Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendor Directory
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 12-10-2010, 11:52 PM   #1
Points: 1,690, Level: 23
Points: 1,690, Level: 23 Points: 1,690, Level: 23 Points: 1,690, Level: 23
Activity: 0.2%
Activity: 0.2% Activity: 0.2% Activity: 0.2%
Send a message via MSN to KilJim
Help~ Car not starting, no sound or anything
Hi guys,
Recently since about the last 2-3 weeks my '00 I30 has been getting starting problems. It sounds like it cranks just fine, but doesn't start up unless I step on the accelerator pedal (and a few tries with that)
Started off not so common, now it happens once in every 2-3 starts.
I've also had a P1320 for a long long time now. Previously had 2 coils replaced after getting specific coil codes, I always thought it was just gonna be another coil going bad so I didn't check the CPS
Anyway does this sound like it might be the crankshaft pos sensor (REF) going bad? If it is I might just go ahead and change it since it's not too expensive
UPDATE:
So now the car wont start at all. At first it cranks like usual, slowly got weaker and weaker until it doesnt crank at all now
Radio, fan and lights work when i turn the key to the ACC position. When i turn it to start, everything goes out
Is there a way to tell if this is the battery or starter? or something else
KilJim is offline   Reply With Quote
Old 12-11-2010, 04:45 AM   #2
Points: 6,460, Level: 52
Points: 6,460, Level: 52 Points: 6,460, Level: 52 Points: 6,460, Level: 52
Activity: 5.6%
Activity: 5.6% Activity: 5.6% Activity: 5.6%
Soon as you described the hard to start having good crank power I thought it was the CPS, it would be the first thing I would replace.
__________________
Sig. Rendered By Rochester
Llumar 20% /FSTB /SRI /BPI Stack /*17 Adv. /ATE Slotted Rotors & ATE Pads / 6000k HID Fogs /2x10 Subs & 1000w amp. /Michelin 235/45/17 /Budget B pipe & Vibrant Exhaust /LED Interior Lighting /Chrome Gauge Rings /Viper Security /F&R ES MM & Sub Bushings /Sm Markers /KYB GR2's-S-Techs /Cus block plate-VIAS del /NWP Spacers /Stillen Lip & Rear Valiance
Open to all Connections On LinkedIn
Maxima's FSM's
Owensfamily TSB's
Nissan "How To"
Ghost_54 is offline   Reply With Quote
Old 12-11-2010, 05:31 PM   #3
Activity: 0.2%
Yeah, read this thread Starting Issues - Related to Camshaft/Crankshaft Sensors? and thought it might be a similar issue
Nvm figured it out, its the right/front one apparently
Old 12-11-2010, 09:22 PM   #4
Points: 6,285, Level: 51
Points: 6,285, Level: 51 Points: 6,285, Level: 51 Points: 6,285, Level: 51
Activity: 0.4%
Activity: 0.4% Activity: 0.4% Activity: 0.4%
First......remove the CPS (the one under the crank pulley), clean any swarf of the business end, check it for cracks, check the harness and connector for damage, and reinstall. See if that makes any change in the hard to start issue before you start throwing parts on the car.
P. Samson is offline   Reply With Quote
Old 12-16-2010, 03:23 PM   #5
Activity: 0.2%
UPDATE:
Old 12-16-2010, 03:51 PM   #6
Points: 4,118, Level: 40
Points: 4,118, Level: 40 Points: 4,118, Level: 40 Points: 4,118, Level: 40
Activity: 1.1%
Activity: 1.1% Activity: 1.1% Activity: 1.1%
sounds like a battery issue.
even if the lights come on when you turn the key to ACC doesn't mean the battery is strong enough to crank the starter .
if you have the starting problem iwth a strong battery, then your starter or starter circuit is FUBA'red
__________________
2000 Maxima SE
www.jiujitsusweep.com For all things jiu jitsu
www.BJJGiMarket.com Slightly used BJJ gear
Amave is offline   Reply With Quote
Old 12-16-2010, 04:30 PM   #7
Points: 7,573, Level: 58
Points: 7,573, Level: 58 Points: 7,573, Level: 58 Points: 7,573, Level: 58
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Quote:
Originally Posted by KilJim View Post
UPDATE:
Your battery is dead now because of the cranking. As for the hard start issue try cleaning your grounds. I just read about another issue like this on another thread.
__________________
Froggmann is offline   Reply With Quote
Old 12-16-2010, 07:25 PM   #8
Points: 17,090, Level: 83
Points: 17,090, Level: 83 Points: 17,090, Level: 83 Points: 17,090, Level: 83
Activity: 94.9%
Activity: 94.9% Activity: 94.9% Activity: 94.9%
Maybe from trying to start it so much he may have ran down the battery....
__________________
I WAS BANNED! ARE U THE MAN???
CMax03 is offline   Reply With Quote
Old 12-16-2010, 08:45 PM   #9
Activity: 0.2%
Would if its just the battery would it not crank at all?
It has enough to power the radio, lights and fans right now, but doesnt even try to crank at all
Old 12-17-2010, 05:54 AM   #10
Points: 8,197, Level: 61
Points: 8,197, Level: 61 Points: 8,197, Level: 61 Points: 8,197, Level: 61
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
A new battery costs $50; buy one if yours is more than 3 years old. THEN start figuring out the other problems.
sontakke is offline   Reply With Quote
Old 12-20-2010, 03:24 PM   #11
Activity: 0.2%
Problem solved
Put in a new started from Advanced Auto and it started up better than ever
No need to waste $80 on a new battery
Also swapped ignition coil #1 with an eBay one and the P1320 is gone
Thanks for the input guys
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
