Cheap Double Din Trim? Step in please...
Old 02-17-2011, 10:35 AM
TunerMaxima3000's Avatar
For everyone that has this cheap piece of crap trim piece:
Has anyone found a way to combat the ridiculous bulge at the bottom of the trim piece???
I tried superglue, didn't hold.
I'm out of 3M double sided tape I was going to try that next.
And either one of those ideas will make taking apart the stereo/ACC, etc a huge pain.
I managed to get the top sitting flush (got rid of the huge 'step') with some superglue, it's not perfect but it's better for sure. I will probably make it all one piece with epoxy and paint it, but I'm not going to bother if I can't get the bottom sitting right as well.
I know about the GXE kit, I don't have $130+shipping to Canada for a trim piece. I may end up going this route later on, but I want to give getting the cheap piece fixed a real shot first. Maybe it's foolish I dunno.
Pics for clarification, I'm talking about the bulge in the center:
And the top, superglued flush:
TunerMaxima3000 is offline
Old 02-17-2011, 10:50 AM
phatboislim's Avatar
i just bought a GXE dash from Deckdout2...cant wait to install it this weekend
phatboislim is offline
Old 02-17-2011, 11:24 AM
How much? PM if you want. Only place I was aware of for the OE kit was Courtesy. I tried checking with Dave B but no response.
Old 02-17-2011, 11:36 AM
i can put you in contact with my nissan guy in Hilton Head, SC...Deckdout2 was just doing a partout. but if you want let me know and ill get you his phone number and ill let him know you're going to contact him about a GXE dash kit so he'll be on the look out to hear from you
Old 02-17-2011, 12:04 PM
Yup PM it to me bro worth seeing what he can do for price at least. For now still trying to figure this out.
Old 02-17-2011, 12:35 PM
5 ltr. beater's Avatar
im wondering if your trim is just a piece of crap to begin with; and maybe you shud just get another one. i dont have any bulge on the lower part of the trim. mind you it doesnt sit flush with the climate control unit but it doesnt bulge out like yours. thats horrible. and mind you i only paid $16 dollars for my kit.
5 ltr. beater is offline
Old 02-17-2011, 12:53 PM
mine sits just like his does..its the metra kit i believe...
Old 02-17-2011, 01:15 PM
kiyakerz's Avatar
Would trim from a maxima with navigation work?
kiyakerz is offline
Old 02-17-2011, 02:05 PM
luvlexus101's Avatar
Tuner which dash kit are you using. If you got the scosche with the cheap plastic brackets, you could slide the hvac a bit forward - no?
luvlexus101 is offline
Old 02-17-2011, 02:20 PM
Froggmann's Avatar
Have you tried applying heat? A few minutes with a hairdryer on low should get the plastic to soften up just enough to flatten it out.
Froggmann is offline
Old 02-17-2011, 02:46 PM
Should be the same as the GXE kit I mentioned.
I just looked at the Pic from Courtesy Nissan for it, http://www.courtesyparts.com/vent-ctr-p-396441.html
It looks tapered???? Can someone clarify this for me?? Is the OEM Navi screen tapered or something? Cause I don't want that.
I think it is, I got it from a member with the busted up Pioneer Navi that I'm trying to sell locally. I'm not 100% sure what make it is.
The HVAC won't slide forward though it's mounted to the bracket, and doing so wouldn't fix the 'bow' anyhow unfortunately.
This is a really good idea, I'm going to give that a shot. Will post back with results.
Old 02-17-2011, 04:17 PM
thats what im using. the scosche kit.
Old 02-17-2011, 04:27 PM
^hmm well maybe it's not then... I dont know would need other members imput of their kits/issues to verify.
It seems that the 'bar' across the bottom is just a shade too long causing it to bow a bit when installed. I'd hate to have to cut it but that's an option too.
Anyone able to paint match the trim colour or is it close to impossible?
Old 02-17-2011, 04:37 PM
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
sparks03max's Avatar
Gotta be tough since you'd have to match the texture as well.
sparks03max is offline
Old 02-17-2011, 05:36 PM
Yeah I figure if I go for paint I'll have to do everything. I don't mind the stock look though it matches the tones in the rest of the car perfectly. Anything else would be a bit 'off'.
I'm going out to try the heat method the little man is sleeping finally. Will post back.
Old 02-17-2011, 06:19 PM
20 Points to Froggmann.
Heat + SuperGlue = No more bow. Just be careful with the heat, test on the backside first to get a feel for it. This kind of heat will warp, melt and disfigure the plastic all to hell. You want to stop just before that happens
Random in case you didn't know, if you remove the blue covering off the ACC bulbs everything turns Orange. Kind of cool but not the route I'm going, I'll be LEDing it soon:
Thanks again Froggmann, hope this helps others.
I will see how it looks in the daytime. I may try to live with it, it's doesn't look too bad now.
Old 02-17-2011, 07:52 PM
BoDenKai's Avatar
wait so the bulbs are orange with a blue thingy on themZ?
BoDenKai is offline
Old 02-17-2011, 08:07 PM
No^
The bulbs are white. The tinting/filter on the housing makes it orange. I guess the blue tint makes them green.
They are much brighter with it removed too.
Old 02-18-2011, 04:31 AM
i think i'm going the amber route...thanks for the heads up tuner LOLOL
Old 02-18-2011, 06:07 AM
No^
Yep, tuner you planning to custom led it or plug and play some of the twist lock bulbs
Old 02-18-2011, 07:32 AM
^Custom - I've already ordered too many various LED items, and I want a white/blue look if I can pull it off also.
Slim- I thought that would help someone. If my HU wasn't green/blue I'd be all over the Creamsicle colour scheme (white/Amber/orange), would be VERY original and downright beautiful.
Old 02-18-2011, 07:33 AM
yea...i'm going to do that for mine...with the speedo...is there anythign i need to be aware of when removing it. something i need to be careful of not disconnecting?
Old 02-18-2011, 09:52 AM
You're going to do the orange/amber?
You are going to have a tough time getting the gauges that colour, the backing has a blue tint as well as the gauge faces themselves. You need to calibrate the speedo before taking the needle off, FAQ/DIY has the link for that procedure. I was going to grab it for you but can't find it quick enough.
Old 02-18-2011, 09:55 AM
with that said, count on it staying stock lol
Old 02-18-2011, 11:08 AM
I'd do it if it werent for the HU would look freaking amazing, and probably the only one too.
what an OT day
Old 02-18-2011, 11:58 AM
Froggmann's Avatar
No problem I have had remold a few things to get them to work in the past.
As for the paint, according to this thread Duplicolor Storm Gray is a close match.
Old 02-18-2011, 02:02 PM
Can't tell at all from that pic. Other than it's definately different, maybe close enough to work if I paint all the components in the center console.
No texture, any appearance of texture is just in the paint. There is a serious flake/metallic effect in the OEM paint though, and I don't imagine matching that will be possible.
Old 02-18-2011, 03:52 PM
Froggmann's Avatar
Yes the texture of the paint is near impossible to replicate. Even wiht the Scorsche kit they have the color close enough but the texture is way off.
Old 02-18-2011, 04:19 PM
^is that the Scosche kit? If so, mine is definately not that kit, that looks clean, the lines follow much better, and the cutout for the HU is actually the right size.
Anyone able to verify the taper on the GXE kit I was inquiring about???
Old 02-18-2011, 06:07 PM
zzmmrx0xmzz's Avatar
Looks nice now that its flush!!
zzmmrx0xmzz is offline
Old 02-18-2011, 06:26 PM
^I need to pull it off again and re-do it, it's not holding at the top 100% because I messed with it so much after. I am going to wait until I pull it all apart for LED's though.
Still want to know about the GXE kit I can't imagine it's tapered like it seems to be in that pic. Strange.
Old 02-18-2011, 10:28 PM
Froggmann's Avatar
Yes, and it's about $20 dollars at amazon. The Plastic bracket is a little flimsy when you install it but all you have to do is hold your HU up while you tighten the top screws. Also, I used the most forward mounting position for the HU and HVAC controls.
I can't verify the taper for you but I did find a few good photos of an installed GXE kit:
Old 02-19-2011, 04:04 AM
Thanks for the verification on that man.
I'm saying forget that looks like they had to put another piece behind it to eliminate the gap caused by the taper... it doesn't look proper either.
This sucks I thought that GXE kit was the answer to our poor trim issues.
Old 02-19-2011, 03:24 PM
nismonegro26's Avatar
Hey, I have the same Scorsche kit and the same avh 3200dvd and I have a gap between the trim piece where the radio sits and the air controls. How were you able to get the gap out? I had a dual din kenwood and never had that gap until I bought the pioneer.
nismonegro26 is offline
BobTX10
10-07-2015 08:43 AM
Dennis Twohy
10-01-2015 06:01 PM
worldwiderecognized
09-30-2015 01:16 PM
Quick Reply: Cheap Double Din Trim? Step in please...
