Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 12-16-2010, 05:04 PM   #1
Points: 4,719, Level: 43
Points: 4,719, Level: 43 Points: 4,719, Level: 43 Points: 4,719, Level: 43
Activity: 7.4%
Activity: 7.4% Activity: 7.4% Activity: 7.4%
How to test bad ignition coil???
After replacing the #5 cylinder coil about a month ago I have the P0300 again ... the first time I actually took all 6 coils out and tested them with the volt meter I just came across a video online that shows a different method... Just wondering if anyone else has tried this.
http://www.youtube.com/watch?v=z37jl4HXQjg
L_U_D_I_AMaxima is offline   Reply With Quote
Old 12-16-2010, 05:59 PM   #2
I too had code P0300 and thought that the coils were bad. I tested them and all were ok. I cleaned up the TB and cleared the code. That fixed it. If your idle is low it will throw that code b/c of misfiring. If your car is a 2000-2001, you should check the iacv or the throttlle pos sensor. Also try to clean the TB.
__________________
2K2 SE 6 spd. " BLACK THUNDER "
realtor is offline   Reply With Quote
Old 12-16-2010, 08:26 PM   #3
Activity: 7.4%
about a month ago when I was testing all coils I also replaced the oil, filter, cleaned the K&N filter, cleaned the cold air intake and also the TB, even that the TB looked pretty good for a car which has 167,xxx miles. I know that it is a misfire because this morning when I started the car I got outside to clean all the snow from last night, about 5 min after I fired the car I was still cleaning it and I could clearly hear the car misfire ... probably tomorrow I will run outside and do the test with unplugging the connectors also about a week latter i had another stored code P1320..
Old 12-16-2010, 08:30 PM   #4
Activity: 7.4%
I am pretty sure that I am dealing with another bad coil here again... for the past week the temperatures here in Ohio were crazy low, a few morning after starting the i check the tem outside and somewhere between 8 to 10 crazy cold, but the car cranked and started with absolutely no hesitation but then after a few min it will cut/misfire sometimes it even happened while I was driving mainly in second gear
Old 12-17-2010, 08:59 AM   #5
Points: 9,834, Level: 66
Points: 9,834, Level: 66 Points: 9,834, Level: 66 Points: 9,834, Level: 66
Activity: 16.9%
Activity: 16.9% Activity: 16.9% Activity: 16.9%
Been having a little mixture here and there haven't checked nothing out yet but will do what you've tried cause think I got a bad coil also.
__________________
http://youtu.be/ZcAj1ffamM8 3'' Cattman Exhaust
http://youtu.be/Icm7djbfUdMR Rev Up Full Cattman
231whp/226wtq
Rods03Max619 is offline   Reply With Quote
Old 06-05-2011, 03:07 PM   #6
Points: 9,299, Level: 64
Points: 9,299, Level: 64 Points: 9,299, Level: 64 Points: 9,299, Level: 64
Activity: 8.7%
Activity: 8.7% Activity: 8.7% Activity: 8.7%
for those who are trying to save some $ on coils, I just got a BWD (Part No E393 ) coil from Advance auto for $40 for front, they are $63 regular use coupon "BIG25"
you can get coupons at (just type advance auto in search field)
slickdeals.net
example
http://slickdeals.net/forums/showthr...id=0&t=2908107
there is also there sale on Actron AutoScanner OBD II Code Reader (Part No. CP9575) came out at $70 (use 30% off on $100, the scanner is 99.99 so you will need to get something for $1 to get to $100)
arlan is offline   Reply With Quote
Old 06-08-2011, 08:09 AM   #7
Points: 5, Level: 1
Points: 5, Level: 1 Points: 5, Level: 1 Points: 5, Level: 1
Activity: 0.3%
Activity: 0.3% Activity: 0.3% Activity: 0.3%
I can tell you this, DO NOT user aftermarket coils, they will not take away the SES light. i found that out the hard way, you have to buy OEM nissan coils only. and they can't really diagnose one coil, you really just have to replace them all.
jebbs1 is offline   Reply With Quote
Old 06-08-2011, 08:55 AM   #8
Points: 8,422, Level: 61
Points: 8,422, Level: 61 Points: 8,422, Level: 61 Points: 8,422, Level: 61
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Quote:
wrong
__________________
2012 wrx
320/333 18 psi
E85 #'s days away
HotshotVQ35 is offline   Reply With Quote
Old 06-10-2011, 07:05 AM   #9
Activity: 7.4%
about a month ago I end up calling Dave B and ordered 6 new coils (gray dot)
My car is back to normal now, after taking a 3,000 mile trip with the in-laws not problems, no lights, no hesitations, great gas millage close to 450miles on full tank of gas with 4 people inside the car and trunk full to the top, the car looked like it has a 3inch drop on the back
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
