350z injector ?
350z injector ?
i was just curious as i am able to pick up some 350z injectors. Guy says they are 03-06 g35, 350z injectors. From what i read our injectors are 315cc and the 350z are 335cc. what im wondering is will the 350z connector fit the harness of an 03 maxima?
Ok thanks Nmex that basically all i needed to know. Let me ask you your opinion. I have the CAI, gutted precats, ssim and ported u and lim, ground kit, and i will have a new SAFC2v soon and will be getting at least a 2.5 inch exhaust come spring. Once i get the SAFC i will do the BBMAF as well. From my reading adding fuel via the SAFc retards the timing . My thought is to get the bigger 350z injectors and be able to pull fuel to lean it out and add timing. With all that i am gonna have (no headers in future as far as it is now) is it a waste to even do the 350z injectors or is it a good idea and will it give some added power over everything else?
It's a 'ghetto' or 'poor man's' way of 'tuning' (probably shouldn't even be considering a tuning method), but, at the time i was setting my car up, it was the easiest and most 'available' option around. So yeah, sure you've got all the accessories (WB, and soon to have BBMAF/SAFCII).
I got mine for 90$ shipped, you could probably get them for cheaper these days, since I got mine a long time ago.
So does this do anything at all in terms of power or just more gas wasting? Also when you say bolt right up does that mean really just bolt and go or is there anything ECU or other related that needs tuning?
If you use a program that has a separate injector & ignition harness, you don't need this.
VQ30DE: 259cc
VQ30DE-K: 290cc @ 3.0 BAR (FBJC100)
VQ35DE: 315cc @ 3.5 BAR (FBJC101, FWD versions)
VQ35DE: 335cc @ 3.5 BAR (FBJC100, 350z etc.)
In order to take advantage of this 'method' you would need to up your FP.
This.
jmlee44
10-02-2022 02:13 PM
04-16-2020 05:15 AM
knight_yyz
11-01-2015 01:34 PM
