   #1
Car wont start ...
I got a 01 Maxima and last week it decided not to start . I check all the sensors (crank , cam etc ) One thing i notice is when i take the plugs out they are soaked with fuel .It will crank but wont turn over the starter is new . If i wait couple days it would start up one time after that no more . It seems like there is too much fuel going to the motor . I even change the fuel pressure regulator . Did anyone had this problem or know whats going on . Thanks
vinh512 is offline   Reply With Quote
Old 02-21-2011, 05:56 PM   #2
Points: 5,597, Level: 48
Points: 5,597, Level: 48 Points: 5,597, Level: 48 Points: 5,597, Level: 48
Activity: 2.6%
Activity: 2.6% Activity: 2.6% Activity: 2.6%
Any SES codes? When was the last service done on changing the spark plugs?
__________________
Sig. Rendered By Rochester
Llumar 20% /FSTB /SRI /BPI Stack /*17 Adv. /ATE Slotted Rotors & ATE Pads / 6000k HID Fogs /2x10 Subs & 1000w amp. /Michelin 235/45/17 /Budget B pipe & Vibrant Exhaust /LED Interior Lighting /Chrome Gauge Rings /Viper Security /F&R ES MM & Sub Bushings /Sm Markers /KYB GR2's-S-Techs /Cus block plate-VIAS del /NWP Spacers /Stillen Lip & Rear Valiance
Open to all Connections On LinkedIn
Maxima's FSM's
Owensfamily TSB's
Nissan "How To"
Ghost_54 is offline   Reply With Quote
Old 02-22-2011, 03:51 PM   #3
No Codes and the plugs was changed about a year ago . I smell alot of fuel when i try to start
Old 02-22-2011, 06:50 PM   #4
Activity: 2.6%
Well I keep thinking of possible reasons, 1. the spark plugs are bad or perhaps need to be re-gaped (possible carbon build up) or simple replace them 2. Sticky fuel injector/or multiple sticky injector do to a build up of gum or carbon.
So you can inspect the plugs again, as you said they are a year old, you could also run Chevron Techron Fuel System Cleaner in your gas tank to see if it will help free up your injectors ... or even run a bottle of seafoam in your gas tank.
__________________
Maxima's FSM's
Owensfamily TSB's
Nissan "How To"
Old 02-22-2011, 06:54 PM   #5
Points: 11,052, Level: 69
Points: 11,052, Level: 69 Points: 11,052, Level: 69 Points: 11,052, Level: 69
Activity: 0.6%
Activity: 0.6% Activity: 0.6% Activity: 0.6%
Send a message via MSN to Professor Send a message via Yahoo to Professor
any security light ?
__________________
SHIFT_auto rolling
Professor is offline   Reply With Quote
Old 02-22-2011, 07:04 PM   #6
Points: 2,309, Level: 29
Points: 2,309, Level: 29 Points: 2,309, Level: 29 Points: 2,309, Level: 29
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Mine did this last night actually. All i did was the ecu reset procedure and it fired right up! followed the reset procedure here: http://forums.maxima.org/5th-generat...tting-ecu.html
Cant hurt anything to try that. Its the procedure listed in the first post
ahilto3 is offline   Reply With Quote
Old 02-23-2011, 11:25 AM   #7
Points: 4,662, Level: 43
Points: 4,662, Level: 43 Points: 4,662, Level: 43 Points: 4,662, Level: 43
Activity: 0%
Send a message via MSN to J-Rod
You know you can't gap plat. or ird. plugs right?
__________________
Jarrod
2000 Maxima SE
White Pearl
the daily driver....
Added new to the stable:
2010 Dodge Challenger Mopar '10 Special Edition (#356 of 500)
Brillant Black Pearl Metallic
Blue Stripe
5.7l
6 speed Hurst Short Throw
Catch Can
Predator Tune - ~420HP(crank), waiting on dyno tune
180* thermo
J-Rod is offline   Reply With Quote
Old 02-23-2011, 11:59 AM   #8
Points: 5,120, Level: 45
Points: 5,120, Level: 45 Points: 5,120, Level: 45 Points: 5,120, Level: 45
Activity: 0.6%
Quote:
You can gap both; plats are easy, iridiums are pretty brittle and will chip if you don't treat them nice. But both should be pre-gapped when you buy them.
Regarding the OP, if car is not starting it would be normal for 'extra' fuel to be in the combustion chamber. I think the issue is the ECU or a crank sensor. You said you checked the sensors; how can you tell if one is good or bad?
__________________
2002 Maxima SE 6MT Sterling Mist, SOLD at 114k mi
Free STS mod, Progress RSB, fleabay FTSB, tint.
1996 Maxima with 185,000 miles (son #2)
1997 Maxima with 104,000 miles (son #1)
2004 Mustang V6 coupe, 78,000 miles, Auto
2010 Mustang GT Cnv,14k miles, 509hp, crazy mods
http://dreammustang.com/
trooplewis is offline   Reply With Quote
Old 02-23-2011, 12:06 PM   #9
Activity: 0%
My wording was probably incorrect you "shouldn't" gap...
__________________
Jarrod
2000 Maxima SE
White Pearl
Blue Stripe
5.7l
Catch Can
180* thermo
Old 02-23-2011, 12:17 PM   #10
Activity: 2.6%
Your probably correct about not wanting to re-gap the plugs, I had only made that suggestion from what I had read on the OP, not being able to start the car and find heavy amounts of gas in the plug area. One of the suggestions in that article for the gas being there was that the plugs could be "old" and the other was they may not be gaped correctly. The other area raised in the article was possible plugged fuel injectors, as the reason for the lack of ignition. So hopefully the OP at least has a couple of option to at least investigate.
__________________
Maxima's FSM's
Owensfamily TSB's
Nissan "How To"
Old 02-23-2011, 12:26 PM   #11
dot dot dot ...
NmexMAX's Avatar
Points: 43,420, Level: 100
Points: 43,420, Level: 100 Points: 43,420, Level: 100 Points: 43,420, Level: 100
Activity: 59.1%
Activity: 59.1% Activity: 59.1% Activity: 59.1%
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
I've never pre-gapped any of my plugs for my 4th or 5th gen
Maybe an o-ring leak .. little strange for all or more than one to leak at the same time .
__________________
03 SE 4AT 257whp/245wtq
95 SE 4AT 245k Miles
08 Pathy LE 5.6
Items FS:
FastCat/WB's/Bearings/Dual IM gaskets Rear Progress Springs
NmexMAX is offline   Reply With Quote
Old 02-23-2011, 01:47 PM   #12
I actually change all my sensors to be on the safe side . And still no luck . and i also replace the plugs too . I'm lost . im gonna try reprogramming the ecu and see if thats goona help . And also no security light
Old 03-10-2011, 12:27 PM   #13
similar problem other then the injectors spraying any fuel. your sounds moor like a spark issue mines seems moor like fuel issue. Either way same symptoms. me and my brother replaced the cps and both css sensors. still no luck. The check engine light isnt on either. We have no way of knowing if there is any codes in the ecu right now with out having it told somewhere. I posted this in the newby section. I hope you get yours figured out.
Im no mechanical but have a lil experience with cars. My brother has a 5.5 gen maxima. He started the car after sitting all day. Drove it about six blocks and it cut off on him. It hasnt started since except with starter fluid. We hear the pump. I took off the fuel pressure regulator to see if it was getting fuel at the rail, which it is. I know its getting spark because it will start with starter fluid. It has had the recall done on it. We replaced both css and the cps sensors. Still wont start. Next we will take off the maf sensor and clean it. Since it is getting fuel at the rail as will as it will start with starter fluid which is means its getting spark. The only thing I can think of is the ecu isnt allowing the injectors to spray for what ever reason(sensor ect.). any help would be greatly appreciated. Thanks and thanks for having this great forum.
rastagunns is offline   Reply With Quote
Old 03-10-2011, 01:15 PM   #14
TunerMaxima3000's Avatar
Points: 15,752, Level: 80
Points: 15,752, Level: 80 Points: 15,752, Level: 80 Points: 15,752, Level: 80
Activity: 30.1%
Activity: 30.1% Activity: 30.1% Activity: 30.1%
His car is a 2001, he clearly stated that, can't just 'reset' ECU.
And Unless your car has had the battery unplugged a lot for a long time, it can take up to 48 hours of having the battery disconnected to clear the ECU.
It's not a bad idea if you can spare a day or two.
Quote:
Sensors throw codes 90% of the time or more. I'm sorry to hear you wasted your time and money changing them.
Now, to address your OP, I have some questions:
1. Does the car bog/chug or try to start at ALL? Or does it JUST crank and nothing else happens?
(if it's ONLY cranking, it's not likely plugs or fuel delivery)
2. Have you tried adding a ground to the starter? Another starting problem-replaced just about everything
A bad IAT can cause this symptom IIRC also. But I'm leaning toward poor starter ground.
__________________
'03.5 6MT G35:
395 WHP & 340 WTQ|SiTrim Vortech V3 |3.12" Pulley|Res. TestPipes|Haltech PlatPro w Dual WB|PnP'd 3 piece intake|MD IsoThermal Spacers|GT-R 570cc Inj.|Fidanza FW & Stg 1 Exedy Clutch|Akebono 14" BBK Drilled/Slotted|RS*R Coilovers|SPC CamberKit|05/06 Tails|Custom Trunk|CustomGaugeFace|Custom Colourchanging LED Interior|Nismo Skirts|JDM Mirrors w CustomAutoFold & Custom PuddleLights
TunerMaxima3000 is online now   Reply With Quote
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
