Strange sound and car choking at 2500+ RPM
Hey guys i have this annoying problem at every gear when i press the pedal all the way down, usually it like at 2500 RPM and on. my car is 2001 Maxima MT transmission any suggestions.
i changed it up, got a new 1 paid $80 for it and its still there. its like the car has loss of power or getting choked and also jerks back and forth a bit. i don't know what else to do, i took it to a shop my friend connected his computer checked it out everything fine but the only code that i get is missing cat because i took it off.
Somehing like that, a bit hard to explain when I floor it it'd like wants to go but something is holding it back. It's sound like wuuuuuuuuuuur when I floor it. Oh and I have 130k I don't think I changed the sparks yet...
I cant get u a clip it only happens when I drive... As far as mods I have a injen cold air intake. i did change the ECU since the original one Fed up on me. changed the transmission about a month ago with a new clutch and fidenza flywheel. that's all i can think off.
You have to provide a good basis and highly descriptive so people aren't shooting in the dark.
Personally sounds like maf. Is do the idle relearn. After id thoroughly check
The maf wiring and actual maf thermistor
sorry guys i completly forgot i posted a thread for my friend who had the same problem in his 4th gen Maxima >> http://forums.maxima.org/4th-generat...ut-im-dee.html << now i have the same problem with my Maxima (except the heating up part), i changed the fuel pump, and the maf and this problem is still here. i'll loose power at 2500+ rpms. There's no warning when it's gonna happen....I'll just be driving and all of a sudden it just burbles and won't go.
OP: worst description of the problem ever. So it sounds like the problem doesn't happen all the time. Does it seem to happen more then the motor is hot?
Couple things to check: crank position sensor (since you just did a flywheel and clutch), ground, coil-packs.
S
S
@ maximase86 possibly when its hot but im not sure, like this morning i got in warmed it up and drove to work. i was ripping it all the way to work trying to see if the problem was still there, for a change there was no sign of the issue. plus i had this problem prior to transmission change fly wheel and clutch.
@Rods03Max619 i did go to see my mechanic on sunday he tested it with him comp and everything was fine.
@VQP0WER changed up MAF and Fuel pump
Lakersallday24
06-16-2019 01:35 AM
MaximaDrvr
08-19-2015 08:20 PM
