Anyone use an oil drain valve?
Old 12-30-2010, 05:01 AM
  #41
phatboislim's Avatar
this is awesome...i think ima get one. i change my oil frequently too. BTW i hate synthetic, my car burns way more with it
phatboislim is offline
Old 12-30-2010, 06:22 AM
  #42
Stormzusmc's Avatar
Originally Posted by SteveB123
As opposed to the "pipe threaded" valve you suggested above.
Pipe thread is tapered, and seals in the threads.
Straight (non-tapered) thread seals at the gasket.
though its not actually standard npt, not all pipe thread is tapered some are actually straight....
in my case i pulled a couple valves out of my lawson bins and found one that fits and does not leak
Stormzusmc is offline
Old 01-01-2011, 12:48 AM
  #43
RR5
RR5's Avatar
Happy 2011, I might pick up one. Finally easier oil changes at home!
RR5 is offline
Old 01-01-2011, 05:12 PM
  #44
trooplewis's Avatar
I did 3 oil changes today in my driveway, and installed the valve on my 5,5 Max.
On a downside,. when I changed the oil in my kids 175,000 mile 1996 Max, the oil came out looking like frothy chocolate milk. See the 4th Gen forum for more on that problem.
Anyway, thought I would post a few photos of how the valve looks installed. It is an easy fix, the same 14mm socket that you use to remove the plug will also install the valve.
Still draining, valve open
Valve closed
The valve protrudes below the oil pan by about 1/2"
trooplewis is offline
Old 01-01-2011, 06:10 PM
  #45
Reece616's Avatar
are those pics of your 5th gen or the sons 4th?
Reece616 is offline
Old 01-01-2011, 06:19 PM
  #46
trooplewis's Avatar
Sorry for the lack of clarification, the valve pic are of my 2002 5.5Gen Maxima SE 6MT
Old 02-09-2011, 08:46 PM
  #47
RR5
RR5's Avatar
Picked up the S type with the smaller nipple and plastic fitting which includes the 3 foot hose. Everyone who changes their own oil should get one, no more draining oil into a catch pan then pouring into a container to take to the recyclers.
RR5 is offline
Old 02-10-2011, 05:04 AM
  #48
not too bad...where'd you buy from again? SN: kinda worried even though i'm not 'super slammed' i'm pretty low..only thing that would worry me is it getting caught on something on the highway
Old 06-09-2011, 12:16 PM
  #49
CTMaximaSE's Avatar
[quote=trooplewis;7862210]For $23, I've been thinking about buying one since I drive 3000+ miles per month so I do about 14 oil changes a year in my driveway.
Any downside to the valve?
What type of oil do you use? Have thought about using synthetic motor oil, that cut your change time in half.
CTMaximaSE is offline
Old 06-09-2011, 12:40 PM
  #50
TallTom's Avatar
Like raised manhole covers on roads that are under construction.
TallTom is offline
Old 06-09-2011, 01:43 PM
  #51
RR5
RR5's Avatar
Actually the idea of using one of these drain valves with a hose didn't work in my application.
With the hose, the oil did not flow out freely. After trying and trying, I gave up and went back to draining into the catch pan. However, no more copper crush washers. Just open the valve, drain into pan and done.
RR5 is offline
Old 06-09-2011, 04:25 PM
  #52
trooplewis's Avatar
Some months later, I'm thinking the valve is somewhat of a waste of money. It does make it easy to get the oil directly into a jug, and you need to have the engine pretty warm ot that takes awhile.
BUT when you remove the oil filter, you still are going to get a big oil spill so you still need a drain pan/container. It just doesn't have as much oil in it as if you drained it all from the start.
Old 06-09-2011, 08:09 PM
  #53
RR5
RR5's Avatar
I agree however the drain valve makes replacing the copper crush washer a thing of the past.
RR5 is offline
mclasser
22
11-12-2020 01:58 PM
06-06-2017 02:01 PM
Forge277
06-13-2016 09:26 PM
tseng1023
10-15-2015 08:30 AM
hayne
10-05-2015 11:53 AM
Quick Reply: Anyone use an oil drain valve?
